Infinity PS-12 Powered Subwoofer Fired Amplifier
  • electricboyo
    • Mar 2013
    • 26
    Re: Infinity PS-12 Powered Subwoofer Fired Amplifier
    Always use a “dim bulb tester” to apply mains power to these types of amplifiers. 60W or 100W conventional incandescent light bulb is about the right size. You need to get the amplifier to the point where it can play sound at low to moderate volume before applying “full” mains power to it.
    • Leroy_2000
      • Aug 2018
      Got my PS-12 fixed too! Sub was humming while sitting at idle (no sound). Hum went away when I replaced the C72 capacitor.
      Also the sub was making chirping noises. Noticed the light in the back flashing frequently between green and red. Could also hear internal circuitry noises (if I get up close to it), as if circuits were being activated and disabled quickly, on the order of about six times each second. Replaced the C2, C37, and C65 capacitors and all of those noises went away.
      Big thanks for all the contributions to this thread! #righttorepair
      • rxm9600
        • Feb 2019
        I just acquired a PS-12 and the cap is blown(of course.), but it also burned the board...
        Is this fixable? I have not seen another one that is burned this much...
        https://imgur.com/gallery/mfwxtNk?fb...YF9kI2iZClRpwU
          master hoarder
          • May 2008
          • 12175
          #184
          I don't see any burning at all. If you are referring to the brown stuff around the big caps - that's just glue used to hold down the caps at the factory.
          Should be fixable if there are no other dead components, aside from the bad cap(s). On that note, I recommend replacing all electrolytic capacitors in this unit. At least that would be the first part in the repair process for this unit.
            Yep, just bad brown glue.
            • ttatma
              • Feb 2019
              • usa
              #186
              Originally posted by budm
              FORCED ON circuit.
              My sub has problem switching from red to green. I repalced most of the capacitors although they all looked good.
              C2/12/35/37/39/41/78.
              I also replaced Q2 with 2N5550 equivalent and Q3 with 2N5401 since I could find the original parts. Are these the right ones?
              My sub switched to green now. But no sound when I connect to the amp. If I played from my phone, I'd get sounds.
              What other parts I need to replace. Also, C71/72/73/74 still have 0V.
              • lti
                • May 2011
                • 2548
                The last few pictures show a hole burned in the board under the blown cap. You have to load the last seven pictures.
                • Mwitte
                  • Jun 2019
                  I am not familiar with the "dim bulb tester" that Electricboyo mentioned above. Is that an incandescent bulb in series with the 120 volt input to act as a fuse?
                  • andy1
                    • Apr 2019
                    • 9
                    That is correct. You can Google and there is a ton of info on this. Make sure you are careful to take precautions so that you do not get electrocuted as this involves 110VAC household mains supply. If you are not sure, get it checked out by a qualified person.
                      master hoarder
                      • May 2008
                      • 12175
                      #190
                      Exactly!
                      https://www.badcaps.net/forum/showpo...4&postcount=70
                      Note, however, that it won't actually act as a fuse; it will behave more like a current limiter. How much current goes through depends on the load you put on the power supply. Generally, you won't be able to run most power supplies with any significant load with the dim bulb tester (due to increasing voltage drop across bulb with increasing load.) In most cases, the dim bulb tester is just enough to allow the power supply to turn on and show you that nothing is shorted on the primary (i.e. bulb will go bright/lit otherwise.) But that is still very useful.
                      In the case of amplifier PSUs, though, I've found that typically you can run the amp at a very low to medium volume to test the operation. To allow for a bigger load, you can use two or three series bulbs all in parallel or a single 100-300W bulb.
                      • sachs
                        • May 2015
                        • 5
                        • Brazil
                        #191
                        Finally after leaving the laziness aside I replaced all the caps practically and 4 more resistors and redid solders in addition to putting a fan to keep it warm, the result is that the subwoofer has never been so good, perfect.
                        • jiari
                          • Apr 2018
                          • 23
                          Nice Job. I would recommend putting standoffs between the box and the plastic. Otherwise, the fan will be rather ineffectual in pushing/pulling air into a closed box. I ended up removing my fan as it made too much air noise.
