yamaha rx-a2a bad stanby power supply
  • tritron
    • Mar 2019
    • 9
    I got yamaha rx-a2a and there is no power no stanby led. I was poking arround
    power supply and shlotsky diod is bad. I get beep of continity. The part has
    marking m3405 08 d5409 on board. What replacement I can buy for it ? What elese could be shorted out with those diods ?
  • CapLeaker
    Leaking Member
    • 8352
    Re: yamaha rx-a2a bad stanby power supply
    Take the diode out or lift a leg and check it in both directions. If it is bad, just size a diode properly up and replace it. Just make sure you put either the same or better rating diode back in. That’s it.
    • tritron
      • Mar 2019
      • 9
      Does anyone knows where I can find service manual.
