Denon PMA-500v issues...
  • drummr
    • Nov 2012
    • 8
    Hi, I'm having a problem with a vintage Denon receiver that up until a week ago worked wonderfully. The right channel randomly got severely distorted, while the left remained normal. Today I opened it up to see if I could see anything wrong, and I found 2 blown fuses that correlate to the right channel. As a test, I took the 2 functional fuses from the left channel (same specs) and put them in place of the blown ones. As soon as I hit the power button both fuses blew and a capacitor right next the the fuse on the right let out a little smoke. So now both channels sound horribly distorted.
    Any idea why the right channel would blow the fuses instantly? From what I've read it might be something to do with shorted output transistors?
    Here's a pic of the area in question: http://i240.photobucket.com/albums/f...n/IMG_0407.jpg
  • drummr
    • Nov 2012
    • 8
    Re: Denon PMA-500v issues...
    Quick update: Took both output transistors out for the right channel and both of them are shorted. Left channel ones check out. I also checked the resistor that smoked and it seems to be fine.
    • 999999999
      • Sep 2006
      • 774
      Yeah that's the usual cause, though sometimes it's a leaky or shorted transistor just prior to the output transistor pairs.
      • drummr
        • Nov 2012
        • 8
        The receiver is actually my friends and he would occasionally turn it up too loud and it would make a horrible popping noise from the speakers(clipping?). As a precaution I am replacing both output transistors on both channels, the cap that smoked (It seems to work, but the top is bulged out), and the fuses (duh).
        • drummr
          • Nov 2012
          • 8
          Ok, I replaced all 4 output transistors (including the 2 left channel ones, just in case), the blown cap, and the fuses and it worked great for about a day and a half. I had the receiver hooked up to my computer after testing it out, but not playing anything, before giving it back, when it randomly made a loud horrible electrical arcing hiss noise from the right channel speaker and it smelled like a toasted resistor. I quickly turned it off and unplugged the power. Both brand new right channel transistors are shot, and a nearby resistor looks burnt, but the fuses didn't blow (they are the right spec). With the right channel fuses removed, the left channel plays fine. With the fuses in place, the speaker relay doesn't engage.
          What should I be looking for now? Or should I just give it back and say it's not worth the effort/cost to try and fix?
          • 999999999
            • Sep 2006
            • 774
            Sounds like you had excessive DC on the output, you'll need to check that channel's output transistor pair again and start tracing back the circuit with no load connected, or at least a very high impedance load like a power resistor, not a speaker.
            At the base of the output pair transistor(s) you should have an AC voltage with minimal DC offset. Compare against the left channel with an equal signal to each and equal load. Trace back to the component prior and see if it is also receiving AC with minimal DC offset.
            It's a bit hard for me to trace something with so many components with no schematic from a pic, but it could be that you have a basic push-pull current gain stage after an opamp on the right channel that corresponds to "IC-5" for the left channel but is hidden in the picture. If this is the case, also measure the output pin of that to see if it has minimal DC voltage (offset) or it is already present at that point in the circuit.
            Of course you should also measure the power rails, both at the output transistor collectors to be sure they are equivalent +/- values, and at the IC-5, again assuming it's a dual rail opamp). The values for the transistors and the opamp may not match each other but the power rail positive and negative values per each separate stage should be polar opposite equivalents of each other. For example it could be (wild guess, just an example) +12/-12V rails for the opamp, and +35V/-35V for the output transistor pair per channel.
            There could be some other fault, for example I see some diodes one step before the output. Fortunately you have two channels which look to be laid out near identically so you can take multimeter measurements as described above and compare where readings from the faulty right channel deviate from the left channel. Wherever they begin to deviate, a component somewhere right before that in the signal path is probably to blame, or the power supply rail going to it.
            Whether it is worth the effort or cost I cannot say. Since I suspect the prior trasistors which are probably less than $1 each if you use near equivalent parts instead of vintage identical parts, it could be cost effective, for that matter a lot of even less expensive components could be replaced to shotgun the problem for pennies a piece, but the time to do it on top of the time to disassemble and reassemble is something only you can place the right value on.
            Since it's about 25 years old now, I'd probably pick between giving up or also committing to replacing all the electrolytic capacitors on the amp board while it's out, maybe spray some cleaner in the potentiometers too and work that around. On the other hand I don't know if the owner has other amps or how much of a rush this is. Since I have other amps I'd probably trash it and save the case, transformer and heatsink for a new chipamp build in it but that's a whole new topic.
            • randtek
              • Oct 2011
              • 280
              • US
              I once had a Denon that I rebuilt, lasted for about a week, went out again. It turned out to be a grounding issue with the amplifier. The power amp grounded through the heat sink screws, and they had gotten corrosion over time between the screws and the copper traces, probably due to dissimilar metals and electric current. This might be something to check for. Another thing I have learned from many years of experience in this field is that when repairing a blown channel I ALWAYS replace at least the driver transistors too. I usually just order all of the transistors in the preamp and power amp stages. They are usually dirt cheap, and it saves me from a lot of repeat failures. The reason that I do this is simple. Modern amplifiers are DC coupled, and when a transistor fails in one, it throws biasing off throughout the whole channel. This can cause the semiconductors that have not failed to be stressed, and they will probably fail prematurely. This tip was given to me by a Pioneer engineer many years ago, and has probably saved me a lot of repeat fails.
              • Sik_6ty_Sixx
                HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                by Sik_6ty_Sixx
                So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                02-18-2025, 05:06 AM
              • falcontech
                Denon Mc6000 channel 1 completely non-functional
                by falcontech
                Hello
                I need your help with a non-functioning channel on this Denon controller. I noticed the problem because, with the mixing software, the channel appears completely off and none of its controls work. At the top of the channel, like the others, there's a selector switch that moves between MIDI and external audio inputs. I also tried connecting an audio source (since it's also a standalone mixer) and I got no input. The flat cable connecting this panel to the sound card is fine. I'm attaching a photo and the service manual. I hope someone can help me resolve the issue. Thanks....
                09-04-2025, 09:03 AM
                Surface Mount Fuses Fundamentals Datasheet
                TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                10-07-2024, 06:07 AM
              • eccerr0r
                old X58 triple channel board... memtest86 memory speed?
                by eccerr0r
                Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                06-28-2025, 09:06 AM
              • re-atari
                Repair Denon AVR-X2600h power amp SBL and SBR channel
                by re-atari
                A few weeks ago I bought a defective Denon AVR-X2600h receiver, wanted to use this one to find and fix a fault in my X2400h. This last part is already successfully done (turned out to be a defective TOP268VG in the X2400h's STBY PSU). So far so good.
                As I like a challenge, I now want to try to fix the X2600h. According to the serial nr. the receiver is built in june 2020. The seller wrote in his ad, that he had bought the receiver in a defective state, and wanted to fix it himself, but could not find the time to do so. The receiver would jump to DC protect mode when switched on...
                08-13-2022, 07:34 AM
