Memphis 1000w amp
  • cchandler
    • Nov 2012
    Memphis 1000w amp
    When i hook it up to power, remote & ground it powers up then it makes a "click" sound & goes off. What could be making it do that?
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Memphis 1000w amp
    You are going to have to open it up and check for bad caps - post pictures
    please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...1&d=1290283049
    https://www.badcaps.net/forum/attach...7&d=1280167246
    It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Are any speakers connected?
      Likely a shorted amplifier stage, hence the amp going into protection mode.
      Muh-soggy-knee
      • nosaj
        Samsung QN82Q70RA powers on then powers off
        by nosaj
        I have a samsung QN82Q70RA powers on then powers off. Using some info on the interwebs. I disconnected main board from power supply and backlight shows blue and stays on indicating power supply is good. So next I unplugged one on the lvds cables that connects to screen( I think other side goes to tcon board?) i can get a blue screen and if I press the picture button on the remote i get rain sounds and birds chirping. A lot of videos suggest using kaptan tape to cover the clock signals, but I've been unsucessful there.
        So I thought I'd just quit messing around and come to the best site...
        11-07-2025, 04:58 PM
      • malogro
        Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
        by malogro
        Hello all,
        I'm stumped on this guy, so wanted to see if anyone has any further ideas:
        Intro:
        This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
        Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
        04-14-2023, 04:44 PM
      • bohaboha
        Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
        by bohaboha
        Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
        anyhow i couldn't t read anything else
        the backlight is on strong and the screen does not get dark or very dark but no pictures
        the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
        01-02-2025, 08:04 PM
      • jose6326
        Samsung s32d850t powers off
        by jose6326
        Powers on as normal shows an image then powers off after 10 seconds
        I have to unplug it from the wall and replug to get it to turn back on but then shuts off
        No blown caps
        I searched for this model but nothing comes up...
        11-29-2024, 11:21 PM
      • valvashon
        LG 55UH6150- trouble powering up, then half lit screen (pictures!)
        by valvashon
        The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
        Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
        11-24-2024, 12:08 PM
