Infinity PS-12 Powered Subwoofer Fired Amplifier
  • Tecchris0516
    • Apr 2018
    • 10
    Re: Infinity PS-12 Powered Subwoofer Fired Amplifier
    Hello All,
    New to hear - but a huge wealth of information - I just got a PS-10 from a Garage sale - that didnt power up - Internal fuse was blown - replaced the fuse and immediately blew- did some preliminary checking and form the Q18-22 MOSFETS were bad - replaced and powered up but lasted for about 3 sec and fuse blew again - check and mosfets bad again !
    I began checking some voltages and i have some questions
    What is the output voltage (DC) from the bridge- i have over 100vDC
    What is the voltage After the (R6-&A) and (R9& R9) I have about 10v
    What controls the 15V rails - I checked C5 and i have approx 8v but on C10 it is less then 1V
    I also replaced TIP31C with the orig Q18,22 to be safe
    There were also a list of CAPS that were know issues - replaced all of them as well
    and Q2 and Q3
    And help would be appreciated
    • Tecchris0516
      • Apr 2018
      • 10
      Hello all,
      I was wondering if someone can help me out with the above post
      Thank you
      • Jr_ece
        • Feb 2018
        • 33
        Tecchris,
        Have you located the service manual? The schematic and parts list are included at least for the PS-12. With the parts list you can get data sheets to determine if the voltage makes sense. I didn't have to mess with the power supply circuitry or transformer so I don't have any specific data that I can recall without digging into the documentation mentioned.
        Do you know for sure the fuse rating including voltage, amperage, and speed are correct?
        It seems like there was some discussion on here about the expected bridge output, but would need to search for it. Maybe this weekend a couple of the others can jump in and help.
        Wanted to let you know we saw your post and to encourage you to stick with it. It should sound good when it's repaired.
        • Jr_ece
          • Feb 2018
          • 33
          I asked about the fuse due to some similar klipche subs being shipped with incorrect/faulty fuses. The service manual and probably users manual should state the correct size fuse.
          • Tecchris0516
            • Apr 2018
            • 10
            Hello JR,
            Yes I do have the service manual and have been going through it until my eyes crossed, along with reviewing the data sheets for components - the fuse it correct (2.0a/250v) slow blow)
            the voltage out of the rect bridge is 121v DC - the voltages at the MOSFET's are 70v along with the same voltage at the MOSFET driver - (IR2111)
            I am trying to find out what controls +15v - MOD and -15v - MOD and +15VSW
              It is linear bi-polar power supply to produce +/- 60VDC with ref. to circuit GND as shown in service manual PDF page 33.
              Q2 and Q3 are for linear regulator circuits (they take +/- 60VDC input to produce +/- 15V outputs) to produce +/- 15VDC for running the OP-AMPs as you can see in same page number. So do you still have the + and - 15V as shown in the schematic? or it is still blowing the main fuse?.
              So look at the schematic then you will see what/where the circuit GND is for your meter.
              Page 32) +15Mod is fed by the +15V through Ferrite Bead inductor FB1.
              Page 32) -15Mod is fed by the - 15V through Ferrite Bead inductor FB2.
              Q18. 22 are blown is probably due to drive circuits are bad and not switching the MOSFET's ON and off bu they are stuck fully on, there are many parts in the GATE drive circuits that you need to test. This is class D amplifier not linear amplifier.
              • Tecchris0516
                • Apr 2018
                • 10
                Bud, - JR
                Thank you for the response - the fuse is not blowing right now due to me removing the Mosfets. But the 15v is not anywhere near 15V - I will check Q2 and Q3 as I did replace those as well with a cross NTE128P (NPN) & NTE129P (PNP). The only reason why i chenged them as to multiple posts about issues with them. I might put the old ones back and see what I get.
                • Tecchris0516
                  • Apr 2018
                  • 10
                  Hello All,
                  Well I reinstalled the old Q2 and Q3 with the original ones - when I measure between C5 (+) and C10 (-) i only get about 8v.
                  If i measure the voltage after the (R6-&A) and (R9& R9) I have about 10v ( before the resisitors (51.6V)
                  I also checked the voltage through the FB1 and FB2 an it is the same on both sides..
                    So you are getting only +8V and -8V from the +/- power supply.
                    What do you have at the Emitter, Base, and Collector pin of the Transistor with ref to the circuit GND?
                    FBx is just simple inductor, there will be hardly any Voltage difference between the two leg of the FBx.
                    C4 and C9 are OK, correct?
                    BTW, the schematic called those two regulator circuits as 'SHUNT REGULATOR', they are not Shunt regulators, they are series regulators.
                    You can learn more here: https://cdn.badcaps-static.com/pdfs/...3da308ff49.pdf
                    • Tecchris0516
                      • Apr 2018
                      • 10
                      BudM,
                      Sorry for the delay - Busy at work
                      Voltage from transformer -
                      AC1-AC2 -53.4vac
                      AC3-AC2 -53.6vac
                      AC1-AC3 -106.8vac
                      After Bridge - 121.6v DC
                      voltage to (R6-&A) and (R9& R9) 51.5v after 10v
                      For Transistor MPSW06 (NPN) - which meter neg to GND( Neg side of rectifier bridge)
                      E- 8.82vdc
                      B- 9.52vdc
                      C- 10.12vdc
                      For Transistor MPSW56 (NPN) - which meter neg to GND( Neg side of rectifier bridge)
                      E- .54vdc
                      B- 0 vdc
                      C- 0 vdc
                      If it put positive meter lead to the (+) on the bridge
                      E- 9.6vdc
                      B- 10.1 vdc
                      C- 10.1 vdc
                      C4 and C9 are both brand new
                        Originally posted by Tecchris0516
                        BudM,
                        AC1-AC2 -53.4vac
                        AC3-AC2 -53.6vac
                        AC1-AC3 -106.8vac
                        E- 8.82vdc
                        B- 9.52vdc
                        C- 10.12vdc
                        E- .54vdc
                        B- 0 vdc
                        C- 0 vdc
                        E- 9.6vdc
                        B- 10.1 vdc
                        C- 10.1 vdc
                        I see why your Voltage readings are not right, the Negative of the bridge is for -50V power supply with ref, to circuit GND, the + of the bridge is for the +50V power supply with ref. to chassis GND. You use the wrong GND ref. for the Voltage testing.
