yamaha rx-a2a bad stanby power supply
  • tritron
    • Mar 2019
    • 9
    I got yamaha rx-a2a and there is no power no stanby led. I was poking arround
    power supply and shlotsky diod is bad. I get beep of continity. The part has
    marking m3405 08 d5409 on board. What replacement I can buy for it ? What elese could be shorted out with those diods ?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8177
    Re: yamaha rx-a2a bad stanby power supply
    Take the diode out or lift a leg and check it in both directions. If it is bad, just size a diode properly up and replace it. Just make sure you put either the same or better rating diode back in. That’s it.
    • tritron
      • Mar 2019
      • 9
      Does anyone knows where I can find service manual.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        03-31-2024, 02:12 PM
        07-01-2024, 06:34 AM
      • JimBanville
        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
        by JimBanville
        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
        09-13-2023, 07:21 AM
      • CMCM
        Russound CA4 Power Supply Repair
        by CMCM
        Hello Everybody,
        Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
        Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
        The outputs marked 12v and 20v are all measuring only 1v.
        The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
        The capacitors physically look clean (no bludgesor leaks) and...
        07-03-2025, 01:12 PM
