Car audio with no radio and blown cap
  • pentium
    • Mar 2006
    • 2778
    I bought at the flea market a Sony car minidisc deck and while it is a little worn it almost works perfectly. I say almost because the only thing that does not work is the AM/FM radio. I can test and get a good signal using my antenna from my old CD deck, unplug and connect it to the new deck and all frequencies are dead static. Opening it up I found the traces to the TUX-020 tuner module from the antenna connector were fine so I suspect the module itself is faulty (at least, I hope..). No worries there as my old CD deck uses the same one.
    The bigger problem I noticed was that on the exact opposite of the board was this little bugger.
    Nothing in the surrounding area showed sign of damage but what on earth blew it up?
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Car audio with no radio and blown cap
    That's a supercap. Most likely for storing the settings or something.
    They don't live particularly long, especially not in a baking hot (at times) car..
    • samson7point1@yahoo.com
      Help troubleshooting an audio problem with an RCA SGT-250 CED Player
      by samson7point1@yahoo.com
      The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
      The player processes the audio signal using two different reference frequencies. The "R"...
      04-30-2024, 11:22 AM
    • shelby5041
      clock radio / radio lifespan?
      by shelby5041
      hi
      ive got a modern digital clock radio approx 15yrs old
      my question is how long can a clock radio or a simple radio last ss farcas operating hours?
      since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
      the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
      it uses very little power just a few watts i would imagine that may have something...
      09-14-2024, 03:30 AM
    • Babbar
      by Babbar
      04-12-2024, 01:12 AM
    • RetroComputingGrotto
      DAP AUDIO QI-4400 Goes In To Protection Mode - Blown Cap
      by RetroComputingGrotto
      I've got a DAP AUDIO QI-4400 Amplifier on my workbench. When you turn it on, it goes in to a protection mode that a lot of these bits of kit seem to have. On opening up the unit I could immediately see a blown cap, so I replaced it and powered it back on. It still went in to protected mode (so there's still something wrong with it) and after about 10 minutes the cap I replaced went bang! Just in case you can't see it, it's the one I've drawn a black cross on so I dont forget which one it is!!
      You have to remove the metal housing in the middle as the...
      11-15-2024, 06:08 AM
    • praveenramavath
      Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
      by praveenramavath
      Hello All,
      I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
      https://www.hifivision.com/threads/m...-screen.98243/
      Troubleshooting Summary: Majority Internet Radio - Flash Chip
      04-26-2025, 09:08 AM
