Altec Lansing V2220 - Problem (Free pile find)
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    As the title says, I picked up a fairly clean pair of Altec Lansing V2220 speakers. They sound quite decent, and feel solidly heavy. However when volume is adjusted there is a horrible crackling hissing sound.
    What is the problem and how do I fix it?
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Altec Lansing V2220 - Problem (Free pile find)
    You mean (only) during the time you're twisting the volume pot? If yes, then there's your culprit
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • rhomanski
      nowhere man
      • 5157
      • U S of A
      If it happens only when adjusting volume, then the volume control may be dirty. Shoot it with some Caig Deoxit D5 and turn back and forth about twenty times. Do it three times about 12 hours apart. Then use Caig Shield to replace the lube in the switch. That will clean the switch.
      sigpicThe Sky Is Falling
      • lti
        • May 2011
        • 2547
        I don't think you need the expensive cleaners and lubricants. I don't think it's worth spending the money on Deoxit and lubricant for computer speakers.
        I have been using the "bad" contact cleaner that doesn't contain any lubricant. It works fine, but I'm sure someone will have a story about a potentiometer failing because someone didn't use the lubricated contact cleaner.
        Spray it into the slot on the body of the potentiometer. It's usually on the bottom, facing the circuit board.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          and if you dont have anything else try wd40.
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • Zeonalbasta
            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
            by Zeonalbasta
            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
            09-13-2024, 01:17 PM
          • gugutm
            a1989 820-00850 stuck at 5v 0.041a Help
            by gugutm
            I'm new to the forum,sorry english is not my first language too, i got a basic plus knowledge, but now i am in this situation where i need some help , i spend good few days reading forums , here and outside , to help my problem solve, with no luck
            long story short, i bought macbook pro a1989 820-00850, clean no water damage which was stuck on 5v 0.200/300a i read a lot of forums what that could be , it indicated to faulty corrupted t2 rom
            of course before jumping to conclusion and connected to DFU , i believe i done basic checks...
            01-04-2025, 09:35 AM
            by Vesko356
            08-11-2023, 03:27 AM
          • perzyk23
            Lenovo T580 - LCD Panel problem - error 0288
            by perzyk23
            Good morning,
            I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
            10-25-2024, 12:42 AM
