Dead Roland AX synth - Capacitor problem?
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    Got a question regarding how best to identify what the problem is on the main pcb of this Roland synth.
    Symptoms are, that it turns only for a second... All the lights and display flash, then it turns off.
    I had thought it could be a shorted cap so removed the main pcb and tested all the caps for a short to ground using a resistence tester, however none were.
    Next I pulled out the Chinese T7 component tester and found 7 caps which are connected in parallel, all reading 36pF (when these caps are rated between 470 and 10uF). None of the other caps on the board measure less than 10uF.
    The caps are all the aluminium can smd type, but my question is why am I getting these readings?
    Obviously, if one cap in a parallel setup is shorted, then they will all read as shorted, however I'm not getting a 'shorted' reading in ohms and actually, the T7 always reads around 36pF if the 'Test' button is pushed with no device connected, so if it was only on one cap, that cap could be open.
    Some pictures below.
    The four together in the second pic are included in the seven.
    The owner had wanted to just replace the board, but none are easily found online.
    Obviously, I could just recap it, but I want to understand why I'm getting these readings, and whether the symptoms are even typical of bad caps?
    • 31260
    Re: Dead Roland AX synth - Capacitor problem?
    calibrate your tester - short the 3 terminals and turn it on
    you cant test caps in-circuit, people who say you can are full of shit.
    maybe 30-40 years ago, but not on modern stuff.
    the tester is effected by other parts - it has a high enough voltage to turn transistors and diodes on!
    • Crystaleyes
      • Sep 2021
      • 493
      • Brazil
      Hi fella.
      The tester was calibrated a couple of days ago but can do it again.
      As for testing in circuit, I am aware of that, but as you know these tincan smd caps are not always these easiest to remove without damaging them or the pcb, hence why I was looking for a short. Kinda hoping for an easy solution.
      None of the cap values are out of the ordinary, so it could easily be done to remove the caps in question one at a time, and replace them, then see if that resolves things?
      Obviously, it may be that there is some other problem, and I don't really wanna devote loads of time chasing my tail on this synth.
      That said, if I could be sure there was a cap fault, I would happily replace them all.
      • redwire
        • 3912
        Roland uses high quality caps, I can see the two solid polymer ones too. Not sure why there are two through-hole Panasonics sticking up there.
        This leads me to think the problem is not the caps. It's not cheap chinese stuff.
        See if any small IC's are shorted and getting hot, check the power supply voltages.
        • Crystaleyes
          • Sep 2021
          • 493
          • Brazil
          In fact if I check the voltage across those caps in question they all measure 5v, so none of them are shorted.
          There is one regulator which I can see that is for the 3.3v line and that measures fine, then there are two LM2576's which both have stable voltages and are not heating up.
          The only components which do evaporate IPA faster are two JRC 2374's so I'll check out their datasheet and see if they can be verified easily or not.
          One thing that does stand out is that on the opposite end of the board from the 9v input, there are nine caps with no voltage across them, they are not shorted.
          It's a shame the Roland service notes aren't easily available.
          • double_DD
            How can I be sure that my EC chip is dead?
            by double_DD
            As the title suggests, how can I be sure that my EC chip is really dead?
            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
            03-12-2025, 07:47 AM
          • disorder
            ps5 edm-033 dead after hdmi/usb ports destroyed
            by disorder
            hello guys,
            i need help to repair a edm-033 ps2
            history : as always hdmi port and usb ports destroyed after unplugged
            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
            so i changed it
            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
            i don't see any projection of liquid metal on pcb.
            01-14-2025, 12:48 PM
          • zunasthegreat
            Chieftec GPS-450-AA with dead 20N60C3
            by zunasthegreat
            Hello everyone hope all doing well!
            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
            09-01-2024, 07:12 PM
          • Beton
            Finding a dead short component
            by Beton
            Hi guys!
            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
            I have a bench PSU and if I try to inject voltage the voltage...
            12-10-2021, 01:05 PM
          • FiguringITout
            MSI Raider GE75 - Not posting, probable dead CPU
            by FiguringITout
            Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
            Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
            07-25-2024, 07:27 AM
