Sony CFD-S01 ghetto blaster modifications
  • lti
    • May 2011
    • 2549
    I would like to modify the audio circuit of this piece of crap. In its current state, there is very little bass with the bass boost disabled and too much bass when the "Mega Bass" feature is enabled. It seems to be controlled using an IC, so it might not be possible to improve the circuit design.
    I also want to improve FM radio reception. The signal on every decent station except one is very weak. I can tolerate the sound through the built-in speakers, but when using headphones there is so much static that you can't hear anything. Strangely, plugging in headphones causes the signal to instantly weaken to the point that the stereo indicator turns off. Unplugging the headphones causes the signal to improve and the stereo indicator comes back on.
    Finally, the previous/next track buttons (also used to switch between radio presets) are broken. They have to be pressed in the correct location or nothing happens. The button caps have broken loose from the front panel.
  • lti
    • May 2011
    • 2549
    Re: Sony CFD-S01 ghetto blaster modifications
    I don't think I can fix the button. One of the tabs that attaches the button cap to the case has completely broken off.
    I also discovered that I can get slightly better sound by replacing the 1uF coupling caps on the output of the volume control IC. The datasheet for the chip (PT2257-S) recommends 10uF coupling caps. I found that 22uF caps would work even better, but I only have one of those. I don't want to use 47uF caps since that might put too much stress on the volume control IC and I don't want to fry it. The caps on the input don't seem to be as critical, even though they are 1uF as well. I will use 10uF caps on the output and 4.7uF caps on the input (if the leads are long enough - the 4.7uF caps are used).
    This thing runs just as well without an antenna. It doesn't have any more trouble picking up radio stations than it did with the antenna connected.
    There are also a ton of bad solder joints. I could solder surface mounted components better than Sony could, and I have a crappy "50W" soldering iron that cost $20 and may need a new tip.
    Finally, someone signed the main board and the front panel board.
    • lti
      • May 2011
      • 2549
      I replaced those coupling caps, but there still isn't much bass.
      • lti
        • May 2011
        • 2549
        There was another problem: the sound from the radio was distorted. I discovered that the coupling caps between the tuner and input selector IC had negative voltage across them! The voltage was positive when the boombox was first turned on, but it became negative after about half a second. I replaced these with nonpolarized caps and the sound improved.
        Now I will play a CD on this boombox and a properly working CD player to compare the sound quality. The lack of bass might be my crappy headphones.
        • lti
          • May 2011
          • 2549
          There is almost as much bass as a decent CD player. I may upgrade the coupling caps between the CD player and input selector, but I can't find the ripple current specs on the old FOAI CD110 1uF 50V caps. The datasheet on the Foai website does not load. I have two 4.7uF caps left, but I don't know what brand they are.
          • lti
            • May 2011
            • 2549
            It sure was nice talking to myself...
            Here are the details if anybody wants to do this:
            The capacitance of C115 and C215 need to be increased to a value between 10uF and 22uF. C163 and C263 need to be replaced with nonpolarized caps. I improved FM reception by resoldering JW231 and JW232. These are both soldered together and the FM antenna touches these jumpers to make the connection. Three of the four solder joints were cracked and the fourth must have been bad as well. None of the other caps need to be replaced, but I replaced C113 and C213 with 4.7uF caps as well. You can upgrade C162 and C262 as well (the CD player coupling caps), but it won't affect the sound very much.
            I didn't have any through hole nonpolarized caps with enough capacitance, so I used surface mounted caps and soldered them on the back of the board. The soldering looks bad on the bottom cap in the first image because both solder pads on the board were damaged. It was easy to lift pads on this board.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              No you're not. Just because no one is replying doesn't mean no one is reading your thread - this thread has 90 views so far .
              I'm guessing people aren't replying since no one has anything to add and most people probably don't consider a boombox like this to have enough value to justify in fixing/modifying it.
              I too have an old Sony boombox that I got for free many years ago. Problem with mine was bad power supply (linear transformer, open primary). The boombox wasn't really worth my time at all, but I ended up fixing it anyways just by adding a plug to it and connecting it to an external PSU. Works pretty good and has decent bass too. I was actually thinking about modifying it to accept computer input so I can use it as computer speakers.
              • Longbow
                • Jun 2011
                • 623
                Well, I believe you that the sound improved, but I also believe you have missed a possible circuit fault. If you found a polarized cap operating with reversed d.c. voltage, you have a big clue that something nearby is faulty. I'll bet that the waveforms around that capacitor will confirm something is operating at the wrong d.c. level and clipping your audio.
                Is it plugged in?
                • lti
                  • May 2011
                  • 2549
                  That might be a problem, but the tuner section is made up of tiny surface mounted parts. It looked like the negative side of those caps went directly into an IC in the tuner section (under the silver metal shield). The positive side was also connected directly to the input selector.
                  It might not have been worth messing with, but I wanted a working FM radio that I could connect headphones to. It wasn't very cheap when it was new and is only a couple years old. The sound became distorted after a few weeks and kept getting worse until I replaced those caps. There is now no distortion on stations with strong signals. It happened so quickly that any components that failed and caused the reversed voltage would have been defective from the factory.
                  • stretch0069
                    Screwed Up Super Moderator
                    • Oct 2003
                    • 2658
                    • oooo ess aaaaaaaaa
                    i have to agree.......
                    i like it when people just like to take something....anything....and make it better/different. Nothing wrong with that.
                    its a nice change in our throw-away world. keep on it!!
