No worries, we aren't going anywhere.
Well, like Per noted in post #479, you won't be able to measure an inductor's inductance with a multimeter... but that's OK. The multimeter is for checking all of the other components - namely diodes, resistors, and transistors on the board.
For starters, it's probably best that you check your multimeter's functions first. Connect black probe to "COM" jack and red probe to "V/Hz/Ohms/%/NCV...", then select the Ohms / continuity / diode check function (4th position after OFF on the rotary switch), and select resistance test mode (probably might have to press "Func." button to get to it, if it isn't the function selected already. After this short the probes together and note what resistance you get - this is your "short-circuit" resistance. Depending on multimeter and probes quality, this can be anywhere from 0.1 to 2-3 Ohms (sometimes even more, like those cheapo multimeters from HF.)
After this test, also check the voltage of 9V or 1.5V battery, just to make sure the voltage function on the MM is working too.
If all good, time to jump in and start checking components.
Let's start with diode D14, since that looks very close to where all of the "action" happened on the board.
Select diode test on your multimeter (little diode symbol should appear on the display), put red probe on the anode of D14 and black probe on the cathode of D14 (side with the white stripe). You should get about 560-700 mV reading on your screen (or 0.560 to 0.700V, depending on how your MM displays results.) If you get much lower than these values, note what they are and post them here, though you can do the same even if you do get readings in the above range, just as a 2nd check. Also note that this check on diode D14 tests transistor (MOSFET) Q2 across D-S junction. So if you get a really low reading across D14, take it out of the circuit and measure it again. If it measures OK out of circuit, Q2 could be bad.
Next, check resistor R15. It's a 0.22 Ohm resistor, so you should see more or less under 1 Ohms of resistance on your multimeter (again, depending on how low it can measure) when set on the resistance test setting. If R15 is open or showing very high resistance, then transistor Q1 is more than likely bad too.
If either D14 or R15 were bad above, remove them out of the circuit, then test Q1 and Q2. These are MOSFETs. With the MOSFET's front facing you (the side with the "IRF840" part number written on it), the left-most pin is the Gate, center is Drain, and right-most is Source. Use multimeter on resistance test and check resistance between Source-Drain, Source-Gate, and Drain-Gate. For Q1, you should get open (infinite resistance / 0L) for all tests, or very high resistance in the MegaOhm range. For Q2, same, except Source-Gate - should get about 10 KOhms resistance there. If you get any other values, definitely post them here. If you get low resistance readings (in the Ohms range), one or both of these is likely bad and you'd have to remove it/them to test out of circuit.
So let's start with those for now. And if you're comfortable with those and know what you're doing, you can skip ahead and also test Q3 & Q4 (these would be BJTs, so slightly different testing methodology.) I wrote how at the end of post #461:
https://www.badcaps.net/forum/showpo...&postcount=461
Interesting.
Well, the wire turns on the new one appear to be of the same thickness, so that's a good sign. The smaller core, we will have to see about. Generally smaller core = less surface area to dissipate heat. But if the new smaller core heats up less to begin with, then it should be fine. It's going to be a bit of an experiment, like I said... hence why keep the old core until the speakers have been proven to work reliably and without anything overheating.
You don't necessarily need to glue the new inductor... but given how badly the trace and hole for it are eaten away on the PCB, it may not be a bad idea.
Hot glue should work OK, unless the inductor/PCB/surround electronics get really hot (over 60C), at which point the hot glue may become a little soft and not hold as well. On a side note, now you have a thermocouple probe to check temperatures with your new MM, so you can find out eventually.
I've also used regular household silicone/caulk, but that's not always recommended due to certain types/brands producing more acetic acid when they cure than others... and acetic acid is a mild corrosive. Still, even "the worst" silicones would be a million times better than the tan glue.
If you want to be fancy / proper, use electronics-grade RTV.
Other glues - read the fine print. Can't be anything (too) corrosive. Also usually not a good idea to use any solvent-based glues, particularly on inductors or anything with coated magnet wire, as that could strip/dissolve away the insulating coating and possibly short out turns.
Dremel with the finest attachment you have. Maybe a drill with a very small drill bit too. Any charred PCB has to go. When you get to clean... or at least overheated but not charred guts, you can stop then. And yes, that could certainly be one of the hardest parts of this fix. Just take your time with it slowly.
On electrolytic capacitors, the negative side is marked with a vertical stripe. So the positive lead is the other side.
Great! More patients coming for this thread.
Hopefully that one won't have any issues (yet). But, see comment below.
Absolutely!
While at it, replace C8 and C35. It's only a matter of time before they fail too.
