So this weekend I decided it was time to blow the dust out of some of my equipment. I have a Klipsch Promedia DD-5.1 digital decoder preamp box that I use for input switching. It's been running really hot as of late, so I figure it must have some dust it in. I crack open the case, and there's no dust to be found. What there is however, is a case full of GSC caps. None are blown, but that can't be good.
I have no idea what the original grade of caps were, as I can't find any series markings. I've read in several places that Panasonic FC is "not bad" for audio. So I went with those. Recapping it was actually quite tricky. The board was thick with lots of copper, and cheap solder mask that flakes off way too easily.
It's now full of FC and back up and running. I think it sounds much clearer now, but that could just be in my head. Or maybe not. I measured some of the GSC caps that I removed and ESR was all over the place. The 25V 10uF caps that were in line with the signal path ranged from 1.5 - 36 ohms ESR! yikes. Would these be filter caps? I'm not used to working with audio stuff. Even the larger caps in the power circuitry showed similar variation in ESR.
So, while I'm not 100% sure the FC ratings are as good as the GSC ratings, the FC installed was drastically better than the GSC removed in every case. It was working fine even with the questionable GSC, so it's definitely an improvement. I'll keep an eye on the FC going forward.
I ordered some heatsinks for the power mosfets, as there was some discoloration on the board. If anybody is curious, I can post photos of the repair when those come in and I crack it open again to install the heatsinks.
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
