Receiver works sporadically
  • HOHMBOY
    • Jun 2006
    Typically when I first turn it on, it powers up, but no sound comes out, then it will just start working without touching anything. Sometimes it will stop working again. Is this a loose connection somewhere? Any help would be appreciated.
  • japlytic
    • Oct 2005
    • 2086
    Re: Receiver works sporadically
    It appears to be something intermittent. Dry and faulty solder joints can be hard to find, so if you have the time, resolder every solder joint.
    • HOHMBOY
      • Jun 2006
      Thanks!
      • arneson
        • Sep 2005
        • 1267
        Here's a fairly simple test for bad connection.
        Access main board, top or bottom.
        Activate system in it's simplest form, ant and coouple speakers.
        Butt end of small screw driver, plastic, start gently tapping around power supply.
        Move onto tuner section, move into preamp, and finnaly tap around outputs.
        Listening for any reactions this should take all of five minutes and will tell about general board condition.
        After all that I could add that a single badcap can absolutely cause that symptom.
        I would go to the old hot cold treatment to find the culprit. (freeze spray and heat gun on small coupling caps)
        Jim
        • Cornito
          Denon AVR-2700H audio stops while receiver still works
          by Cornito
          Hello team,
          I've got a new issue with a Denon Avr-2700H.
          After several minutes working, receiver stops playing sound with a poc eared in the speakers.
          Receiver still work and display video with error message on display.
          Seems to me that is the main output relay.
          I'm looking for the service manual that I can't find for the moment.
          Does somebody have it?
          Regards...
          08-03-2025, 06:10 AM
        • CapLeaker
          Dell ATX PSU won’t start, but forcing it works fine?
          by CapLeaker
          Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
          Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
          10-28-2024, 06:59 PM
        • CDNBrewer
          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
          by CDNBrewer
          Hello Everyone,
          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
          Symptoms:
          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
          • I swapped the Left and Right surround
          08-05-2025, 09:29 PM
        • wolf1976
          wireless receiver for 6 speeds fan control with remote control
          by wolf1976
          hi i have a receiver that is destroyed from the overvoltage i guess
          my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
          the motor fan has not label
          i have an other receiver operational
          In your opinion can i measure the voltage at the output ?
          what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
          thanks in advance...
          07-23-2025, 03:12 PM
        • rounin
          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
          by rounin
          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
          🛠 Original Issue
          The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
          04-19-2025, 01:18 AM
