Onkyo NR609 usual Dolby/DTS DSP failure
  • tony359
    • Oct 2018
    • 259
    • United Kingdom
    I have a TX-NR609 which shows the usual issue with the DSP on the HDMI board.
    How do I know? I managed to revive it with heat. Then it failed again. I reballed it, it lasted 3 months then failed again for good.
    I ordered one from China - not knowing that
    1. It's likely fake
    2. It's likely pulled from another broken machine
    3. There is a revised version which does not fail, which was never sold outside of OEMs so unlikely to be found online
    I installed it and it didn't work.
    The bottom line is that I have this nice amplifier which works besides that IC. I don't want to throw it away but I don't know where to find the replacement IC or board. I could try China again - and maybe this time not wait 6 months before installing it so I could ask for a refund?
    I read a thread on a forum where someone with great experience on the subject said that the only way is to find a replacement HDMI board with the latest DSP version on it. I am unable to find it.
    Any ideas? I'd hate to throw it away even though it's not worth much.
    Thanks!
    Tony
  • yajdeeks
    • Jan 2019
    • 6
    • Poland
    Re: Onkyo NR609 usual Dolby/DTS DSP failure
    Try flashing nand with firmware dump... it's sometimes broken
    • tony359
      • Oct 2018
      • 259
      • United Kingdom
      oh yes, I was supposed to try that - do you know where I could find the firmware?
      I believe on another forum there was a note about connecting via serial and see if the IC is trying to boot
        • 31013
        the dsp from china was probably blank if it was new.
        programmable parts get programmed AFTER soldering - more reliable that way!
        • tony359
          • Oct 2018
          • 259
          • United Kingdom
          Maybe. But I am also told that those ICs were never sold outside of OEMs so all China ones are fake/broken. And if not mistaken the EEPROM is on the PCB? The DSP is more or less a CPU which boots from the ROM. But I might be saying rubbish here.
          Still, I can try to give it a go. Do you happen to have a pointer on where to find more info about that?
          Meanwhile, I have another Onkyo I THOUGHT was working but no, never passes audio when cold, needs 5 minutes and a power cycle to work.
          Sigh, another useless heavy brick. This is a powerful one, 250W per channel.
            • 31013
            do you have the dsp part number?
            remember everything is made in china - they have access to a lot of parts
            • tony359
              • Oct 2018
              • 259
              • United Kingdom
              D830K013BZKB300
              The other one I have has a different variant, D830K011A which likely means is even earlier than the B.
              Apparently the "D" version is the good one which does not fail. Sigh!
              Good point about those parts being manufactured in China, who knows someone might have found a tray forgotten somewhere.
              I'd like to try to access the serial port of the 3007 - the bit 250W I realised today that also failed. I mean the DSP serial port - it's an ARM processor apparently.
              I think I'mm wasting my time though.
              Edit: apparently the recall was for revisions B and C, not for A. But expert TJmotter said those ICs fail around 18K hours and my 3007 has 19K hours. Still, it behaves differently. It always powers up ok after a few minutes, it just needs a power cycle, so maybe I'll check the supply - and the serial port.
              The bottom line is: I have two of these bricks which I'd like not to throw away or harvest for parts. I really hate thinking they work, they just need ONE IC but it's unobtainable...
                • 31013
                i see they didnt label the SWIM interface - no surprise there.
                they dont want anybody connecting a serial jtag adapter to it and reading the silicon i.d.
                • tony359
                  • Oct 2018
                  • 259
                  • United Kingdom
                  there are other pages about that IC, maybe it's somewhere else?
                    • 31013
                    maybe
                    it's probably not a custom part, but it's got a custom number printed on it.
                    • tony359
                      • Oct 2018
                      • 259
                      • United Kingdom
                      now I've realised that my own Onkyo pre-amp I use in my Home Theatre has the same DSP! It's got a heatsink on it but it's a ticking bomb!
                      I can't believe there is no reliable source of those ICs to fix those AVRs. So much working parts that can't be re-used because of one IC!
                        • 31013
                        these motherfuckers!
                        https://e2e.ti.com/support/processor...ent-equivalent
                        https://www.ti.com/product/TMS320C6747
                        • tony359
                          • Oct 2018
                          • 259
                          • United Kingdom
                          out of curiosity I managed to connect to the IC via RS232.
                          If I spray it with cold gas it fails to boot or hangs during boot.
                          What's weird is that it just needs 60 seconds to warm up, then it ALWAYS boot.
                          My previous cases were more digital: either they'd work or they'd not.
                          All I can do is to reball it (it's an A revision which in theory is not in the list of affected chips) but I don't think it's the problem as it really takes a tiny amount of gas to stop it and if I mechanically tinker with it I don't see any effects.
