BMW Logic 7 sub amp issue
  • koerneka
    • 33
    (I tried to post this once but apparently it didn't go through )
    I was given a Logic 7 rear (sub) amp to look into, as I am familiar with component-level repairs. The bass of the BMW Logic 7 system cuts out after being on for a few seconds. This is apparently a common issue with 7-series BMWs. A new amp is over a grand from the dealer.
    I cracked the amp open, half expecting to see bulged caps. However, I haven't seen any. There are a couple 25V that are kind of suspect (Samwha, SME). There are a bunch of tall KME 25V 6800uf caps and a couple of short squat Rubycons. I think the tall caps drive the subs and they look good.
    I might be in over my head, but if anyone has any guidance, I would appreciate it!
  • 999999999
    • Sep 2006
    • 774
    Re: BMW Logic 7 sub amp issue
    I know nothing about this amp, but I'll throw a few ideas out there... since the bass works for a short period before cutting out my random (since it could be true for some amps but I've no knowledge of this amp's circuit) suggestion would be leaking driver transistors right before the output transistors, that they soon enough cause an overcurrent shutdown condition. It might help to search for info about what kind of protection circuits it has, possibly also overheating but unless the heatsink jumped off I wouldn't expect overheat shutdown in only a few seconds.
    However if it is common you might find someone elsewhere on the 'net that has traced the circuit, found the fault, and done the repair.
    If all else fails do a few common things. Reduce input signal to zero and see if amp stays on with speakers disconnected. In steps, raise input signal very slightly and measure for any output (voltage, to confirm proper operation before it's high enough to even drive the speaker(s) to an audible level). If it made it this far, reconnect speaker(s) and repeat the above.
    I would not suspect bad caps to cause this if none show signs of failure. If all else fails, you'd remove the output transistors and see if they are ok (Google search for type, mosfet or bipolar junction transistors), and leave them out and power up the amp with a low level audio input (playing), measuring at the transistor base or gate pad on the PCB for half the waveform of the expected output if it were working properly (lowest voltage scale on a multimeter will at least get a change in reading).
    Repeat the test for every output transistor used.
    If no luck yet, now repeat the tests with no audio input signal and also measure - there should be a marked reduction in signal reading at the base or gate pad, ideally approaching zero. If it isn't approaching zero you pull the driver transistors off the board and repeat all the above, checking if they are working still and measuring at their base for an even smaller drive level.
    If these things seem beyond your ability, your best hope is to keep hunting BMW or electronics forums till you find an owner who has fixed one themselves. Also check for delaminated PCB traces or cracked solder joints that might have caused a break in some subcircuit when it heats up slightly due to current flow. Places to start looking are where prior heat has darkened the top or bottom of the PCB and around larger resistors and transistors.
    After it cuts out can you turn it off and immediately back on (or after less than 6 seconds or so) and have it work again for a few seconds? If not, how long must it stay off before it will work again?
    That's all the ideas I have at the moment.
    • ugamazing
      Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
      by ugamazing
      I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
      We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
      12-17-2024, 07:05 PM
    • Stephen
      A2991 Logic Board issue, 20volts 0 amps help!
      by Stephen
      Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
      09-10-2025, 03:16 PM
    • Stephen
      A2991 logic board issue, 20volts 0 amps help!
      by Stephen
      09-10-2025, 03:15 PM
    • Stephen
      A1989 Logic Board Repair Issue. One CD3215 chip is the culprit
      by Stephen
      As the title states, got one CD3215 chip being a complete butthole to me. All readings on the other 3 chips read as follows
      5.16V .47amp
      5.16V .47amp
      5.16V .47amp
      5.16V .04amp (this guy is the issue) (U3200)
      So I went ahead and replaced the chip, (actually 3 times with 3 new CD3215 chips) all same issue, at first it wasn't reading at all then it finally started reading. I can rest assured is it not the CD3215 chip now but something else is causing this port to not fully read (god I wish the board would just turn on so we can just recover the data)
      11-27-2023, 03:57 PM
    • shahnld
      Lenovo legion 5 pro startup issue
      by shahnld
      Good day Experts
      I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
      A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
      And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
      08-24-2025, 12:31 PM