                          • sachs
                            • May 2015
                            • 5
                            • Brazil
                            #193
                            I opened a hole in the plastic, the fan draws hot air perfectly from the amplifier box
                            • mhren
                              • Apr 2017
                              I know this post was from quite a while ago but I'm wondering how this worked out for you? Looking at that last picture it seems C71 exploded (and it took out D34 with it)!!
                              Here's a picture of mine and you can see the same exact part failure (this is on the bottom of the board just in parallel with the crossover cap C73 that was bulging) BUT mine was not nearly as bad.
                              So I have replaced all the electrolytic caps and the two crossover bipolar caps and have just ordered a replacement for C71....
                              Unfortunately the specs for C71 is not listed in the manual on the parts page but I see on the schematic that it is a 0.1uF probably 100V. I ordered this but does anyone have an idea of what it really should be?
                              https://www.digikey.com/en/products/...K1RACTU/754779
                              Once I replace C71 I'll post how the repair went....
                              • mhren
                                • Apr 2017
                                My Infinity Entra Two is working good as new.
                                Not sure if this is visible to others but here is the bill of materials I used at Digikey for the caps.
                                https://www.digikey.com/BOM/Create/C...?bomId=8604745
                                My board was a first revision so I used the original caps except for C37 which I upped to a 270uF since my sub normally didn't stay (green) on for the full 10 minutes before going back to standby after no input (now it does)
                                Add to this the small ceramic cap in my prior post that was unique to my failure along with the two crossover caps posted by jiari in post #119. I also put a bit more silicon next to the new NP caps so it looks as good as new
                                https://www.parts-express.com/6.8uF-...acitor-027-336
                                https://www.parts-express.com/4.7uF-...acitor-027-332
                                Thanks to everyone that's posted in this thread before .. lots of good info here to help complete this worthwhile repair.
                                • R_J
                                  • Jun 2012
                                  • 9551
                                  Your Digikey link can't work unless you want to provide your login and password, which I would suggest you do not.
                                  • backcountrymountains
                                    • Aug 2022
                                    So, I now have a broken PS-10 with the same vaporized C71 and a slightly bulging C6.
                                    Can anyone post a definitive list of parts to replace? @mhren?
                                    • Flying Trunk Monkey
                                      • Jan 2023
                                      This thread has been in circulation for over 10 years now, why stop?
                                      I actually joined this board after googling how to fix my PS-12 amp so I could see this pics referenced.
                                      I'll start with my question and then give background....
                                      Q1: C65 is listed in the repair manual as 470uF but the installed part appears to be 47uF. Unfortunately, I ordered replacement parts based on the manual. Also, on the board the outlined footprint of the cap is much closer to the larger 470uF chassis. Admittedly, C37 is also a smaller chassis cap with a larger footprint. I'll likely test and reinstall the 47uF cap at C65 and see if this amp will function again.
                                      https://www.manualslib.com/manual/10...ected=1#manual
                                      Does anyone have any input as to which value is actually correct?
                                      I'm at the point now to where I need to get my dining room table turned repair station cleaned off before my wife gets home so I'm going to reinstall the C65 47uF cap and hope that this turns out to be the correct recommendation.
                                      Background:
                                      I decided to replace the following components based on info found throughout the thread as I had the power relay rapidly switching/buzzing condition (with no sound output) that seems to be a common issue.
                                      C2,C4,C9: commonly suspected issue because the SAMXON branded caps throughout the amp seem to be of questionable quality, also the caps in this location are in the vicinity of the 4 resistors that appear to run VERY warm.
                                      C6, C9: powers supply caps, appeared good visually but they are SAMXON branded and aged
                                      C12, C78: commonly suspected issue because the SAMXON branded caps throughout the amp seem to be of questionable quality, and also because C12 is in the vicinity of the 4 resistors that appear to run VERY warm.
                                      C65, I thought this cap was SAMXON branded but after pulling it I see it appears to be "Su'scon"
                                      C72 and C73: these NP caps appeared fine visually and I don't suspect they were part of the problem but there are posts in this thread that show these can cause problems. Figured it would be cheap and wise to replace them while I had everything apart. Digi-Key only had polarized caps of the correct specs so I ordered two of each and installed them in opposing polarity.
