Rotel Caps Questions and help request.
    by momaka
    03-12-2025, 03:42 PM
  • bermo96
    Rotel RA-810 Fader Caps
    by bermo96
    I rescued an old Rotel RA-810, after a little cleaning and new thermal grease for the transistor it works like it should.
    But unfortunately the fader caps are gone, they are nice aluminum caps, so I want to try to find something similar.
    Does anyone know if this amp shared these fader caps with other brands? Or if there is something similar on the internet?
    The picture is for the balance cap, the faders have the black line running through the cap.
    04-08-2025, 07:16 AM
  • Paxman_Swede
    by Paxman_Swede
    Hello!
    01-14-2025, 09:51 AM
  • captain150
    by captain150
    03-16-2025, 07:34 PM
  • Foetuss
    Gigabyte GA-6OXT :: caps question
    by Foetuss
    Good evening
    I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
    Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
    But I was also suprised about the bigger boys, which are 330µF 25V.
    Could it be they used 25V caps because they were cheaper / available at that time?...
    02-11-2025, 12:22 PM
