DVC subwoofer wiring methods
  • stevo1210
    • Oct 2006
    • 4156
    I just got my hands on a Jaycar (local brand) CS-2278 subwoofer with a Kevlar cone for literally peanuts.
    It was in a crappy looking box that looked all beat up... wasn't until I opened it to discover a dual voice coil sub! (explains why it was so heavy!).
    Now It says 250W RMS on it, but that's like max power I think?
    The previous owner wired it in series as in red to black from one coil to the other.
    My amplifier is a car amplifier (for the Jukebox) and it's a Kenwood DAC-624 model 2ch amp where I can bridge the connections to pump out 110W per channel at 4 ohms.
    Here's the performance sheet:
    http://www.subwoofer-builder.com/driver-CS-2278.htm
    Since mine is wired as "2 series coils", I get 8 ohms right? Does that mean the output from my amp will be 220W instead of 110W? I don't know how this works
    master hoarder
    • May 2008
    • 12175
    Re: DVC subwoofer wiring methods
    Yes
    No, not quite. As far as I know, the output power of an amplifier decreases with increasing speaker impedance.
    Is your car amplifier 2 channel single-ended and 1 channel bridged (BTL)? Or can it do 2 channels BTL? If the latter, then you can wire each coil to each BTL channel separately. If the former, you can wire the speaker coils in parallel to get 2 Ohms and wire that to the single BTL channel. Must check the data sheet or spec sheet for your amplifier, though - not all car amplifiers can handle 2 Ohms or lower impedance.
    According to the spec sheet of your subwoofer driver, each coil can handle up to 125 Watts (most likely this is peak and not RMS, though). That means the whole woofer driver can handle up to 250W itself. You can do this in 3 ways:
    - Wire the coils in parallel (2 Ohm impedance) and drive with a single channel on the amplifier (provided the amp is even rated to output 250W at 2 Ohms)
    - Wire each coil (4 Ohms) to its own channel and drive separately from the amp (then the amp must be capable of driving 125W into each channel into 4 Ohms).
    - Wire the coils in series (8 Ohm impedance) and drive with a single channel on the amplifier (provided the amp can drive 250W into 8 Ohm load).
    • mikey5791
      Help on car amplifier only one channel works
      by mikey5791
      Hi all forum members,
      Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
      My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
      08-06-2025, 10:36 PM
    • jinu_j
      How to test Subwoofer Amplifier with only a multimeter
      by jinu_j
      Hi Folks
      Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
      Problem
      I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
      Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
      Any advice would be appreciated...
      08-29-2024, 02:05 AM
    • Francesc V.
      Rotel RSX-1056 amplifier. Troubleshoot a noisy channel
      by Francesc V.
      Hi:
      I've realized that one of the channels of this amplifier has no proper sound.
      This is the signal at the speakers output.
      As long as the audio coming in to the amplifier board (blue) looks ok although with some noise due to the wire, I think that there's nothing to look at the preamp section.
      Now, I could start looking at components to see whether I find the guilty one.......but I would rather prefer to ask for advice. Here there is the amp. schema. Which points would you check with the oscilloscope to gather...
      07-15-2025, 01:33 AM
    • Sik_6ty_Sixx
      HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
      by Sik_6ty_Sixx
      So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
      02-18-2025, 05:06 AM
    • eccerr0r
      old X58 triple channel board... memtest86 memory speed?
      by eccerr0r
      Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
      Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
      Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
      06-28-2025, 09:06 AM
