Roland HP-1 Electric Organ/Keyboard audio output noise
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Roland HP-1 Electric Organ/Keyboard audio output noise
    Originally posted by notallbad
    Just to see I'm going to disconnect the headphone jacks, there are 2 of them, at the amp/power board side. I doubt this is causing the fault but worth a try to eliminate.
    I did read somewhere in my travels someone had a curious sound issue and had something to do with the headphone jack.
    So, what did you find when you did that?
    Muh-soggy-knee
    • notallbad
      • Oct 2012
      • 1190
      I think what happened is what would be expected to happen.
      Pins
      1 Sig L
      2 Sig R
      3 AGnd
      4 Mute Send
      5 Mute Ret
      6 LED K
      7 LED A
      removing the 7 pin plug the piano switched on but the power led did not light up (Pin 6&7), no sound at all - Pin4&5 (no fault noise or key stroke tunes) either from built-in speakers or headphones obviously.
      So I removed just pins 1 and 2 Sig L and R, piano powers up with led and still get the faulty noise through the speakers.
      • notallbad
        • Oct 2012
        • 1190
        Solder side of the Main board.
        • notallbad
          • Oct 2012
          • 1190
          So, I'm going to connect an external speaker to the 'Output' jack, looking at the schematics this will bypass the Equaliser and Amplifier circuitry.
          These I take it would need to be powered speakers?
          If possible I shall then also try connecting an external input, which would presumably bypass the sound generator circuitry on the main board.
          • notallbad
            • Oct 2012
            • 1190
            Theres also a Local Control On and Off function which is for connecting MIDI devices, in the off state 'the keyboard and the internal sound generator are in an unlinked state. No sound will be produced by the keyboard when it is played.'
            The faulty noise still persists with this on or off.
            • notallbad
              • Oct 2012
              • 1190
              Hacked a few wires and mashed up a connection between the piano input/output jacks to a Logik LOGLM101DU Micro Hi-Fi System.
              Connected powered external speakers and get 'fault' noise through both left and right speakers with volume on piano turned up only.
              Connect an Aux input and plays through the pianos internal speakers fine, the 'fault' noise only occurs when the volume on the piano is turned up.
              Not sure exactly how conclusive this is?
              Does this narrow it down any?
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Does the noise change if you just tap the volume POT?
                It sounds like a bad op-amp or bad (noisy) resistor.
                Muh-soggy-knee
                • notallbad
                  • Oct 2012
                  • 1190
                  No, doesn't seem to make a difference tapping or twiddling the volume knob.
                  • notallbad
                    • Oct 2012
                    • 1190
                    Would it be possible to disconnect on Power/Amp Board CN4 Pins 10 LeftCh Signal, 11 AGnd and 12 RightCh Signal (these are AOUTL+/- and AOUTR+/- on AK4324 96kHz Sampling 24Bit DAC) and connect directly to speakers, bypassing the Control PCB i.e master volume and bypassing Power/Amp board.
                    • notallbad
                      • Oct 2012
                      • 1190
                      Still no success fixing this but an update:
                      Scope connected to CN8, Agnd (Pin 11) and LeftCh-Signal (Pin 10) or RightCh-Signal (Pin 12) and get the 'noise' waveform. Also get the 'noise' waveform on pins 1 and 7 of the M5218AFP - Dual Low-Noise Op-Amp.
                      The next step is to check between the 96kHz Sampling 24-bit DAC (AK4324) and the Op-Amp (M5218AFP).
                      Not really sure how to check before the DAC and getting the feeling that if the fault is before the DAC the problem is going to lie with an I.C.
                      • tony359
                        by tony359
                        11-28-2023, 05:18 AM
                      • MegaZAC
                        Onkyo TX-SR805 noise in one channel
                        by MegaZAC
                        Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                        Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                        There's some logic behind it. As soon as I select an input I get only left...
                        04-23-2025, 10:09 PM
                      • courtcircuit
                        Philips HTS8000 home cinema noise problem
                        by courtcircuit
                        Hello
                        I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                        Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                        Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                        I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                        Removed each of tyhe boards
                        02-08-2025, 08:22 AM
                      • Dannyx
                        Electric piano distorted notes (Roland RD100)
                        by Dannyx
                        Good day folks. Today, I came across something kinda special, which I haven't worked on before: a Roland RD100 electric piano. It was just sitting there in the shop covered in dust, no doubt having been ravaged and then abandoned by my oh-so-skilled co-worker. I actually remember seeing him struggling with this thing and I recall briefly witnessing the problem too: some of the notes play distorted. I'll try plugging it myself and maybe do some captures for you to hear for yourselves, but let's just say it sounds....bad.
                        I haven't actually dug into it myself yet, so this is mostly...
                        03-29-2021, 02:08 PM
                      • karatzdi
                        Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                        by karatzdi
                        I know some might say... just buy another one. Sell it as parts..!
                        So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                        Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                        Spent some time downloading the Service...
                        06-11-2024, 08:38 AM
