Headphone wires.... confused!
  • budwich
    • Jul 2015
    • 3097
    I picked up a "beat up" set of sennheiser headphones (hd201). The phono plug end seemed to have an issue such that most of the time only one ear would work but by compressing / bending the jacket of the phono plug, I could cause the other ear to work. Must be a phono jack (3 pin) problem. So I cut it off and have solder based replacement. BUT... the wiring seems "mysterious" to me. I can't see how this can work or even ever worked. Attached is a picture of the wires (less the phono plug). One sheath has what I believe is two enameled wires while the other has basically copper... just one "wire". One sheath goes to one ear and the other goes to the other ear. How can this work??? I don't believe there is any wiring leaving the ear pieces and traveling thru the head band as the ear piece holders / frame are basically solid plastic.
    How does a "wire pair" ever get "completed" at each ear piece?
    • 31028
    Re: Headphone wires.... confused!
    red is one side, green is the other and uncoloured is common.
    are you sure the red isnt just twisted with another uncoloured one?
    • budwich
      • Jul 2015
      • 3097
      the one sheath going to the one ear has the two colored wires. The other sheath has what looks like bare copper / uncolored. The is no wiring leaving the ear pieces (going from one side to the other). I looked at the "single uncolored" sheath. There is only uncolored copper and "hair strands" of some sort of "cording" which in large cable, I think, could be use to strip other side sheath ... at least that's what I have seen it used for. There is no second conductor that I can see in that sheath, which I have cut back at least 5 inch already looking a second conductor. I have to pull the ear pieces apart to see what's up... but it still seem kind of strange that the two colored conductors are in the same sheath and going to one ear piece.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        I've seen some stereo headphone cable use two pairs of lacquer coated wires, one pair going to each earpiece...
          • 31028
          is the bit between the ear sections metal by any chance?
          • budwich
            • Jul 2015
            • 3097
            that would be too easy. attached is a picture of the speaker assembly from the side that has the two colored wires in the one sheath going into. Note there is no contacts out of the "box" going into the ear "body" so I don't think there is any was to get electricity flowing unless its travel thru my ears from one side to the other.... :-)
            • lotas
              • Jan 2016
              • 4602
              • Russia
              Remove the insulation a little further, most likely you cut it or it was broken.
              https://audiorepair.ru/product/provo...02-hd201-hd206
              • budwich
                • Jul 2015
                • 3097
                there is no wires in the removed insulation. I didn't do 4 inches in one cut... I did about 3/4 inch at a time. I am going to crack open the speaker module, hopefully without wrecking to see how those wires are physically terminated inside the housing. Then, maybe the mystery will be solved.
                • lotas
                  • Jan 2016
                  • 4602
                  • Russia
                  https://www.youtube.com/watch?v=NOc3aYNq10o
                  • budwich
                    • Jul 2015
                    • 3097
                    AH... you were right. I took a larger "strip" about 1.5 inches and was more careful and indeed there is two wires in both sheaths. The thin "ground" wires were being stripped away by the stripper and being so fine were lost inside the removed insulation.
                    thanks.... mystery solved... poor technique and poor eyes. :-)
                    • Dannyx
                      Wire twisting tool for small wires - ideas ?
                      by Dannyx
                      Good day folks. Recently, I started doing more and more alarm system installs which involve dealing with a ton of small wires which are part of 4 to 12 core alarm cable. To make my installs as clean and neat as possible, I twist together the individual wires whenever possible to make braids like in the picture. It takes a lot of time and wears on my fingers really quickly, to the point where I actually developed a blister on my index finger from all the twisting. This got me thinking if there's a tool designed to braid small wires like this. I know there is something for twisting together solid...
                      08-23-2020, 06:29 AM
                    • DanielCoffey
                      Bosch GRA53 36V Lawnmower - no motor
                      by DanielCoffey
                      Hi folks. I have a Bosch GRA53 36V lawnmower that has developed a fault and will not spin the blade.
                      I should say for the purposes of guiding what how you can explain things to me that that I have only modest knowledge of electronics, own a basic multimeter and soldering iron.
                      The mower is four years old, out of warranty, discontinued and the brand has been sold to Honda who have iterated on the design a couple of times and now sell their own 36V mower. My mower was effectively a prototype when Bosch tried the 36V Bosch Professional range of garden equipment which...
                      08-06-2023, 12:40 PM
                    • ChaosLegionnaire
                      correct way to connect bare speaker wires into spring clip terminals?
                      by ChaosLegionnaire
                      i recently bought a logitech z607 surround system. however, its giving me grief. when i first connected it, it only had sound coming from the front right speaker. after a great deal of fiddling and reseating the speaker wires into the spring clip terminals, i finally had sound coming from all 5 satellite speakers.
                      however, the sound still gets cut off intermittently if i move the speakers, subwoofer or move/touch the speaker wires on the back of the subwoofer. so i wanna ask what is the right way to connect bare speaker wires into spring clip terminals?
                      i googled...
                      10-27-2022, 06:19 AM
                    • artvandalai
                      Advice on rewiring this stepup transformer?
                      by artvandalai
                      I bought this Chinese made step up transformer to run some 220v appliances. Some of the wires were brittle and broke off. I attempted to improve some of the wiring with spade terminals and heatshrink tubing as the wires were just soldered straight to the connectors. Any advice on how to rewire the broken wires on this step up transformer? I'm unsure how to go about rewiring this to a better safe working condition.
                      01-14-2025, 01:00 AM
                    • gabri2211
                      I'm looking for the wiring diagram for led monitor model DHI-LM19-L200
                      by gabri2211
                      hello everyone, I'm looking for the wiring diagram of this led monitor.
                      the model is DHI-LM19-L200, but I think that any other diagram of a DAHUA monitor could be equivalent.
                      I really hope that among you someone can help me to repair this monitor, the screen is black, it doesn't seem like a backlight problem.
                      I see the presence of 12 volts, 5 volts, but without a diagram the repair is very difficult.
                      thanks to those who will answer
                      12-10-2024, 04:37 PM