                        May I ask if you know how to read schematic? If you know how to read schematic then you will know where the circuit GND is.
                        • Tecchris0516
                          • Apr 2018
                          • 10
                          BudM,
                          Thank you for taking to time to stick with me. Based on your comment i guess I am incorrectly testing the component(s) - I have attached how i have been testing. Can you please enlighten me to the correct point for GND ref and i will be more than happy to supply the data to help get this working
                          The second image after looking at the schematic again - I green circled the GND ref- is this correct?
                            That Triangle symbol (center tap of the power transformer) that you circle in green is the circuit GND, the amplifier runs on +/- power supplies (+50V, -50V) that are ref to circuit GND.
                            You AC for each half of the transformer shows 53.4VAC, the the DC Voltage as measured on each main filter caps C6, C8 with ref to circuit GND should be = 53.4VAC *1.414 =about 75VDC, the caps are rated at 80VDC so are you 100% that you are getting 53.4VAC as shown in your diagram?
                            • Tecchris0516
                              • Apr 2018
                              • 10
                              Budm,
                              Well I re-measured the voltage at the C6 and C8 caps with ref to the circuit GND- on C6 I had 50.8VDC and on C8 I had 70.8VDC.
                              So for the hell of it - I reinstalled the original Caps ( replaced both due to one was slightly bulging) and rechecked - now both Caps are at approx 71vdc.
                              For Transistor MPSW06 (NPN) - which meter neg to ref GND
                              E- 11.46vdc
                              B- 12.02vdc
                              C- 13.0vdc
                              For Transistor MPSW56 (NPN) - which meter neg to ref GND
                              E- .74vdc
                              B- .20 vdc
                              C- .20 vdc
                              I wonder if the defective Caps I bought did further damage to other components
                              • R_J
                                • Jun 2012
                                • 9550
                                When you measure the voltage on the caps was the voltage on C8 -70.8 volts (negative voltage)
                                It seems like you have open R9 & R9a
                                The likely reason the voltage you measured was high is because the resistors are open and with no current flowing the cap charged up to peak voltage.
                                • Tecchris0516
                                  • Apr 2018
                                  • 10
                                  R-J
                                  I did have -70vdc on C8 -- referencing your attachment
                                  On the Red arrows = I have from Left to Right 70v 13v 13v
                                  On the Green Arrows = I have from Left to Right @ C7 (-70v) but at the resistors I have -.74 and I cant find a break between C7 (- side) to the R9A/R9 resistors
                                    So if you check the resistance between the (-) of C8 and the left side leg (based on the diagram) of the R9/9A legs it shows open circuit?
                                    May be you need to upload well focused pictures around R9/9A.
                                    • R_J
                                      • Jun 2012
                                      • 9550
                                      This is a double side board and a feed-thru got damaged, likely at the c8 negative connection.
                                      • Tecchris0516
                                        • Apr 2018
                                        • 10
                                        R_J
                                        that was it - under the C8 there wasn't enough of solder - now I have -71vdc
                                        and a C5 i have +14.2vdc and at C10 I have -14.1vdc
                                        I am going to go buy another C8 due to it bulging and I need to get Q18 / Q22 as they shorted and was originally blowing the fuse when I bought the amp broken.
                                        Thanks to you and Budm for your assistance so far!
                                        • Jr_ece
                                          • Feb 2018
                                          • 33
                                          Tecchris0516,
                                          Did you get it completely repaired and working correctly?
                                          • jinu_j
                                            How to test Subwoofer Amplifier with only a multimeter
                                            by jinu_j
                                            Hi Folks
                                            Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                                            Problem
                                            I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                                            Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                                            Any advice would be appreciated...
                                            08-29-2024, 02:05 AM
                                          • MrCommunistGen
                                            Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                                            by MrCommunistGen
                                            My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                                            I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                                            07-12-2021, 05:11 PM
                                          • rustinjust
                                            Please help, subwoofer connected to tv, read description below
                                            by rustinjust
                                            I've got a subwoofer that I've had for nearly 20 years, it did come with a basic remote which I've lost. It's a generic make of subwoofer, I can't see a brand sticker on it. It comes with 2 speakers.
                                            Question recently I've connected it up to my tv which has greatly improved the sound on my tv, however I'd like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                            Is there a way of...
                                            10-28-2023, 07:09 AM
                                          • rustinjust
                                            Please help, where can I get a remote for my subwoofer?
                                            by rustinjust
                                            I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                                            Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                            Is there...
                                            10-28-2023, 03:43 AM
                                          • stefan94stefan
                                            Amplifier Subwoofer Gale 3090
                                            by stefan94stefan
                                            Hello guys ,
                                            So first time I took this subwoofer with amplifier damaged "no power " , I checked the amplifier board and I found two power resistor missing and some smoked board around , I've changed them and now I got power but some smoke comes out from other resistor I can't find a diagram . The amplifier board is poor exfoliates.
                                            Please if is someone here who can help me I need a diagram because I found some missing resistor I've put them back and now when I turn on I get smoke from 47r 1/4w resistors .
                                            This using Toshiba 2sa1943 transi...
                                            02-29-2020, 11:04 AM