                          Code:
                          U-Boot 1.3.3-svn (Apr 27 2009 - 18:14:10)
                          DRAM: 64 MB
                          NAND: NAND Manufacturer id: 20
                          NAND Device id: 75
                          NAND device: Manufacturer ID: 0x20, Chip ID: 0x75 (ST Micro NAND 32MiB 3,3V 8-bit)
                          Bad block table found at page 65504, version 0x01
                          Bad block table found at page 65472, version 0x01
                          nand_read_bbt: Bad block at 0x00890000
                          nand_read_bbt: Bad block at 0x008b0000
                          nand_read_bbt: Bad block at 0x016d4000
                          32 MiB
                          In:  serial
                          Out:  serial
                          Err:  serial
                          Hit any key to stop autoboot: 0
                          Loading from NAND 32MiB 3,3V 8-bit, offset 0x254000
                            Image Name:  Linux-2.6.18_pro500
                            Image Type:  ARM Linux Kernel Image (uncompressed)
                            Data Size:  806112 Bytes = 787.2 kB
                            Load Address: c0008000
                            Entry Point: c0008000
                          Automatic boot of image at addr 0xc0200000 ...
                          ## Booting kernel from Legacy Image at c0200000 ...
                            Loading Kernel Image ... OK
                          OK
                          Starting kernel ...
                          Uncompressing Linux......................................................... done, booting the kernel.
                          init started: BusyBox v1.12.1 (2009-05-25 17:54:13 JST)
                          starting pid 155, tty '/dev/console': '/etc/init.d/rcS'
                          /dev/mtdblock9
                          starting pid 188, tty '/dev/console': '/etc/init.d/rc 3'
                          starting pid 190, tty '/dev/console': '/sbin/getty console'
                          starting pid 191, tty '/dev/console': '/opt/onkyo/avr/bin/netapp '
                          starting pid 192, tty '/dev/console': '/opt/onkyo/avr/bin/spid '
                          Start SPI DAEMON Compiled Date[DATA:Sep 10 2010, TIME:09:51:50]
                          MontaVista(R) Linux(R) Professional Edition 5.0.0 (0802607)
                          (none) login: Start Netapp Compiled Date[DATA:Sep 10 2010, TIME:09:52:08]
                          DSPDEC Version:09710A
                          DSPDEC ID:!!9071
                          [TimerInitialSeq] called
                          [TimerInitialSeq (system_timer.cpp 259)] Send STAT commmand
                          [avr_system_set_ringio_status] status=0
                          [SpiService::RawDataCallback] send selector info to audioapp
                          [SpiService::SendToAudioApp] Sync OK
                          DSPPOST Version:09723A
                          DSPPOST ID:H20000
                          DSPPOST Revision:1.03
                          DSPMEQ Version:09914A
                          DSPMEQ ID:H30000
                          DSPMEQ Revision:1.05
                          C_CPLD_PCMDIRECRT_DSP
                          Start message loop
                          [TimerInitialSeq (system_timer.cpp 278)] Mount User Area
                          [mount_user_area (system_timer.cpp 53)] try to mount user area
                          [TimerInitialSeq (system_timer.cpp 289)] Send PROD commmand
                          [SetProductInfo (system_timer.cpp 94)] Product ID = AVR0001
                          [SetProductInfo (system_timer.cpp 96)] Brand Name = ONK
                          [SetProductInfo (system_timer.cpp 98)] Destination = XX
                          [SetProductInfo (system_timer.cpp 100)] Product Name = TX-NR3007
                          [SetProductInfo (system_timer.cpp 104)] Friendly Name = TX-NR3007
                          [SetProductInfo (system_timer.cpp 122)] Software Version = 10706AH
                          [TimerInitialSeq (system_timer.cpp 325)] Send DLNG commmand
                          ----> 36 Message resources
                          ****** LangPropertyFileMap ****** TX-NR3007
                          ****** LangPropertyFileMap construct OK ******
                          ****** Language setting = ENG ===> /opt/onkyo/avr/etc/pfsInfo/netapp_mongon_eng.properties
                          *** MessageID Duplicate (272)RH_LIST_TEXT_PLAYLISTS
                          ----> 407 Message resources
                          [TimerInitialSeq (system_timer.cpp 342)] Call PostInitCallback
                          [NetApp::OnInit] called
                          [CoreApp::EnableEthernet] error=No such file or directory
                          [CoreApp::EnableEthernet] start eth0
                          [NetApp::OnSelectorEvent] called, zone=0, selector=4, setupflat=0
                          [NetApp::OnSelectorEvent] called, zone=4, selector=5, setupflat=0
                          [CoreApp::EnableEthernet] start lo
                          [NetApp::OnInit] Try to Register PREPRO Module
                          [NetApp::OnInit] Registered PREPRO Module
                          [NetApp::OnInit] Try to Register UPDATE Module
                          [NetApp::OnInit] Registered UPDATE Module
                          [~priority_saver()] set prio = 10
                          [NetApp::OnInit] Try to Register ISCP Module
                          firmware version is not exist
                          /opt/onkyo/avr/bin/AmxBcast -e eth0 -b ONKYO -p TX-NR3007 -v 0.0...0 -c 60128
                          [NetApp::OnInit] Registered ISCP Module
                          Successfully bound in file /tmp/ISCP_CONTROL_SOCK.
