Bowers and Wilkins ZEPPELIN crappy caps
This is what you get these day for expensive products.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809Tags: None -
Re: Bowers and Wilkins ZEPPELIN crappy caps
Bowers and Wilkins ZEPPELIN crappy capsNever stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
That's what I call an expensive piece of junk.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
I know Samxon GF is problematic, but geez, I didn't think Samxon GK series was bad.
I remember growing up reading Stereo Review and seeing all the positive reviews on the BW series speakers.
Thanks for the "teardown".--- begin sig file ---
--- end sig file ---Comment
I dont even trust ipods, mine which was just out of warranty had copletely lost audio in the right channel, then a year later it randomly died, and made a clicking sound from the internal speaker a few times, then totally dead.
Over $150 for a small thing that fits in your hand that doesnt last more than a year of less than 3 hours use a day! .....
-BenMuh-soggy-kneeComment
Look on the bright side, for those of us who know how to repair stuff, it's dirt cheap if not free to acquire a lot of electronic toys and fix them to the point you feel they're MORE reliable than if you'd been given the same thing brand new.Comment
I have to admit, these things sound great, the second one (later model) I open up which suppose to have been upgrade with better power supply, but I found bad caps (Su'scon) as well. Sorry for people that paid $500~600 for this thing.
They are sure hard to put the grills back on.Never stop learning
It doesn't surprise me one bit, my Polk Audio powered subwoofer is full of CapXons, you'd think for the price they charge for these things they could use good caps, but I guess saving a few cents on the caps boosts the profit margin, and since most audio equipment isn't too hard on caps they can get away with it most of the time. In fact the only relatively recent piece of audio equipment I have that has good caps is my Kenwood VR6070 home heather receiver which is 100% Elna and Cornell Dubilier.Comment
Hi Budm,
I have the earlier version of the zeppelin (chrome back) the unit has just died, and research has pointed to power board, what capacitor would you use as a good replacement?
GaryComment
Also got a Jamo 200 sub for ~50$ that was "way too quiet" - culprits ended up being the gain pot and the dual-gang low-pass adjustment potKhron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - ShenanigansComment
I have this one too, but It have problme with PH7SD chip
http://www.uphinh.vn/image/stream/1374912.jpg
Can you advise me how to repair this. or...
ThanksComment
My friend´s B&W Zeppelin only plays on right channel with both the center bass speaker and left channels being dead!
Can anybody help me out, please?
Thanks and regards,
Alnasir.Comment
Just brought one of these full of, suscon capacitors. They are not physically bloated but most are open circuit:
3 1500uf 16v all test fine
6 220uf 25v 4 open circuit the other 2 very high ESR and no capacitance
6 100uf 16v caps all open circuit
2 22uf 50v caps open circuit
1 100uf 35v cap 40 ohms with 20uf left
I changed all the caps and the primary’s for high end power supply caps, also added some more heat sinks with thermal glue to the floating TO220 power transistors and output diode....
I can see why these power supplies throw tantrums, the units run very hot I don’t think the passive air intake from the speaker movement is enough to cool the unit properly. Bad design for the price of the units new, luckily I only paid £10 for mine faulty and it’s in mint condition I’ll grab some photos before I put it back together.Last edited by ReeceyBurger123; 04-25-2021, 04:13 AM.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
I feel like modern Samxon GK's are pretty decent. I usually replace a lot of Samxon when I see them if I have a better replacement but usually they test very good esr when removed.--------------------------------------------------------------
Ryzen 3600x
16GB Patriot 3600MHz
MSI B450 Gaming Plus
MSI Air Boost Vega 56
Acer 32" 1440P Freesync
Rosewill Capstone 750W
Hakko FX-888D Station
FX-8802 Iron
MG Chem .8mm 63/37 RA 2.2%Comment
by soflesHi there,
Recently I bought broken Bowers & Wilkins PX7 S2, the problem with them is that battery discharges on its own even with headphones turned off. It is a quite common issue with this model and even with model higher PX8.
With help of thermal camera I found out that there is one IC that is hot even with headphones turned off. To check if I'm correct I bought another PX7 S2 working one and replaced small charging board with this IC and problem solved, battery no more drains on its own. After changing board back to original problem returned so I'm 100% sure problem...-
05-30-2025, 01:11 PM -
by eryjusHello,
Channel: General Capacitor Questions & Issues
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
- Loading...
