Sony CDP-CX355 Table Error on led readout
  • mecha1166
    • 37
    I have a CDP-CX355 with Table Error. Anyone know what this is. I am opening it to check belts. I know position switch on bottom of CD holder "donut" goes bad or breaks on some of these models.
  • mecha1166
    • 37
    Re: Sony CDP-CX355 Table Error on led readout
    Drive belt in back of unit has stretched. We used to use Sony or PRB belts. Anyon know where to buy belts now days?
    • mecha1166
      • 37
      Found a set of generics on eBay. $6.20 delivered.
      • AK_777
        Sony KD-65A1 Repair – 4 Red Blinks Error
        by AK_777
        Hi everyone!
        I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
        Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
        02-20-2025, 04:15 PM
      • Sus256
        HISENSE 65E7KQ PRO - no boot
        by Sus256
        Hi all!
        HISENSE 65E7KQ PRO
        RSAG7.820.13512 - chassis
        MT9618BAATAB - cpu
        RSAG7.820.12059 - power
        HD650Y3U77 - panel
        KLM8G1GETF - emmc
        Replaced emmc.
        Terminal log
        UART
        AC_ON
        E-B
        FDE enabled
        06-01-2025, 02:11 AM
      • GoodCapDude
        Sony XBR-75X940E intermittent 6 blinks error code
        by GoodCapDude
        Hi everyone. First post on Badcaps!
        I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
        09-20-2025, 06:07 AM
      • goodpsusearch
        Sony RCD-W3 Deck A (Playback only) not playing CDs (Disk Error) repair
        by goodpsusearch
        Recently I was given for free a Sony RCD-W3 with the following symptoms, CD recorder drive reads CDs without any issues (haven't tested recording function yet because I don't intend to burn CDs on that machine) but the reader drive shows disc error after some seconds of it trying to read CD. Tried both CD-Rs and commercial audio CDs with same results.
        First thing to do was to clean the lens but that didn't change anything. Googling the issue revealed that this is a common issue on several Sony CD recorder machines and the culprit is SMD electrolytic caps located on the PCB bellow...
        05-05-2024, 02:04 PM
      • cheeky2
        Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
        by cheeky2
        For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
        See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
        01-08-2024, 05:56 AM
