Directed Audio 2400D powers on into protect.
  • ktulu909
    • Mar 2012
    • 40
    Hey folks,I have a Directed Audio D2400 that has been in my car a little over a year.Its a high current car audio amp amp driving 2 Fosgate P3 10" at a 1ohm load,which it is stable at.
    So basically the short version is that I got into my car last week and there was no bass.Worked the day before,never had it go into protect and then one day theres just nothing.
    Voltage to the amp is adequate (been working professionally in car audio and security for 20 years,so I can promise its nothing with the install)Subs are metering properly and play just fine with my old amp.
    I cracked it open and here are the pics.Looks like one cap is damaged,but ill let you experts chime in and let me know what you think.
    Re: Directed Audio 2400D powers on into protect.
    What are the cap arting as printed on the body of those 5 caps and the 4 large caps on the pictures. This amp uses DC-DC step up switching power supply to power the power amp section
    • ktulu909
      • Mar 2012
      • 40
      The 5 caps are 25V 2200uf
      The 4 large ones are 80V 3300uf
        OK, those 5 caps are for the DC input from your car batteries, the 4 large one are for the DC-DC step up switching power supply, I belive this use dual voltages (Plus supply and Minus supply) for the for the power amp sections, that why I can see two TOROID transformer. It may have gone into protection mode if it senses short circuits in the power amp section. This chassis will not be easy to work on with a lot of transistors attached to the heatsink. I would expect to see about 45VDC on those 4 big caps if you can access it from the top of the board. This amp looks like Class D amplifiers.
        • 999999999
          • Sep 2006
          • 774
          The top (as pictured) 25V/2200uF cap looks physically damaged, I'd at least replace that. Otherwise this could be a real PITA to troubleshoot with it shutting down, but if I were stuck on Gilligan's Island or something and it was the last power amp on earth, I'd desolder and pull the last stage output transistor pairs then see if it stayed turned on, measuring for signal at their lead locations... suspecting a short in one of those.
          • ktulu909
            • Mar 2012
            • 40
            Pulled it out of the heatsink and it has 67.2 volts on the large 4 caps.And of course now it isnt going into protect.So it appears this is going to be one of THOSE problems.I cant even replace the damaged cap because of the mountain of solder on the underside of the board.All I have is a 40/20 watt solder station.And yes,it is a ClassD amp.
            • ktulu909
              • Mar 2012
              • 40
              Yea,I agree about the top cap,but it looks like it was probably installed that way.I agree that I should probably change it,but like i said,I have no idea how to unsolder it lol.
              • 999999999
                • Sep 2006
                • 774
                feed it a very low level audio signal (so as to not create much heat with it out) and see if it works. Might just be a bad solder joint you've temporarily reconnected by handling the board.
                • cadiman
                  • Mar 2010
                  • 397
                  This is a plus and minus switching supply. These run about 60 to 80 volts (pulsed) then get rectified into the + 30 and - 30 voltages needed to run the audio section. This is where 80% of the problems are with this type of amp.
                  When most amps fail or shut down it will mostly be one of the mosfets in the switching power supply. In your case caps too.
                  the mosfets are easy to check on both sides with a meter as they are all in series on each side.
                  If you find one side shorted then you will need to pull each one until you find the shorted mosfet.
                  You can also check the two rectifier diodes (in the middle bottom of the picture). They will normally be ok.
                  Then go after the audio section last.
                  As said above you do not want to run this thing with the heat sinks off it will fry quickly even at low volume.
                  You can bench run this amp with a 20 amp power supply. (use an inline fuse) Stuff happens!
                  • samson7point1@yahoo.com
                    Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                    by samson7point1@yahoo.com
                    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                    The player processes the audio signal using two different reference frequencies. The "R"...
                    04-30-2024, 11:22 AM
                    HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC E6300 Specification for Upgrade or Repair
                    This specification for the HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC boardview and Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will...
                    09-12-2024, 03:36 PM
                  • i_am_patch
                    Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                    by i_am_patch
                    Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                    04-30-2024, 08:20 PM
                  • MOSSEP
                    Monitor Audio RSW12 - Green light but no audio
                    by MOSSEP
                    Hi
                    Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                    Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                    The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                    I have already tried replacing all of the...
                    01-26-2025, 08:18 AM
                  • grimacelord
                    MacBook Air 2337 - Right I/O Board Audio IC - Alternative Replacement?
                    by grimacelord
                    I'm working on a MacBook Air A2337 that had liquid damage on the right I/O board. I ultrasonic cleaned the board and it all functions except the computer has no audio. I tried reballing the audio IC which is TAS5770AC0, but that did not restore audio. I could just replace the entire board, but I wanted to see if replacing the audio IC would fix it first. Mouser has a similar audio IC in stock which is TAS5770LC0YFFR, but I wasn't sure if it is compatible. I was just wondering if anyone knew if I could use the one from mouser as an acceptable replacement or if I need to purchase...
                    12-11-2023, 11:13 AM
