Marantz SR4023 - stuck in standby
  • gfosterCA
    • 13
    Hi folks.
    I've checked KEY1 at the CPU and voltage is dropping as expected when the front panel button is pressed.
    I'm unclear as to whether voltage should be present or not on P-FAIL in a good state.
    Suggestions on test points for healthy voltage ?
    Relay activates manually when DCPS voltage applies. Where is the standby relay activated from in CPU, WAKE ?
    Thank you.
    Greg.
  • lepak06
    TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
    by lepak06
    Hello
    I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
    The TV is faulty with stuck in Standby RED LED. Can't power the TV.
    Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
    All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
    But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
    01-12-2023, 01:43 AM
  • toty79
    Hisense LTDN50K220WSEU stuck in standby
    by toty79
    Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
    As per Hisense tv title LTDN50K220WSEU stuck in standby
    PSU rsag.820.5687 HLL 4855WF
    Main rsag 7.820.5842
    I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
    05-01-2022, 04:39 PM
  • lego1234567
    LG 32LB1R - stuck in standby mode
    by lego1234567
    Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
    What could be the problem ? Thanks...
    01-21-2024, 03:39 AM
  • Stunt
    Hp Laptop Stuck on Hp protected by hp sure start screen
    by Stunt
    Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
    I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
    I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
    Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
    screen that's it and stuck there. I left it until the following day and i still...
    09-02-2025, 01:51 PM
  • Faluky
    firmware for Marantz SR5008 stuck in update loop
    by Faluky
    After an update it stopped playing audio and video, I have reset it as it says in the manual and tried to reinstall the firmware over the internet but logging failed each time and I tried to download the firmware to install it by usb but it does not appear on the official page, could you help me? Since it would be a shame to have to get rid of him, European version Thank you very much
    Best regards.
    Anyone got their hands on firmware for Marantz SR5008 stuck in update loop
    01-17-2023, 04:33 AM