                    "Its all about the boom....."
                    Guns kill people like spoons made Rosie O'Donnell fat.
                    We now return you to your regularly scheduled drinking.
                    "Fear accompanies the possibility of death.....calm shepherds its certainty"
                    Originally posted by Topcat
                    AWD is just training wheels for RWD.
                    • lti
                      • May 2011
                      • 2549
                      There haven't been very many times when someone on this forum didn't want me to throw away the device I was trying to repair. I remember an amp from a set of computer speakers, a power supply, and an entire computer.
                      I didn't even post about the CRT TV I repaired by replacing a single cap. That thread would have been three pages of posts asking, "Why didn't you just throw it away and buy a new TV? They are only $150 new." The cap that was bad was a 100uF 35V. Those don't cost $150, and the old CRT has a better picture than any LCD TV within the $150 price range.
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        I never said anything about the power supply. But the computer speakers and the Compaq computer were more trouble than it's worth. I mean, you can go to your local radio shack and with $10 worth of parts and a couple days to spare you can build a better amp yourself... When you'll start doing this as a job, not only saving money for yourself but also earning money in the process, you'll learn that some devices aren't worth the time they would take to fix.
                        I gave away a computer of the same vintage as your Compaq for FREE. Just that mine was a Fujitsu and it was working perfectly. After a few years of being used as a router i replaced it with something slightly better because the slow CPU was bottlenecking my bandwidth.
                        Well, the guy who took it (who i knew from before, he did seem a little retarded, but i didn't know it was that bad), didn't like that the whole computer was full of dust and tobacco residue (it sat in the living room its whole router lifetime, and my mom smokes there). So he decided to clean it. He managed to mess up the proprietary PSU in the process... i'd rather kept the computer if i knew that would happen.
                        You are wrong here.
                        A working TV? How boring!
                        • lti
                          • May 2011
                          • 2549
                          You never said anything about a power supply. The power supply was used in a Dell computer that only had cutouts for the power plug and fan on the back of the case. I could have recapped it, but people kept arguing over which caps would work best as replacements and I was finally told that it would be best to replace it and modify the power supply cutout to make the new one fit. I don't know if the person that told me to replace it wanted me to recap the old one and keep it as a spare or just throw it away.
                          Radio Shack doesn't sell many parts, and the parts they do sell are expensive. The seven caps that needed replaced in the old amp cost $10. They only sell LM386 amplifier chips, and their cheapest transistors cost $1.49 each.
                          Yes, the Compaq sucks (I haven't seen a Compaq that worked properly), but it is still my only desktop computer and was only needed for old software.
                          Why are you always arguing with me?
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            [QUOTE=lti;175554]You never said anything about a power supply. The power supply was used in a Dell computer that only had cutouts for the power plug and fan on the back of the case. I could have recapped it, but people kept arguing over which caps would work best as replacements and I was finally told that it would be best to replace it and modify the power supply cutout to make the new one fit. I don't know if the person that told me to replace it wanted me to recap the old one and keep it as a spare or just throw it away.
                            I don't know the shack in your area was THAT bad. You could order online if that's the case. In my country there even aren't any Radio Shack stores, the brand did not carry till here... but in the stores that are here, you CAN find half-decent stuff at a half-decent price. You still have to order exotic parts, but for the basics they have you covered.
                            I have one that i got for free and worked fine. Has been sitting in my closet for the past few years tho.
                            I'm not.
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              I think Radio Shack is expensive everywhere (here too, at least). I spent quite a bit of money on parts (particularly LEDs) at Radio Shack when I was a kid. The white and blue LEDs were the biggest killers - $3.50 for a pack of two! I didn't eat lunch for like half a year in high school - and people wonder why I'm so thin . (I have a friend who did a whole year of no lunch so that he could buy a Radeon 9800 Pro ).
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                White and blue LEDs are expensive here too. But i'll order a 100pack from dealextreme for $12. That's funny about your friend - i have a Radeon 9800 Pro handling the display duties of the dual-PIII i am typing on right now... It's soon due to be replaced by a HD4670 (likely the last, and best available AGP card), but yeah, i paid someone top dollar for this particular model back in the day. It's a model with universal AGP (2 notches) - i needed that for it to work with my old BX board which only had AGP 2x.
                                • Carlos#2003%
                                  Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                  by Carlos#2003%
                                  Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                  02-15-2024, 07:52 PM
                                  RCA WHP141 wireless headphones wired up
                                  by momaka
                                  OK, this one dates back to 2015! I thought I had posted this, but realized I didn’t when I posted a picture of something else. So here it goes…
                                  Back in 2015, I bought a pair of RCA WHP141 wireless headphones at Micro Center for $2. I even mentioned it in the best cheap/free scores thread right here. Just forgot to follow up with that.
                                  As mentioned back then, these are (were) 900 MHz FM wireless headphones. No modern day Blutooth or anything like that. I knew they wouldn’t be great headphones or even that good… but the price was right! So let’s take...
                                  02-22-2023, 06:28 PM
                                • dkneyle
                                  Sony KDL-46HX850 Can't upgrade/update firmware
                                  by dkneyle
                                  Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                  Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                  09-25-2024, 10:44 PM
                                  Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                  This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  09-06-2024, 05:27 AM
                                  Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                  This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                  09-06-2024, 05:30 AM
