Microwave advise please
  • Nevillet
    • Sep 2019
    • 272
    Hi All,
    I am trying to diagnose a faulty microwave oven and have checked the following components.
    Transformer – The primary and secondary windings have low resistances and no shorts to earth or between pri/sec.
    The high voltage capacitor (1.05uF/2200V) measures fine with no shorts to earth.
    The diode is not shorted or open circuit and when connected to a 9V battery drops 4V.
    The magnetron has a low resistance across the terminals and has no resistance to earth.
    I’ve put a clamp meter around one of the primary lines to the transformer and measured about 4A (240V) when the microwave is ‘on’.
    A cup of water in the microwave does not heat in any way.
    My gut feeling is that the magnetron is suspect but I’d appreciate any opinions on this.
    Many thanks.
    • Jul 2011
    • 6070
    Re: Microwave advise please
    Originally posted by Nevillet
    Hi My gut feeling is that the magnetron is suspect but I'd appreciate any opinions on this.
    Many thanks.
    You are probably correct in your determination of what the issue is
    Depending on the model of your microwave would determine weather or not replacing the
    • redwire
      • Dec 2010
      • 3912
      Last to check is for open filament wiring at the connector/feed-through capacitors or for a bad connection there, or inside the can at the EMI chokes. Magnetron filament is low voltage, high current around 3.3VAC 11A for 36W, but caution it's at the (-ve) high voltage potential and not something to measure safely.
      http://www.hokuto.co.jp/eng/products/magnetron/list.htm
      Measuring mains 4A is a bit misleading becuase there is the transformer's magnetizing current and the power factor needs to be taken into account. So it's not really 4A used, if you have a power meter check how many W it's using.
      • Nevillet
        • Sep 2019
        • 272
        The magnetron is a Toshiba 2M303H(EX) and I can't find a replacement in the UK.
        How generic are magnetrons?
        The one I need is in this article:
          • Jul 2011
          • 6070
          Are you able to find the specifications for the one you have and match it up as close to what you have now
          This aspect is going to very important as well to the one you have “ Type of Outline—> Direction of air flow and mounting patterns ”
          Which there several different air flow patterns and different mounting variations so you would have to match this as well
          • Nevillet
            • Sep 2019
            • 272
            I replaced the magnetron and it cured the problem.
            Many thanks to all.
            • redwire
              • Dec 2010
              • 3912
              That's good you got it fixed. Especially over counter ones are so expensive.
              Where did you buy the replacement magnetron in the UK?
              • Nevillet
                • Sep 2019
                • 272
                The microwave was made by Electrolux and the magnetron was supplied by them as a spare item. The price was £70 including delivery.
                • valvashon
                  Sharp R-930CS microwave/convection oven, dim display
                  by valvashon
                  Older microwave/convection oven I picked for free on Marketplace. Previous owner replaced turntable motor which didn't fit in the mounting hole properly. Shaft was at an angle causing plastic thing that fits onto it to eventually break. Filed the hole bigger, fitted the motor correctly, put on a new plastic thing, all (almost) is OK.
                  The fluorescent display is quite dim. The camera doesn't see what the eye sees so these pictures are brighter than what the display really looks like:
                  As you can see even from these pictures, the tops and bottoms of the...
                  11-14-2025, 12:34 PM
                • valvashon
                  Toshiba EM131A5C-BS microwave oven- noisy EE16 2.7 mH inductor
                  by valvashon
                  This poor microwave oven was purchased by my former employer in 2019 (it's a 7/2018 build) and lasted for about 3 months before making a terrible noise when in use. I determined that it was the main transformer and contacted Toshiba. They asked for a picture of the cord cut in half and the serial number, and then credited my boss' credit card. Rather than sending it to the e-waste, I bought a transformer on eBay and thought I'd try flipping it. Discovered that used microwave ovens aren't worth much but in for a penny, in for a pound as they say. It sat in my basement getting kicked and shoved...
                  02-20-2024, 10:38 AM
                • jkucukov
                  Help with Samsung Microwave Cooling Fan Wiring Pins
                  by jkucukov
                  I have a Samsung Microwave I'm looking to harvest some parts from, specifically the 120V AC motor that keeps the Magnetron cool.
                  From the image below, we see 3 pins on the AC motor, with AC Voltage tester all 3 leads measure 120 V with the microwave plugged in and fan not running. With the fan running only pins 2 & 3 measure 120 V.
                  What I'm looking to do is wire this motor up on a Air Compressor to keep the motor cool, but I need to know what is the safe way to wire it, (IE wire in pins 2 & 3 with 120 V only to get it to run?)
                  Also, as its wired, when...
                  11-24-2025, 05:02 PM
                • Peterpies
                  How to repair ffc connector on microwave panel
                  by Peterpies
                  I have a sharp microwave front panel connectors which link to the motherboard via ffc strips into push in connectors, see images, the connector strips are worn I have cut them back but they still don’t make a good connection any ideas how I can overcome this would be appreciated. All switches on panel which are touch type work fine, have thought about conductive pen or paint anyhelp appreciated....
                  09-21-2025, 10:29 AM
                • davph
                  Microwave HV transformer
                  by davph
                  Hi
                  Can anyone tell me the difference between MD-801FMR-1 / MD-801FTR-1 and MD-801EMR-1 microwave HV transformers?
                  All I can see is they are all 800W but wondered if they are inter changeable...
                  06-25-2025, 08:25 AM
