Re: Repairing Alesis M1 Active mk2 Monitor Speakers
I don't suppose you've taken any voltage measurements anywhere, have you?
This is a sticky topic.
Hi all, this is my 5th attempt to resurrect this speaker
Ive just replaced
r5,r11,r15,r16,r18 -
d1,d2,d3,d4,d5,d6,d7,d9,d14,d15,d16, -
q1,q2,q3,q4,q5,q6,q7 -
c1, c2, c6, c7, c8, c35, -
rt1 -
f1 -
u1 (TL3842P) + dip8 socket -
after all this,plugged in and switched on, no sign of power, dead, no fuse pop, nothing. all solder joints have been checked...
does anyone have any advice at this stage ?
cheersLeave a comment:
I've recapped* two pairs of these Alesis monitors, years ago (whenever i posted here about them), and later sold them off to two different friends, and i've yet to hear any complaints about either pair, so...
* Recapped = using Japanese electrolytics, plus moving that Vcc capacitor from next to the heatsink, to next to the UC384x, and moved the ceramic cap to underneith the chip. I also discovered that my 5A fuse not only fuses but explodes
* Recapped = using Japanese electrolytics, plus moving that Vcc capacitor from next to the heatsink, to next to the UC384x, and moved the ceramic cap to underneith the chipLeave a comment:
Hi, guys. Great thread.
Just purchased a set of broken speakers here in France in a hope to repair them. I'm electronic engineer so it should be doable, but while reading this thread I started having serous doubts if this is a reliable solution. The initial design is quite poor and unreliable. I think batches of capacitors were faulty when Alesis first built them but the rootcause of all is a poor thermal management. That's why everything blows in a semi-random manner. Do you think that by recapping the speaker with decent capacitors and replacing faulty components will bring speaker to a long life? Or it is a matter of time when it will blow again? I'm worried as it might catch fire or something as I often leave speakers unattended? Do you heave return of experience of a lifetime with the recapped units?
Thank you all for this work.Leave a comment:
Thanks for that. There is about 3/8" on 3 of the leads that has broken off. I have some magnet wire on order and plan on re-wrapping the whole thing.
Once I get that done, I can go back to the other stuff. I have gone through the whole thread and it is quite informative. I plan on relocating C8 to the C14 position. So far I have been pretty lucky compared to others as mine is not blowing fuses and hasn't obviously blown out any components.Leave a comment:
So, while I wait for those to be delivered, I have another (self caused) issue that I was hoping someone may be able to help me with. While trying to clean off some of the dark, hardened goop that was put all over the components, I managed to break off the leads of T2. The schematic lists this as only "Transformer 1:1 Gate Drive". Being somewhat of an electronics novice (I've had a few courses and understand the basics, but that's about it), I am unable to find a suitable replacement. I would appreciate it if anyone could point me in the right direction, or even where to get components and a guide to rewrap it, if that is possible.
And if you are in a real pinch and don't have magnet wire, then good regular wire (with PVC insulation) could work too.
As for the rest of the main issue with the speakers... I haven't posted that much in it and don't remember the details too well. But try reading through the entire thread first (I know, it's 16 pages!) just to make sure you didn't miss anything.Leave a comment:
I'm new here and found the board through searching for this very issue. I have been trying to get my M1 Active Mk2 working again. I tried the C8 cap replacement, but it didn't fix the problem. The blue light pulses and the woofer pops at a regular beat when turned on, but that's all I get.
The caps I used were these:
https://www.digikey.ca/en/products/d...1MH20D/4843724
But after reading this thread, it seems they may not be up to the task, so I have ordered some low-ESR caps to try:
https://www.digikey.ca/en/products/d...5AG4AA/2712539
Thanks!Leave a comment:
First, let me thank everyone for putting this wealth of information together, related to this old monitors. Keeping things running is an awesome motivation for tearing things apart
I have a pair of Alesis M1 Mk2's here that a friend of mine is very attached to. They start to heatup and the performance is no longer what it was. Lots of crazy noises, hums, pops, hiss, or just stop. I immediately thought it would just be a cap issue, before I started digging into it, because it is one of the things that do fail in older amps and power supplies.
As I tear this pair down, they both suffer from overheating in the load resistor R37 that appears part of the RC snubber circuit bridging the secondary outputs of the flyback transformer. This half of the flyback feeds the +V-Hi that powers the woofer amplifier section.
While I notice in the thread above, damage to this area is common, I am not seeing the other related issues in this pair. I have a guess that when used at low to reasonable volumes, this circuit dumps far more energy into the RC snubber than the designers accounted for. But I am only making a SWAG at it from my rather rusty understanding of analog circuits
I would think simply using a higher wattage load would do. No need to change the resistance value, but moving to a more substantial dump would most likely do the trick. But before I just jump in and start changing things, I thought I might ask opinions. My limited, and as noted, quite rusty understanding, is that the combination of R37+C38 form an RC snubber that keeps things grounded so to speak, a little bungie cord that keeps things calm, at the price of lots of heat load. Is this evaluation correct?
