Cambridge BassCube 12 blowing relays
  • blargg
    • 51
    I got a broken Cambridge Soundworks BassCube 12 someone was giving away. Powered on, and sub suddenly went all the way in/out (not sure which). Disconnected and I measure -49V on speaker output. Ouch.
    I trace things and find that it has a DPDT relay that connects the +/-50V rails to the amplifier, and that one side is stuck closed, and the other stuck open, so the amp was only getting -50V. I had also noticed that one of the transistors was hot, but the other wasn't. With it off, I didn't measure any shorts between the rails and the speaker output, so the transistors aren't shorted.
    Oddly there was a second relay inside whose coil was in series with the main one, but had NOTHING connected to the contacts. So I rewired the power rails to this one, and it promptly blew out the contacts for the +50V; they're open permanently now.
    I found another SPDT relay and connected it in series to control that rail, and it didn't destroy it. I got ~0V at speaker output, so I connected it to the speaker and powered on. Loud pop, then the same -50V again, with the speaker not liking it at all. As best as I can tell, the protection circuit is kicking in when it's turned on, but only turning ONE relay off, perhaps just lowering voltage until both rails aren't on. So the speaker gets -50V again.
    At one point, only the +50V rail was connected, and the OTHER transistor got hot. So the first time one got hot was clearly a result of having only one rail.
    If I UNPLUG the speaker from the amp, power in, THEN plug the speaker in, it works beautifully. Been running it for hours now, with georgeous room-filling bass and no hum or anything. I checked and none of the amp transistors is getting hot now. I'm going to get a really beefy DPDT relay and see if perhaps the relays in it were just old or maybe got worn out by all the bass. They were 5A 250V, so it's hard to believe the contacts would blow that easily. There aren't any capacitors either on the amp side after the relay, so no inrush current to fuse the contacts.
    Also a side question about improving the voltage regulator design: With this thing on for a while now, I'm noticing that almost all the heat comes from what seems to me a terrible voltage regulator design: power resistor to zener diode. They employ FOUR of these, for two +/-15V supplies from the +/-50V filtered/rectified output of the transformer. Would there be any downside to just putting some 15V regulators in place of this? The PCB is really toasted/brown from all the heat these wasteful regulators generate. I'd rather not subject it to more heat, and save some electricity as well. I'm thinking that there's one possible snag: regulators would put less constant load on the transformer, which might result in a higher +/-50V supply since it's unregulated off the transformer. I'm wondering why they don't use a switching supply in subs like this, since switcher noise is high frequency and therefore totally filtered out by the nature of the sub being very low-frequency.
    Re: Cambridge BassCube 12 blowing relays
    I am surprised that this unit does not have speaker relay protection that will detect DC present at the speaker and shutdown the speaker relay. To drop 50V down to 15v, the regulator IC will have 30V voltage drop across it, if the 15V circuits draw lets say 100mA, it means that the regulator will have to dissipate about 3 Watts of power. This setup will be pushing the Vin limit of the regulator.
    The power relay contacts may expose to high inrush current, so what ever you put in, you should find out the inrush current spec if they can provide it.
    By the way, is this thing using Class D amplifier or linear amplifier?
    • blargg
      • 51
      I wonder whether this is relay system is related to detecting large DC on the speakers, and was failing to work. I could always put the speaker on one of the relay switches, as that would have protected it from these stick DC episodes.
      I researched the regulator a bit and found that I could use a 317/337 adjustable regulator, which has an absolute maximum drop of 40V from in to out. In this case it'd be dropping 50V to around 16V, a 34V drop. I'll have to see if I can measure how much current the preamp is using, and the amp.
      I hadn't thought about the regulators having to dissipate a lot. Perhaps I could drop to say +/-20V, then use normal 7816/7916 regulators to get to the two +/-16V supplies. Or heck, once it's dropped to +/-20V, use their resistor-zener regulators, since they'll be dissipating a lot less.
      But maybe I'm not paying attention to the fact that both of these use resistive means to drop the voltage, and thus might be hardly any different in terms of efficiency. Switching regulators maybe? This is getting involved. My Kill-A-Watt says it uses about 20 watts (@120V AC).
      I don't think the relays had any inrush because they're after the power supply filter caps.
      It looks like a linear amplifier. It's over a decade old. No inductors on the output either. It's got a huge metal-cased power transformer inside.
      • blargg
        • 51
        After fighting with this protection circuit all day, mapping it out and seeing how poorly it operates, I just bypassed the relay so the amp is always powered, then put the speaker on the relay and manually switch it in after the amp has been on for a few seconds. This eliminates all popping and nasty stuff, and it works perfectly. I also moved the power resistors from the underside of the board by the zeners to the copper trace side on top, which gets the heat away from the zeners and other sensitives there. Either this thing is way overpowered, or I'm just running it at very low volume compared to what it can do. I think an amp one quarter this size could easily drive it plenty loud. Oh well, I've spent way too many hours and it's working and hopefully won't fail and kill the speaker...
        • smurtz
          Cambridge Audio Stream Magic 6 - Power Supply
          by smurtz
          I have here a Cambbridge Audio Stream Magic 6 which does not power on.
          When opening the case the PSU appears to be faulty:
          IC1 (ICE3BR0665J), D2, the rectifier bridge, C15,C16 are dead and T2 is fried:
          I found the schematics of the PSU in the cambridge Audio CXN Service guide which uses the same:
          My problem is that I cannot find any info on T2 (SG01323) which seems to be a choke. Anyone knows how I can find a replacement & the value of that choke ?
          Thanks very much in advance...
          12-20-2024, 02:40 PM
        • valvashon
          Repair Success! Middle Atlantic UPS2200R-IP
          by valvashon
          Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
          Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
          02-06-2024, 12:54 PM
        • flibidy
          Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
          by flibidy
          I have here a Magnum IA.100 which belongs to my parents.
          The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
          Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
          What Ive done........
          01-01-2025, 01:26 PM
        • yuii
          ThinkPad W530 - faulty CPU regulators?
          by yuii
          Hello
          I've got two W530 boards, one with K1000M and one with K2000M graphics card. The first one had an issue of turning off under heavy CPU load after about 30 minutes or in idle. GPU load wasn't causing it to shut down. Trying to turn it back on would only make the power LED to come up for about 2 seconds without fan spin or thinklight flash, and that's it. It also wasn't charging the battery after it died.
          Gently pressing the laptop in left upper corner would fix this problem for a couple of days.
          The latter is completely dead and has the same 2-second power blink, nevermind...
          11-01-2023, 02:59 AM
        • CoinCoin88
          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
          by CoinCoin88
          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
          09-15-2025, 03:36 AM
