Hi... trying to fix my sons SubZero SZ-PMIX8-MP powered mixer.... Initial fault turned out to be output amplifier TDA7293... but I've replaced a couple of times, and just generating more smoke!!... Can't find any fault on the power module, starting to wonder if its the mixer sending faulty voltages? So, the question.. Anyone know where I can find schematics for this unit... Google search hasn't uncovered anything obvious. thx
Re: SubZero amplifier
check the speakers and cables first . and be sure to not turn up the volume to clipping levels .Comment
thanks... I get some strange readings on the voltage regulators, but assumed that was my measurement technique... so I'll have another go at measuring (or replacing) them...Comment
sorry for 'newbie' question... but I don't have the cables/speakers attached... I assumed (dangerous, I know!) that with no speakers, it should pull no current?Comment
Re: SubZero SZ-PMIX8-MP powered mixer
Apply the signal from the tone generator to the audio input.
You can do it, for example, from a laptop or phone. You will get a constant output that you can measure.
Then a multimeter for ac voltage and write what you get on both channels. The mixer must of course be turned on, and speakers do not need to be connected.
Inside the circuit the're DC voltages to power the audio path. Voltage regulators should be measured on the dc voltage setting.Comment
Hi, I realise this is an old topic but does anyone have a circuit diagram for the SUBZERO PMIX8 ?? ..... got one that keeps just cutting out.
Cheers, Kevin.Comment
Model: Phonic powerpod 1860 plus
Board: pod1860 v11 master pcb
(number above this): 0D02005Q0100G
I attached photo of the specific board which I need to check.
Thanks in advance, guys/gals.
08-28-2024, 05:08 AM -
by dicky96Hi guys I'm trying to fix this powered speaker
I have bass but no treble. The horn speaker works OK but I have no audio signal going into or out of the TDA7293 amplifier chip that drives the horn. The chip has power +/- 24V
I don't appear to have any HF signal coming from the preamp/mixer board, only LF. The signal present LED is on/flashing.
I have a schematic which seems to be the correct one for the main amp but not for the mixer - see attached
For example on my mixer PCB, I don't have SW5 which is referred to on the schematic. Also I don't...-
04-28-2023, 07:22 AM -
by BektronicsHello dear audio friends.
I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
Thanks in advance if anyone can help me with this schematic.
Of course, all information about this digital mixer and possibly references...-
07-24-2023, 06:40 AM -
by dicky96Hi guys
I'm trying to repair this powered mixer. Sorry this is a bit long but I want to give as much info as possible to help get an answer,
As soon as it powers on the protect light comes on. There are relays that connect the speakers to each channel of the amplifier but they never click. If I connect a 60W light bulb in series with the mains supply it comes in bright then goes to maybe 30-50% brightness - it seems to dim a little further over time
I have power to the amplifier, I think it was as about plus/minus 50-60V for the main amp, and plus/minus 15V...-
by EvazXHello everyone,
I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
However, after some time, the replacement motherboard...08-25-2025, 06:09 PM - Loading...
