crate b6350 cuts in and out
  • mcross
    • Sep 2011
    • 201
    pa mixer amp, works but cuts out for 20 or so sec then works again for a while. Would bad transistors cause this as in MJ15025 and MJ11522 there are 4 each in the unit
    Thanks for any help
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: crate b6350 cuts in and out
    If the finals were bad then it would not output any sound. More likely some protection circuit is tripping. Open it up and give it a good cleaning first and see if the problem persists. If you cannot find any thermal protector, the amp is cool and the transistors are secured to the heatsink, then look for the problem in the input and driver stages.
    A working TV? How boring!
    • mcross
      • Sep 2011
      • 201
      will do and let you know what i find
      • Zonzi
        Neptune mixer model 611 - Works for a few minutes then fades out and distorts
        by Zonzi
        Hi there !
        This is my first post out there, glad to be part of the community.
        I was gifted an old analog mixing unit (from the 70s) by a good friend. It's a Neptune Audio Mixer model 611, 6 channel mixer with :
        -6 XLR inputs wired hot to 3, and 1&2 to ground (which is already a weird start. You can see this in Picture 3, and all sockets are what I understand to be common ground, as there's a long wire connecting all XLR grounds together. Besides, all Hot are connected to the other pins via a cap with the marking 24 102k)
        -6 unbalanced...
        02-16-2023, 06:28 AM
      • Bektronics
        Schematic Digital Audio mixer RCF type M18
        by Bektronics
        Hello dear audio friends.
        I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
        The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
        I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
        Thanks in advance if anyone can help me with this schematic.
        Of course, all information about this digital mixer and possibly references...
        07-24-2023, 06:40 AM
      • CapLeaker
        Dell ATX PSU won’t start, but forcing it works fine?
        by CapLeaker
        Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
        Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
        10-28-2024, 06:59 PM
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
        🛠 Original Issue
        The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
      • ex250
        Kenwood SW-505D no sound issue and pops from time to time when it works
        by ex250
        Hello mates,
        I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
        It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
        12-29-2024, 03:27 PM
