Re-cap my Pioneer SX-950
  • kidd
    • Aug 2011
    • 5
    I was going to re-cap my Pioneer SX-950 and while peeking at the Equalizer Amp Assembly (AWF-011) I had noticed 1 bulged cap and 2 others that were not the value I was looking at in the schematic, C-7 is supposed to be 330uF/6.8V and C-8 is supposed to be 330uF/6.8V and they were both 470uf/6.3V and then the one with the bulge is supposed to be 220uf/25V and it is 330uf/63V.
    I guess my question is do I replace with the schematic values or the ones on the board?
    Would this cause my speaker protect relay to shunt the audio when I go to try turn it up?
    Also is there any way of finding out if these are updated values that came out after the SM was printed, Any help would be appreciated also if there is another SM around to be downloaded as the one on the data page is not clear at all when you download it and you can't read it.
    Thanks, Kidd
  • ipman
    • Jul 2011
    • 159
    Re: Re-cap my Pioneer SX-950
    That depends. It's important to know what those capacitors do in the circuit.
    If they are just filtering, a slightly higher value does not matter.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      ipman speaks truth.
      Can't know from what you've said if these caps are in the power distribution or something for the audio signal.
      If in the audio, changing the uF could change frequency handling/properties.
      If those caps are just part of the ripple filters [they remove SMPS noise] then that much uF difference probably won't matter [ESR matters more for that] and the added uF will help somewhat for DC load changes. [Cranking it up or down for instance.]
      If it worked well with those caps then look up the specs [beyond uF you need to know Ripple and ESR] and find replacements that match as close as possible.
      [That works no matter what they do.]
      Mann-Made Global Warming.
      - Dr Seuss
      • spiros.p
        Pioneer DJM-800 recap
        by spiros.p
        point of interest i recap my 14years old djm800 psu.last 2-3 months gets too hot the mixer on psu side.open it after two hours of use and touch the big filter cap and the near mosfet heat sink was very hot.under the board i see three hot spots that is discolored from excessive heat. replace all caps with nichicon GU big filter cap and all the others with nichicon KY and panasonic FR now is running cool and sounds better.
        07-28-2022, 02:17 AM
      • Bushcat
        Pioneer PL-X9 motor speed control wobble
        by Bushcat
        I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
        Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
        BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
        05-24-2023, 03:36 AM
        ASUS P5GC-MX motherboard recap
        by momaka
        Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
        This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
        So here is what the motherboard looked like with its original caps:
        CPU VRM area up close…...
        01-27-2021, 11:59 PM
      • EduCabral
        [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
        by EduCabral
        I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
        While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
        🔧 Details:
        • Model: YT-M06
        • Interface: Pioneer 1
        • MCU: Fujitsu MB89F202
        • Goal: Find a valid .bin firmware file or memory dump from a working unit
        I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
        07-15-2025, 12:26 AM
      • pixelcap
        Pioneer Kuro Pro 111FD 8 red blink error
        by pixelcap
        Pioneer Kuro Pro 111FD 8 blink red LED.
        I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
        So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
        based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
        10-06-2024, 11:26 PM
