PSU Board repair or replacement Ecler Nuo 2.0 DJ mixer
  • eum
    • Sep 2021
    • 8
    • France
    I try to repair this fly-back type PSU, I diagnosed (identifiable) dead N-MOS and fuse, but there are 3 smd resistors on the bottom that burned and became unreadable.
    The support in charge of the brand in France managed to get me the schematics from Ecler, but it didn't include the PSU board. After a while they finally told me that the unit was too old so they don't have the PSU board schems.
    I can find replacement PSU board online, but only for the Nuo 3 or 4 or 5, and it seems they ar compatible with each other, as I often find boards compatible with these 3 Nuos.
    Funnily, Ecler won't share the service manuals for the newer models either.
    My board version is : 11.0864.04, and it has what looks like 2 bipolar outputs.
    Each one having a black, yellow and brown cables, and 2 470μF output Rubycon electrolytics, rated for 35V, so maybe for ±18 or 15V outputs.
    If someone can send me a readable pic of the bottom of the PSU PCB I may manage to fix it. But maybe there is conception error hat makes it useless to repair, just to see it fail again a while later.. But, according to the SM, just on the Nuo 2.0 mainboard there have been several revisions, so it may be also true for the power board...
    Does anyone know or can measure the output voltages of the PSU for Nuo 2.0, 3, 4 or 5 ?
    Thanks,
    Eum
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: PSU Board repair or replacement Ecler Nuo 2.0 DJ mixer
    look up whatever burned the resistors and see if there is a suggested circuit for it ..
    • eum
      • Sep 2021
      • 8
      • France
      There is a MOS driver for fly-back application (UC3842BDG).
      I had downloaded its datasheet, but was not convinced I could find like that.
      You gave me the punch to go look deeper in it, thanks !
      It seems those are 3 paralleled resistors between the switching N-MOS and ground.
      I guess they put 3 to dissipate heat more easily with basic CMS.
      It's supposed to be 0.5Ohm, based on the Figure 35, "27W Off-line flyback regulator", page 16 of On Semi's datasheet.
      There is an additional Zener on the PCB that I don't see in datasheet's applications, where it's always between pins 8 and 10 (SOIC14 version, here), unlike in my case.
      Well, maybe I'll try to find a 4W (roughly), 0.5Ohm and also replace the dead Mosfet to see what happens..
      But again, if anyone has one of those machines, and would be kind enough to go look / probe inside, It'd be good too
      • eum
        • Sep 2021
        • 8
        • France
        Little update.
        I tried like I said, with 0.5 Ω sensor Resistor, and it didn't start. It didn't burn either though.
        I'll dig deeper, maybe I can find a PSU calculator using this chip, or an application note.with more precise data.
        • eum
          • Sep 2021
          • 8
          • France
          I finally found a work around : add two 18V 40W PSUs in series. The only prerequisite is that the selected PSUs are not ground referenced, otherwise, it would put one output to ground and not work.
          I found that those XP Power Model FCS40US18 could be fixed using the old screw holes. 2 of the 4 for each of these smaller boards, in diagonal, but it was a few mm farther so I had to pinch the edge of the board between washers. I added spacers to the remaining holes so that it won't bend too easily.
          Lastly, each of these PSUs is rated at max. 1.2A input, so the smaller 0.5A fuse needs to be replaced, I had 2.5A to hand, that should be good.
          Now it starts ok, but it outputs a low frequency, when the faders levels are at their minimum ! Maybe a grounding issue or something .. (?)
          • eum
            eum commented
            Editing a comment
            Definitely mains irradiating the circuits board, I tried to shield the PSUs in a DIY manner, but it wasn't effective.
          • eum
            eum commented
            Editing a comment
            It seems the mixer cant operate powered by +/-15V instead of the original +/-18V.
            If so there are several power supplies available, of which some are shielded.
            I'll do some tests and update soon.
        • dragos.gogan22
          • Mar 2024
          • Romania
          The power supply of my NUO 4.0 died as well after someone spilled a drink on the mixer. I don’t know exactly if the values are matching, I hope so tho. I know the values of the SMD caps as well, except for the 2 black ones, if you were searching for those too.
          I tried repairing the unit, but since I didn’t know the values of those 2 caps and I found a website that is selling a newer 2017/2018 version of the power supply, instead of this one, I purchased one new. I’m going to put the mixer back together soon.
          It might work with the 2.0 too, so if you need the website, here it is. You can ask them if they have it in stock and if it works for the 2.0, here’s the link: https://www.music-center-shop.com/fr...400-neuve.html
          Hope this helps!
          • eum
            • Sep 2021
            • 8
            • France
            I actually found a complete mixer with working PSU for less than the price than the new version you shared. (I could fix the mixers' output board quite easily, but otherwise it would have made me a good PSU source.)
            It seems there have been plenty sub-versions of those PSUs.
            What black SMD caps are you talking about ?
            (The little squares you show on your picture are in fact resistors, and the number on it codes for the resistance in Ohms : 1211<>121x10¹=1210Ω, 4753<>475x10³=475000=475kΩ.)
            I've recently heard that mains film capacitors (X2, Y2,..) can fail too !
            It seems they are often undersized...
            I measured the capacitance of those on my dead Ecler PSUs boards, and they were really bad.
            I'll update when I test with more robust parts (a bit more capacitance and voltage rating : 275>350VAC and 150>220nF).
            The previous PSUs on the 2 Nuo 2.0 (and others from the same era) I opened, all had 2 ±18V outputs (symetric). If you can measure on the external pins +18 and -18VDC using the center pin as ground on your newer version, we can conclude they are compatible, and probably better versions.
            Finally, I could start one of those Ecler mixers with a standard +/-15V PSU, but I still have to test it in real conditions.
            • eum
              • Sep 2021
              • 8
              • France
              I think you should check that your mainboard isn't short-circuit to prevent killing your brand new somewhat expensive PSU.
              You can measure the resistance between the pins on each power connector.
              Each has 3 pins with the ground in the middle.
              If any combination of 2 pins display 0.0Ω for more than a few seconds, it means it is shorted and you have to fix the mainboard first before applying power again.
              Hope this helps,
              Good luck
              • deetee4252
                • Jul 2024
                Hope this helps!
                I registered just so I could say thank you for posting that link! My Nuo 5 went POP! yesterday.
                • boosti45
                  Macbook pro logic board replacement parts quesion
                  by boosti45
                  i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                  08-21-2024, 05:23 AM
                • tuner2000i
                  Philips 65PUS8518/12 distorted image after main board replacement
                  by tuner2000i
                  hello everyone,
                  I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                  The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                  07-15-2025, 01:15 PM
                • Cvrado
                  Led TV Board Replacement, same part number and model, different size
                  by Cvrado
                  Hello my friends!
                  I have a question that I think you can answer and help me with!
                  I have a faulty main board from an led TV. And I found the same part number board and design but is from a 43" TV and I want to use it on a 65". On its stickers , all are the same except the wattage for the LEDs backlight, both state different watts and LED Voltages!
                  So I presume that the backlight inverter section from the replacement board has lower wattage then the original one, am I right?
                  My concern is that the board won't draw enough voltage to the bac...
                  03-02-2024, 05:05 PM
                • Hakuu
                  by Hakuu
                  Hi There,
                  More Details
                  TV Model - LG OLED77G1PUA
                  07-12-2023, 02:37 PM
