Learn about Class D amplifer
http://www.badcaps.net/forum/showthread.php?t=24809Tags: None
by madan1Good day everyone.
I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
The normal value of the positive and negative power rails is +/- 43V.
The positive rail stays...-
Today, 10:33 AM -
by dicky96Hi guys, this is general query really
So I have a Hill DX3000 3KW audio amplifier here.
It has a topology/design like a class A/B but all the banks of output transistors (10 transistors in each 'side' of the channel) are NPN.
I was wondering what class this is. It doesn't fit the description of class A.
It also doesn't match class A/B or B amplifiers as all the examples I see have a complimentary output stage desigs (NPN/PNP) and clearly is not G, H or D
I looked for 'class A push pull' but that didn't tell me anything either
by japlyticFor some time, a "Class 2" HDMI cable (part number BN39-01583B) supplied with a Samsung 4K 60 Hz display sometimes causes the display to overlay a few horizontal lines of flickering pixels of random colours and sometimes drops out, particularly on content requring HDCP.
Since changing the cable to a thicker Class 2 unit, this problem has not occured again - do you know of other marginal "Class 2" HDMI cables supplied with displays?09-06-2023, 08:50 PM -
Hello!
Unfortunately my Lenovo L14 Gen 1 (motherboard NM-C741) was involved in a terrible mishap. At first, one of my friends accidentally spilled coffee on it which made some of the ports stop working but the computer worked fine otherwise. After that I stupidly opended it and forgot to disconnect the battery... One thing leads to another and I accidentally short it between two components (unfortunately I do not remember which components). After that I get nothing, no charging indication, no boot indication, no fan spin, nothing.
So I'd love to learn my mistakes and... -
by presario425Hi all!
I have a piece of gear with a Power-one SPL130 power supply in it. On the primary side, there is a very tiny (about the size of your thumb nail) RIFA Class Y capacitor, 2.2 nF. I'm not too sure about the condition (whether or not it's cracking) but I do know that it's there.
I'm aggregating information as to how I should remedy this. It hasn't exploded yet, but that's what I'm trying to avoid.
I've never seen a RIFA class Y safety cap self destruct (or at least it hasn't been documented in the past). However, it's not worth the risk to leave it in there.... - Loading...
