Sansui R-303, Distorted audio......
  • Bobhoskin
    • Mar 2012
    • 23
    • italic
    Sansui R-303 with a big problem, the audio output it's distorted and if I turn the Volume knob, I can hear something from 10%, than it's all the same, even at 100%, very low volume.
    I've tryed every input, tape, Fm etc.. same problem.
    The tranformer seems ok, good voltages.
    All Caps seems ok (by eye), I've just tryed change the 4 ones that goes to the "Stereo Amplifier STK 4803", nothing changed.
    Can be the STK 4803 with that big designed dissipator?
    http://i.imgur.com/DRcAvop.jpg
    http://i.imgur.com/gzspcae.jpg
    I'm not an expert, please give me advise.
    (I can make many other photos if needed of each section.)
  • Bobhoskin
    • Mar 2012
    • 23
    • italic
    Re: Sansui R-303, Distorted audio......
    Help
    • redwire
      • Dec 2010
      • 3912
      One thing to try with STK's is to tap them with a screwdriver. The IC bonding wires sometimes fail and you will hear it.
      Otherwise, compare voltages on R, L channels on the chip's pins.
      • newbiesat
        • Dec 2012
        • 25
        • usa
        Checking the resistor value from the output pin 5 and pin 12 by using the digital multi-meter (DMM). Usually it is 4.7 ohm. The bad one never give the correct value. Must power-off the unit before measuring the value of resistor. Good luck.
        • Bobhoskin
          • Mar 2012
          • 23
          • italic
          Sorry guys for late reply, now I can make tests.
          I've tryed moving the STK, and I remade solder on all 16 pins, same problem ....I will try to tap (you mean like give knocks with the screwdriver??)
          I've tryed following the 2 resistors that are directly connected to pin 5 and 12, those are named like r8l & r8r, and they measure 10.1 ohm and 10.2 ohm, not really 4.7 ohm (with unit OFF but I didn't disconnect the resistors from the circuit board, bad idea?).
          • Bobhoskin
            • Mar 2012
            • 23
            • italic
            Here the photos of the STK Board... on the top view you see the 2 resistors on the left, R8r and R8l, both measure about 10 ohm..... please, give me advise:
            Top side:
            http://i.imgur.com/cASXAil.jpg
            Bottom side:
            http://i.imgur.com/RdjaatF.jpg
            Sansui R-303
            http://i.imgur.com/z2kyQxH.jpg
              The STK4803 is a stereo Power amplifier module, pin 5 is an Output for Channel1, pin 12 is an output for Channel 2, so reading between the 2 outputs will not really help.
              If you look at the pinout of the IC and the circuits inside the IC, what DC voltages do you get at pin 9 (+Vcc) and the chassis, Pin 7 (-Vcc) and the chassis?
              Make sure all the circuit board mounting screws are tight since the boards are grounded through the mounting screws.
              Since you are getting bad distorted sounds from both channel, chances are for both amplifiers to be bad is not likely, it has to be something common to both amplifiers.
              Does this unit has Main line In and Pre-amp out RCA jacks on the back? Did you activate the Tape monitor switches and the Muting a bunch of times to clean the contacts?
              • Bobhoskin
                • Mar 2012
                • 23
                • italic
                Thank you budm
                By now I've tried what you suggested on both pin 9 and 7 gives 33volt each, those match with the two big caps, but the value of the caps its 42 volt.
                I have clean all buttons like tape monitor...
                  Do you have the pictures of the rear panel of this unit? I will see if I have the service manual for it or not.
                  • Bobhoskin
                    • Mar 2012
                    • 23
                    • italic
                    Here the photos of the front and rear panel:
                    http://i.imgur.com/B05EKer.jpg
                    http://i.imgur.com/CnoEGb6.jpg
                    Precisely the 2 big Caps are 42V 3300uf
                    If can help, I can make a video and post on youtub, to listen how bad it works.
                    • Bobhoskin
                      • Mar 2012
                      • 23
                      • italic
                      Like you see on the rear panel there is some oxidation due to water of the previous owner that give it to me.
                      I hope it's fixable.
                        Do you have powered PC speakers that you can connect to the TAPE output to see if the sounds are OK at that point? Your +/- voltages are OK. We can also turn the powered speaker into signal tracer to find out where the distorted signals start.
                        • Elysarian
                          • Mar 2013
                          • 200
                          Probably a silly question, but have you checked the volume pot itself? (I'm assuming it's a pot looking at the vintage of the unit)
                          They do wear out and a break in the track on there can lead to the kinds of symptoms described.
                            Acer Aspire A314-22-R303 Notebook 3 Specification for Upgrade or Repair
                            This specification for the Acer Aspire A314-22-R303 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A314-22-R303 boardview and A314-22-R303 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-06-2024, 11:20 PM
                          • maleksa
                            Yamaha MOX8 boot freeze and distorted sound
                            by maleksa
                            My Yamaha MOX8 synthesizer recently developed two issues.
                            Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
                            Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
                            11-07-2024, 03:28 AM
                          • LEECH666
                            Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                            by LEECH666
                            Good day ladies and gentleman!
                            I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                            This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                            I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                            01-19-2024, 05:46 PM
                          • Hornnumb2
                            Sansui sled4019 dim picture
                            by Hornnumb2
                            I have a sansui that just started having a dim picture, adjusting backlight settings up or down have no effect on display. I went ahead and ordered some backlight strips for it but find it weird that changing the setting has no effect. Could it be power related. Where should I start? Thanks Michael ...
                            08-31-2025, 10:37 PM
                          • Hornnumb2
                            by Hornnumb2
