1965 Gibson Hawk w/ 7191's in the output
  • jnl636
    • Dec 2006
    Problems, Lots of hum. Can't find a schematic on this one. It uses 2 BEU7's 4 12au7's and 2 7191's for the output. I can remove every tube except the outputs and still hum. Checked a lot of voltages and everything seems ok. Still hum. Replaced the 20uF filter caps. Still hum. Tried a new set of outputs. Still Hum. Any ideas? There's not that much to it.
  • PedroDaGr8
    • Oct 2006
    • 130
    Re: 1965 Gibson Hawk w/ 7191's in the output
    Could it be a ground loop hum? I can't say I am very familar with anything about guitars or guitar amps. I do know though that they are very common on stereo equipment. I know that there are things that are called ground loop isolators that would take care of that. I am sure that more than likely you have thought of that but still thought I would ask.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      main filter caps open.
      and those are 7591's in the output.
      change every lytic and wax paper cap in it and report back.
      • FrancescoV
        Onkyo HT-R390 no sound output, video output ok
        by FrancescoV
        Good morning everyone,
        I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
        The firmware reported is the following:
        M:1.00/11107BLP
        D:?.??/????????
        O:1.00/11107AL
        The DSP firmware given the question marks seems corrupt.
        On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
        05-11-2025, 02:59 AM
        NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
        I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
        I bought this from an eBay seller but unfortunately they only had one
        I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
        I bought three of from them to also make battery packs with this output power limit in mind
        I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
        04-23-2025, 05:50 AM
        Corsair CX750M [Model 75-002019] - burned output toroid inductor
        by momaka
        Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
        So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
        09-19-2021, 08:44 PM
      • CoppellTVRepair
        Troubleshooting PFC with SPC1012T not raising output
        by CoppellTVRepair
        It has been a long while since I posted here to ask anything....hope you can help.
        I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
        I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
        03-09-2025, 10:38 PM
      • flibidy
        Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
        by flibidy
        I have here a Magnum IA.100 which belongs to my parents.
        The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
        Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
        What Ive done........
        01-01-2025, 01:26 PM