                                      Thanks to everyone who has contribute info here over the years, I wouldn't have attempted this repair without what I found here.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        #199
                                        I found some information in the following two posts:
                                        https://www.badcaps.net/forum/showpo...&postcount=130
                                        https://www.badcaps.net/forum/showpo...&postcount=133
                                        To highlight the important part, this is what jiari put down:
                                        I see the note on AresROC's blog that changing C65 from 470uF to 47uF fixes the chirp. Honestly, I can't tell if it's ok to swap out. The change looks ok to me (IR2111 seems to be used very closely in line with the application notes which only called out the bypass cap), but I don't know amplifier design. AresROC mentioned in post #94 that it was a design change on his revision D board. I'll give it a try if I need something from Mouser. I'm not that bothered by it.
                                        Also, I looked at the IR2111 datasheet myself, and while it doesn't list a sample / application circuit, it does show two test circuits, both of which have 10 uF caps for what would correspond to C65. So I think anything down to that value may be OK to use. In your case, I suggest going with whatever values was installed there originally (looks like 47 uF). But if you don't want to buy replacement caps just for that, then you can try the 470 uF caps too. As per the other posts, it seems the older revisions of this sub used 470 uF caps. So the change should not have any adverse effects, other than perhaps a high-pitched chirp during power On.
                                        When in doubt, you can always use the incandescent lightbulb "trick" in series with the AC live to limit power/current, in case something does go wrong.
                                        https://www.badcaps.net/forum/attach...chmentid=10462
                                        Lol. At least you only have a sub on there. I have an entire 55" TV taken apart, and it's been sitting there for a week. But then I don't have a wife to complain to me so... all is fine?
                                        Su'scon, SAMXON... whatever. Neither is that much better than the other.
                                        Pretty much the only worthwhile cap companies today, at least for reliable small-can electrolytics, are Panasonic, Rubycon, Nichicon, and United Chemicon, which are all Japanese brands too. Sanyo/Suncon are too, but you'd be hard-pressed to find these for sale anywhere. The ones on eBay and Amazon are typically counterfeits.
                                        Should be OK with that.
                                        Let us know how the repair goes/completes.
                                        • Jodeanss
                                          • Dec 2017
                                          • 7
                                          I've read the entire thread now. I thought my amp had obvious signs of what was wrong but all I found was a little browning by the resistors..... and no one mentioned anything like what is happening with mine ..... got this wierd zap sound happening.
                                          https://youtube.com/shorts/_duiud-yCZk?feature=share
                                          https://youtube.com/shorts/I8oVNq_59eQ?feature=share
                                          Should I just start replacing caps anyway?
                                          I get nothing out of it at all, have never seen the woofer move.
                                          • jinu_j
                                            How to test Subwoofer Amplifier with only a multimeter
                                            by jinu_j
                                            Hi Folks
                                            Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                                            Problem
                                            I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                                            Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                                            Any advice would be appreciated...
                                            08-29-2024, 02:05 AM
                                          • MrCommunistGen
                                            Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                                            by MrCommunistGen
                                            My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                                            I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                                            07-12-2021, 05:11 PM
                                          • rustinjust
                                            Please help, subwoofer connected to tv, read description below
                                            by rustinjust
                                            I've got a subwoofer that I've had for nearly 20 years, it did come with a basic remote which I've lost. It's a generic make of subwoofer, I can't see a brand sticker on it. It comes with 2 speakers.
                                            Question recently I've connected it up to my tv which has greatly improved the sound on my tv, however I'd like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                            Is there a way of...
                                            10-28-2023, 07:09 AM
                                          • rustinjust
                                            Please help, where can I get a remote for my subwoofer?
                                            by rustinjust
                                            I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                                            Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                            Is there...
                                            10-28-2023, 03:43 AM
                                          • stefan94stefan
                                            Amplifier Subwoofer Gale 3090
                                            by stefan94stefan
                                            Hello guys ,
                                            So first time I took this subwoofer with amplifier damaged "no power " , I checked the amplifier board and I found two power resistor missing and some smoked board around , I've changed them and now I got power but some smoke comes out from other resistor I can't find a diagram . The amplifier board is poor exfoliates.
                                            Please if is someone here who can help me I need a diagram because I found some missing resistor I've put them back and now when I turn on I get smoke from 47r 1/4w resistors .
                                            This using Toshiba 2sa1943 transi...
                                            02-29-2020, 11:04 AM