Thus, simply increasing the wattage, while also sinking the load resistor to the metal chassis, should stop this from simply repeating?
Thanks in advance for any debate and discussion. I appreciate the wealth of information already laid out. And worry not, I will be replacing the caps anyhow, since I already got them torn apart
Cheers
AnjinLeave a comment:
Hi All,
I've actually followed the advice on this forum to repair one of my units previously (replaced C8 with a low ESR Panasonic and the resistor nearby due to charring). I also stood off the cap to move it away from the heat a little.
The speaker in question is a spare 3rd one I have and I went to use it today and found it not to work properly anymore. The LED lights, tweeter works fine, but no woofer.
I have done lots of voltage testing and everything is in spec. The PSU is outputting a very clean +/- 37V on the HI and +/- 18.1V on the LO.
I've also tested the mute output to ensure Q3 on the amp board is OK and yep, seems fine. I've checked the output of the two +/- 15V regulators and all OK too.
Any ideas? Just a fried Audio IC - Seems unlikely IMO if it previously worked?
Cheers,
JamesLeave a comment:
After taking the Monitor apart I notice that when the speaker is in an upright position. The caps are above the R3 and R4 resistors. It seems having them on their sides might not only be better for sound. Might be a bit of a stretch , but heat does rise, so in an upright position the caps might get hotter.Leave a comment:
I purchased the revised boards because I did not have time to deal with the problem last time. The original boards blew within a few hours of each other. Strange after years of use.
Of the revised boards one just blew with about 1/20th the use. This time I will replace the caps on the good one before it blows, and repair the three bad boards.
I just want to thank you guy's for this excellent thread (repair manual really)
Especially Krohn, and mamoka. You have gone to great lengths to help people with these monitors. If I find anything that hasn't been covered already I will add what I can.Leave a comment:
Good luck with the repairs, then.
PS: No need to "sir" me - the Queen hasn't knighted me, i'm not even one of her subjects, and i'd like to think i'm not quite THAT old..... yetLeave a comment:
Thanking you again, sir.
It was actually much easier than that (I knew that this was a good, working board). I had actually unsoldered one side of R15 and forgot!
I will have a look at those links you posted, I knew about Ohm's law but had clearly not used my brain, so will read up on that again.
Many thsnks, sir!Leave a comment:
The 0.22 ohm current-sense resistor may well be open-circuit, especially if, say, the bottom MOSFET is blown as well.Leave a comment:
Ok, I have 2 boards, side by side.
The other, working one read 15k across R10.
Does that meant there is something wrong in that circuit?Leave a comment:
It's perfectly normal. If you look carefully, R10 is in parallel with R11+R15 (which, incidentally, add up to virtually 1k).
https://www.digikey.com/en/resources...eries-resistor
https://en.wikipedia.org/wiki/Curren...hunt_resistors
"The parasitic inductance present in the shunt affects high precision current measurement. "Leave a comment:
Errm, maybe not the last question. So R10 reads just under 1k in circuit with R15 in place (on the bad board).
Once I take R15 out, everything reads fine. I have tried a couple of different resistors in that location, all causing the same result???
Logic tells me it must be R15 but somehow it must be something else in that part of the circuit?
Unless it is because all the resistors I tried are wirewound. That's what I ordered from Farnell (and I had lying around) and until I get something else I won't be able to find out.
Please help if you can.
Many thanks.Leave a comment:
Hi, one last question as otherwise we are good to go, Khron.
I seem to have read a post by you somewehere here not t use wirewound resitors for R15, due to induction?
Induction remains a dark art to me, can you confirm and/or explain why it is nescessary to use a non-wirewound resistor in that place?
Many thanksLeave a comment:
And I kind of answered my own question re the inductors myself, but it is always good to get some moral support...Leave a comment:
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by wattageHello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...-
by ant3202Hi Everyone
Lately I am experiencing the deja-vu incident on one of the led monitor like this.
https://www.badcaps.net/forum/troubl...lashing-on-off
The monitor is HP 27es LED Monitor
https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
The monitor will randomly blackout and display no signal and will recover again.
Sometimes need to power and off again to restore the display but...-
by Rick_1234Good evening, gentlemen.
I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
https://drive.google.com/file/d/1L6S...ew?usp=sharing
Things I tried
- Bought a new AC adapter thinking that was the problem but the problem...-
by momakaLooking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
When I saw the Craigslist post, I wasn't...-
- Loading...
