Replacing old high-voltage electrolytic capacitor
  • pol098
    • Sep 2011
    • 18
    An interesting link on restoring, replacing, or repairing high-voltage capacitors in old equipment, e.g. multi-section 450V. Covers safe re-forming of existing capacitors, various replacement ideas, how to replace capacitor without changing the appearance of collectable equipment. If you pay, you could even get a capacitor rebuilt within the original can, until the one and only expert died.
    http://www.nmr.mgh.harvard.edu/~reese/electrolytics/
  • MORETTIGIAN
    by MORETTIGIAN
    Title:
    Description:
    Procedure performed:
    - Removed backplate
    - Reapplied thermal compound
    - Reassembled card
    09-18-2025, 12:14 PM
  • madscientist750
    Replacing electrolytic caps by solid caps on old motherboards
    by madscientist750
    I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
    I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
    I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
    10-19-2025, 06:10 AM
  • cloudff7
    Electrolytic capacitor leak in storage?
    by cloudff7
    there a risk of this aluminum electrolytic capacitor of electronic device long term storage opening and leaking acid and corroding the PCB board?
    07-22-2024, 06:27 AM
  • devsigner
    identify capacitor for MacBook Pro with rare logic board 820-02037-06
    by devsigner
    Hi
    While messing around with my MacBook Pro, I stupidly pinged off a very small surface mounted component that I’m now trying to identify.
    resistance tests show a rising resistance value, indicating a capacitor.
    The laptop boots up and runs, however I'm choosing not to use it until I get it fixed.
    i can’t see any markings on the capacitor at 10x magnification using a professional jewler's loop.
    It seems like there's some damage to the capacitor - one side doesn't have "shiny bits" - can you tell I don't do this for a living!...
    11-28-2025, 01:39 PM
  • AleXis6
    Manufacturing Date of Electrolytic capacitor
    by AleXis6
    Guys. could you help me please to decode some codes of main capacitor's producers.
    I would like to know the manufacturing date.
    Based on the information from capacitors I have - it seems easy to decode manufacturing date for Rubycon, Nichicon.
    If I understood correctly:
    1. Nichicons marks date of production as (see the attached pictures) H2116
    I don't understand the meaning of first letter - may be it is code of factory.
    21 -year
    16 week
    I bought this capacitor recently.
    another one-
    2....
    10-11-2021, 02:20 PM