                          listen ok
                          ecn server thread start port = 60128
                          Successfully bound in PORT 60128.
                          listen ok
                          thread Ecn listen ok.
                          [NetApp::OnInit] Try to Register IRadio Module
                          [NetApp::OnInit] Registered IRadio Module
                          [NetApp::OnInit] Try to Register USB Module
                          Starting the hotplug events dispatcher: udevd.
                          Synthesizing the initial hotplug events...done.
                          Waiting for /dev to be fully populated...done.
                          [NetApp::OnInit] Registered USB Module
                          PROC_setup () failed. Status = [0x8000801c]
                          • nobbnobb1
                            • Nov 2019
                            • 76
                            I didn't know people go through the effort of reballing! Since I don't have the tools or skill, I've just been doing the heatgun trick. I shield the chip surroundings with some tinfoil and blast the heatgun until I measure 200C on the chip. I then let it cool slowly and naturally, then stick on a heatsink to the chip. I also modified the onboard fan to run all the time (there's a spare connector somewhere that puts out a constant 12V). Has seemed to holdup for the last year so far.
                            I've also done this to fix a Toshiba plasma TV and it's held up for >4 years so far. So maybe the trick is to keep the chip from too many extreme thermal stresses by having a fan over it.
                            • tony359
                              • Oct 2018
                              • 259
                              • United Kingdom
                              @nobbnobb1
                              The issue with this IC was acknowledged by TI, the manufacturer. Heating it up only fixes it temporarily. There is a newer revision available which should not fail but it was never made available to the public.
                              • tony359
                                • Oct 2018
                                • 259
                                • United Kingdom
                                I forgot I discussed my issue with the Onkyo 3007 on this forum.
                                I made a video "repair" of this unit where I try to explain what happens from all the info I got from various sources - which are all mentioned of course
                                I post it here for future reference - it's so sad that those beasts cannot be recovered because of one tiny IC...
                                • tony359
                                  • Oct 2018
                                  • 259
                                  • United Kingdom
                                  I was forwarded the Texas Instruments bulletin which confirms that only B and C DSP ICs were deemed as faulty - the "A" you see in the 3007 video above is likely to have a long life after the reball! Fingers crossed!
                                  I cannot find this bulletin online anymore so I thought I'd share it here.
                                  • madan1
                                    • Nov 2016
                                    • 682
                                    • Bulgaria
                                    You should have checked here https://www.badcaps.net/forum/troubl...50#post1131150 post#40
                                    By the way, nice video, it will be interesting to know what will happen to the IC.
                                    • Sus256
                                      HISENSE 65E7KQ PRO - no boot
                                      by Sus256
                                      Hi all!
                                      HISENSE 65E7KQ PRO
                                      RSAG7.820.13512 - chassis
                                      MT9618BAATAB - cpu
                                      RSAG7.820.12059 - power
                                      HD650Y3U77 - panel
                                      KLM8G1GETF - emmc
                                      The TV does not turn on, the standby indicator is on. All voltages are present.
                                      Emms is dead. Not readable, not detected.
                                      Replaced emmc.
                                      But with another dump there is no launch
                                      Terminal log
                                      UART
                                      AC_ON
                                      RPMB key is not yet programmed
                                      HASH1_VERSION=0x00000000 64bit
                                      E-B
                                      FDE enabled
                                      layout pattern onebin by SAR7,0...
                                      06-01-2025, 02:11 AM
                                    • howardc64
                                      by howardc64
                                      07-24-2025, 05:17 PM
                                    • FrancescoV
                                      Onkyo HT-R390 no sound output, video output ok
                                      by FrancescoV
                                      Good morning everyone,
                                      I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                      The firmware reported is the following:
                                      M:1.00/11107BLP
                                      D:?.??/????????
                                      O:1.00/11107AL
                                      The DSP firmware given the question marks seems corrupt.
                                      On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                      05-11-2025, 02:59 AM
                                    • ctroxtell
                                      Carrier HK50AA063 display controller common failure help
                                      by ctroxtell
                                      I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
                                      02-05-2025, 05:31 PM
                                    • howardc64
                                      Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                      by howardc64
                                      Problem
                                      Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                      Model & Board Pics
                                      Conflicting Spec
                                      Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                      https://www.shopjimmy.com/vizio-gj-2k1...
                                      10-10-2024, 01:16 PM
