Magnavox MX931P Recieiver from 1995
  • itek
    • Aug 2010
    • 65
    Hi guys! I got in a Magnavox MX931P RO01 receiver here that has some channel issues. All inputs work, headphones out works fine, RIGHT channel on system A and B puts out very faint sound, LEFT channel on system A and B puts out NO sound. I have cleaned everything up as it was pretty dusty in there and I am still in the process of getting the boards out, will do more checking a post here when I do. Does this sound like a capacitor issue or something else? Thanks
  • itek
    • Aug 2010
    • 65
    Re: Magnavox MX931P Recieiver from 1995
    OK so I got the boards out, there is nothing on the bottom,, all caps ESR test OK except this little SMG 6800uf 25v which shows 0.04 ohms ESR which seems high? maybe not... I'm not sure where to go next, all speakers line solder points are good, the main unit is STK4192II if that helps, Thanks!
    • retiredcaps
      • Apr 2010
      • 9271
      I'm no receiver expert, but I have watched videos by
      http://www.youtube.com/user/mdzacharias
      and he is in the stereo repair business. From his videos, I'm guessing you have a blown output transistor?
      Anyway, check out his channel for ideas.
      --- begin sig file ---
      --- end sig file ---
      • itek
        • Aug 2010
        • 65
        I am having a hard time finding these transistors, the only thing on the heatsink is the STK4192II IC......
        PS Thanks for that video channel it is a great resource!
        • retiredcaps
          • Apr 2010
          • 9271
          ebay has some ...
          http://shop.ebay.com/i.html?_from=R4...All-Categories
          • itek
            • Aug 2010
            • 65
            OK there are 2 GBU4D bridge rectifiers inline with the outputs that are both blown (i have continuity both ways between ~/+, ~/- and ~/~), would this cause my issue or should I give up on this thing? Thanks
            • itek
              • Aug 2010
              • 65
              we posted at the same time! I don't know how to test that IC, need to do more reading.. gosh I have learned so much in the last month
              • Tube_Dude
                • Feb 2011
                • 51
                Have you measured the bridge rectifiers out of circuit? If not, that continuity come from the low resistance of the transformer secundary. If you had the rect. diodes shorted, your filter caps have gone BOOM long time ago...
                • itek
                  • Aug 2010
                  • 65
                  You are so right I tested them in circuit..... gosh I think i'm gonna give up on this thing, thanks guys!
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    I believe Magnavox is not mentioned in the same breath as Marantz, Arcam, NAD, etc in the audiophile circles so giving up on this one may be a good decision.
                    • Krankshaft
                      • Jan 2007
                      • 2328
                      I see this receiver is a Magnapox product . A great majority of amp issues can be traced to fault in the power supply, bad caps, or bad output transistors. Based on what you've done already I'd check the output ICs.
                      The Sanyo STK series of hybrid ICs are notorious for dying. Just ask guys who used to fix convergence issues in the CRT projection TV repair business.
                      To check them I'd power the unit up and hook up some audio to the input (like a steady sine wave tone from frequency generator on my PC) it's name escapes me at the moment but it's free. Then I'd use a scope and probe on the input of the STK IC if the signal is there I'd then probe on the output and expect to see a waveform with a higher amplitude.
                      Without a scope troubleshooting gets dodgy maybe build an LM386 audio amp on a breadboard and hook headphones to the output of the LM386 to check for the input signal.
                      • itek
                        • Aug 2010
                        • 65
                        wow thanks Krankshaft for the insight! Looks like I better buy a scope, any recommendations?
                        • itek
                          • Aug 2010
                          • 65
                          OK I got my Tektronix 465 and a couple probes today!!! Gonna check it out and post results soon
                          • Krankshaft
                            • Jan 2007
                            • 2328
                            A very nice scope. They weigh a ton but they're built like tanks and as time has shown they just don't die.
                            Proprietary ICs are kept to a minimum too unlike the Tektronix scopes from the 80s which are packed with large scale ICs that can't be found anymore.
                            Since the amp has isolation via it's transformer you can probe safely. But if you are ever working with unisolated devices connected directly to line voltage you'll need to plug the device under test into an isolation transformer to protect the scope.
                            • itek
                              • Aug 2010
                              • 65
                              Wow OK good to know! I'm still getting this thing figured out, not sure what the best settings for this scenario would be.. In the picture is the output side of the board, the only line that shows an effect from turning the volume knob I lined in red, the rest show the same result as the input side of the IC,, maybe I need to adjust the scope some more? Thanks again for your help
                              • TheLaw
                                • Jan 2011
                                • 477
                                Just wondering. Off topic. What's the wattage on this thing?
                                • itek
                                  • Aug 2010
                                  • 65
                                  well the STK4192II IC is rated 50w/chn @ 8 ohms minimum i believe
                                  • JunkForLess
                                    1973 Magnavox. One dead channel.
                                    by JunkForLess
                                    I am working on repairing a 1970s Magnavox stereo console. The Left channel works perfect, but the right channel is dead at the speaker. This happens in all modes (Tape, Phono, FM Stereo). Now, I do have audio from the right channel via the "Tape Record" output, so this confirms the problem is in the right channel AF and Output amp? I also tested the speaker itself. I attached a schematic of the Right channel: AF and Output.
                                    In addition to a recap, I found that R101 and R107 were both open (see arrows). I replaced R101 and R107, but they both become very hot....
                                    11-01-2021, 09:46 AM
                                  • eccerr0r
                                    old X58 triple channel board... memtest86 memory speed?
                                    by eccerr0r
                                    Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                    Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                    Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                    06-28-2025, 09:06 AM
                                  • LEECH666
                                    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                    by LEECH666
                                    Good day ladies and gentleman!
                                    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                    01-19-2024, 05:46 PM
                                  • spleenharvester
                                    Reverse engineering of 18650 4-channel tester
                                    by spleenharvester
                                    Hi friends
                                    I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                    05-04-2025, 02:43 AM
                                  • Christos Tsiligiannis
                                    Marian Trace Alpha sound card repair help
                                    by Christos Tsiligiannis
                                    Hello to the forum.
                                    My name is Christos, I am new to the forum here and i am posting from Greece.
                                    So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                    To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                    So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                    11-18-2024, 05:26 AM
