Technics SA-EX310 dead...no sound, no display
  • Francesc V.
    Tempus fugit
    • Nov 2022
    • 231
    • Catalonia
    Hi:
    I am trying to bring back to live this amplifier. So far I see that main transformer doesn't receive 220V. It doesn't receive voltage because relé is not activated and doesn't close the main AC circuit to the transformer. (It's not activated because Base of transistor is not excited.......base is connected to pin2 that comes from the main PCB)
    Between pin 1&3 I am getting 6.3V, which seem correct......is this the "standby" for the PCB?
    Pin 2.....the one connected to base is tagged as "relay". So as soon as it gets the right voltage, the relé will receive about 21V dc....... and then all voltages should be present in the PCB. (that's my analysis that maybe is wrong).
    What's the part that triggers this pin2?
    Is it this part? (don't see it conneceted to the connector, but it says "relay"..)
    Regards,
    Francesc.
    P.S: Service manual attached for reference
  • lotas
    • Jan 2016
    • 4587
    • Russia
    Re: Technics SA-EX310 dead...no sound, no display
    This relay starts (gives a command) the microcontroller U901 (25 pin).
    • R_J
      • 9535
      Rely control is by U91, pin 25 (noted by lotas)
      Also locate Q902 and check if you have 5.1 volts on emitter and collector. (page26)
      • Devil_rider
        • Jan 2023
        • 33
        Do you get voltage on the power button? If yes make a temporary short to try to start the Amp. During my time with Panasonic I saw switches going bad a lot. Also on this unit the fan and the power amps are the weak parts( not related to your present issue though)
        • Francesc V.
          Tempus fugit
          • Nov 2022
          • 231
          • Catalonia
          Hi:
          Pin 25 in the microcontroller has 5.1V.
          Both Collector and emitter in Q902 have 5.1V
          In the power boton PCB, there is also 5V. As soon as you click the power boton it goes to 0 for a second, so I foresee some kind of trigger there.
          I will disassemble front panel in the meantime.......to see if I visualise something wrong there.
          What do you think about injecting voltage in the Q751 Base to power up everything? (or shortten C-E)
          Regards,
          Francesc
          • lotas
            • Jan 2016
            • 4587
            • Russia
            Is there 5v on the Q751 base?
            • Francesc V.
              Tempus fugit
              • Nov 2022
              • 231
              • Catalonia
              Yeap!!! it's fixed...........it had "nothing".
              Desassembled front panel. Cleaned PCB and connectors with isopropanol and came back to life.
              I will be testing it to see if everything is ok.
              Regards,
              Francesc.
              • Francesc V.
                Tempus fugit
                • Nov 2022
                • 231
                • Catalonia
                Before cleaning...........base had 0V. Now it has the voltage you mention.
                • Devil_rider
                  • Jan 2023
                  • 33
                  Good job!
                  • ChaosLegionnaire
                    by ChaosLegionnaire
                    09-13-2022, 09:02 AM
                  • LEECH666
                    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                    by LEECH666
                    Good day ladies and gentleman!
                    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                    01-19-2024, 05:46 PM
                  • Christos Tsiligiannis
                    Marian Trace Alpha sound card repair help
                    by Christos Tsiligiannis
                    Hello to the forum.
                    My name is Christos, I am new to the forum here and i am posting from Greece.
                    So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                    To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                    So i tried asking for a schematic from the company and they would not give me one. Instead they...
                    11-18-2024, 05:26 AM
                  • Xenon-Codex
                    Technics SL-PG420A.CDM4/19 whining sound with CD-R
                    by Xenon-Codex
                    It works but a loud whine appears with CD-R discs, but only in the middle of the disc, beginning and the end are silent. Silver cd's do not whine.
                    It's still present with a different clamp. The player is Technics SL-PG420A.​ Blue capacitor in the laser circuit is replaced already.
                    12-21-2023, 01:51 PM
                    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                    This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    09-12-2024, 02:30 PM
