2004 Avalon radio/6 CD JBL sys
  • ilikesteel
    • Jul 2012
    • 284
    • usa
    I have a 2004 Avalon. my problem is it stopped loading CD's. after inserting a CD it will not load all the way. consequently, you cannot eject the CD. I feel it may be one of the detection sensors that the CD passes as it is inserted into the player. it does pull the cd in to where you cannot see it from the front of the radio.
    I cannot find a schematic for the player. anyone familiar with this problem and any suggestions? also, I had the radio out to remove the CD. It looks complicated to get at the sensors too. If I could find a place that's reasonable, I'd get fixed by a repair place.
    thanks very much,
    frank
  • Longbow
    • Jun 2011
    • 623
    Re: 2004 Avalon radio/6 CD JBL sys
    If this player came with your vehicle, you are on your own with this fix, unless the dealer offers repair services for their car electronics. The big problem is getting repair info and parts.
    Car CD players have the straight in-drop down loading mechanism. Limit switches might be involved, but worn rubber loading rollers/belts are the most likely thing to need attention.
    However, the usual operation is that the disc tries to load, stops for some reason, then times out. At that point it will automatically eject, or will allow manual eject. If you are saying that the disc does mechanically get into play position inside the player, doesn't spin up, or won't read TOC, then we have a more serious problem like a bad laser or spindle motor. A good check would be to find a similar unit that works and confirm what is actually happening.
    Is it plugged in?
    • rhomanski
      nowhere man
      • 5157
      • U S of A
      I would think worn rubber as stated and or dust in the mechanism. I would pull it find out what rubber parts are in it replace them and clean and lube it first. These guys might be able to help you http://www.studiosoundelectronics.com/ .
      sigpicThe Sky Is Falling
      • redwire
        • Dec 2010
        • 3912
        Here are a few common problems with car CD players that I've run into:
        It's usually the transport (jamming) from dirt, no grease, kids put stuff in there, flaky limit switches (dirty/oxidized), CD (copy) labels peel off inside, etc.
        I would pull the unit out, pull off the top and try run it in-vehicle. Running it on the workbench is best but it's tricky to get power connections/pinout made. A dust clean job using a can of compressed air (not the laser pickup!) and lube the transport is mostly what I end up doing.
        Rarely, the transport can get out of sync - the radio CPU gets confused as to what CD is up and load or unload or swap was it doing. So you have reset the transport. I eject all CD's and do a cold-boot or hit the reset button.
        Um. well hitting the dash with a fist can temporarily work to clear a jam. I know it's silly but while the transport is trying to eject or load, give it a mild bump...
        • delaware74b
          • Apr 2009
          • 628
          I had 2 different model Pioneer head units (2002-2006 models, DEH P3xxx series) have the same load/non-eject issue. I used only CD-R's with the write-on surface, no labels.
          The disc would load with no issue and they wouldn't eject. I found the loader roller was slipping on its bar.
          A temporary fix was to glue the rubber roller to the bar, but it would last for 3 months.
          The permanent fix was a JVC Arsenal head unit with full bluetooth integration.....
          Stupidity should be a crime, especially for drivers. I have NO patience for them.
          • redwire
            • Dec 2010
            • 3912
            For dried out rubber rollers and idler wheels, I use MG chemicals rubber-renue, (DON'T use it on belts) it softens and remoisturizes rubber but a bit expensive.
            But it's a good point you make - CD's are pretty much obsolete and a car PC with SSD drive and WiFi makes an awesome jukebox.
            • ilikesteel
              • Jul 2012
              • 284
              • usa
              Thanks for all the replies and suggestions. will try and access rollers and clean them.
              frank
              • mikey5791
                Sony CFS-5000S radio cassette player no FM reception
                by mikey5791
                Hi forum members,
                In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
                Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
                I opened the casing inside and checked for any dry solder, burned component or loose wires...
                02-24-2023, 03:48 AM
              • shelby5041
                clock radio / radio lifespan?
                by shelby5041
                hi
                ive got a modern digital clock radio approx 15yrs old
                my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                it uses very little power just a few watts i would imagine that may have something...
                09-14-2024, 03:30 AM
              • slothen92
                Volvo HU850 Radio/CD-player repair, LDO-voltage regulator IC
                by slothen92
                Hello
                Im trying to repair the Volvo HU850 radio/CD-player from a Volvo V70.
                I have ordered replacements for the four transistors (SD1760), but Im not sure about a replacement for the low dropout voltage regulator IC (marked by the red circle in the attached picture).
                On the body of the IC it says: “LF33AH GK133544”.
                Does anyone know where to find this part or a replacement for it?
                Cheers
                04-09-2025, 08:30 AM
              • BOSCHNJAK
                by BOSCHNJAK
                ABOUT ME INTRODUCTION FILE
                2
                024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                2022 BEV, PROJECT ?
                2021 BEV, PROJECT ?
                2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                12-28-2023, 02:09 PM
              • UserXP
                Vintage SONY Digital Clock Radio ICF-C12W no audio
                by UserXP
                Dear all,
                I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                My question is, do you know of this brand of capacitors and how bad are...
                07-21-2025, 08:35 AM
