Teac Model 5 recap help
  • ChunkyBustout
    • Mar 2011
    Hello all,
    I am in the process of creating a shopping list of parts and wanted to know if there a standard as far as recapping different sections of a 1975 mixing board. I'm doing the Monitor/Master module first since it's needed more there. Then it's on to the power supply then input channels and last, the sub module. I know on a mixer's power supply, you can replace the caps with the largest capacity that will fit. For the signal path, I know this isn't as simple. Do I use the exact capacity I'm replacing or ...? I don't want to have to return inside the mixer to do more recapping because I didn't take care of it the first time.
    There are electrolytic, ceramic, mylar and polystyrene caps on the Monitor/Master module - any suggestions on exchanging one type for another to maximize improvements to the circuit?
    All suggestions, ideas and info regarding this would be very appreciated.
    Thanks,
    CB
  • TheLaw
    • Jan 2011
    • 477
    Re: Teac Model 5 recap help
    I'm no expert, but usually capacitor type should be left the same because different types of capacitors have different functions. Ceramics can do a lot of high-end filtering, while the electrolytics will be used for the bigger values that can't be achieved with polyester/polypropylene. If you were to replace different types of caps, I think a safe bet would be to replace electrolytic with film, try finding a 470uF film cap....oh wait, that would be the size of my car.
    For brands to pick out.
    Don't be stupid and buy those overpriced "audiophile" crap. It's a bunch of bologna. You won't hear the difference, and please don't convince yourself you will. However, there's no hurt in getting good quality components. Just don't go over the top.
    Electrolytic: Panasonic FM/FC
    Film: WIMA/Panasonic
    Ceramic: Vishay/Whatever you can get
    Signal path, you want low ESR and just replace value for value. Someone of more intelligence can tell you what you can/cannot do in signal path.
    Power supply wise: Get capacitors with the highest ripple current rating you can find. This means how well it can handle dirty unfiltered power. Make sure they are rated for 105C and low ESR really never hurts. I don't know exactly the make up of the supply but that will guarantee prolonged life.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      1975... this is likely to have a linear power supply. Yes you can (and it is recommended to) replace the main filter capacitors (the ones after the rectifying bridge) with the largest values you can fit.
      For the caps after the regulators just replace with the same value, the regs might oscillate with other values. Same goes for signal path. Replace ceramics with poly where possible as poly caps have tighter tolerances.
      A working TV? How boring!
      • TheLaw
        • Jan 2011
        • 477
        Polys supposedly sound better as well. Ceramics have poor electrical characteristics.
        However, sometimes Ceramics are used for high-frequency filtering.
        (How are poly's for high-frequency filtering?)
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          Since there is no switching supply there is no need for high frequency filtering. I'm using poly for a filter capacitor in a class D amplifier (quite a demanding application and usually the job for ceramics), and they do just fine.
          • TheLaw
            • Jan 2011
            • 477
            I'm not talking about the power supply, rather any other IC that might be in there.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              Not sure what a high frequency IC would be doing in there. LED VU meters (the only thing i can see a digital IC used for in a mixer) weren't common in 1975.
              • TheLaw
                • Jan 2011
                • 477
                Yeah not sure what would be under the hood....
                  no-name Radeon 9600 XT recap and cooler
                  by momaka
                  I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                  This one was actually suggested to me by ChaosLegionnaire....
                  11-06-2020, 07:54 PM
                • chth96
                  Is it no harm to replace with capacitor without ripple current rating?
                  by chth96
                  When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                  Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                  But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                  Rubycon YK DataSheet (b...
                  04-19-2024, 05:19 AM
                • RetroComputingGrotto
                  Opinions/Advice on Do/Should I replace ALL Electrolytic Capacitors on old equipment?
                  by RetroComputingGrotto
                  I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
                  As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
                  What is your advice/opinion on whether or not on old(er)...
                  04-03-2024, 08:30 AM
                • chth96
                  Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                  by chth96
                  I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                  Since then, This AC/DC adaptor have been out of order.
                  But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                  After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                  And Is there any possibility that it will suddenly explode as well as to be out...
                  12-03-2023, 04:40 AM
                • varunviolin007
                  Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                  by varunviolin007
                  Hi guys,
                  I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                  I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                  Looking for someone experienced with older PC boards who uses...
                  07-29-2025, 11:53 PM
