Dead Oven Control Board, Possibly Transformer?
    • 31183
    Re: Dead Oven Control Board, Possibly Transformer?
    search ali for 169' thermal fuses - if your too specific the seach falls over
      • Jul 2011
      • 6061
      Here is a link that has 150*c
      https://a.aliexpress.com/_mtc5gC5
      • Bobby78
        • Sep 2014
        • 47
        So neither of the manufacturers have responded. Applianceboardrepair.com responded, but were of no help, only sending me links to irrelevant search results on mouser. Their last response was that they did not have a transformer, but if I sent the board in they would "patch it" for me. Not sure what they would "patch" it with considering the useless search results they sent me. Oh well.
        Anyway, I couldn't find an exact match for the fuse and didn't want to wait on AliExpress, so I ended up buying some 2.5A 126C fuses from Amazon for $10. I figured the amp rating was more important than the temp limit. Fingers crossed.
          • Jul 2011
          • 6061
          I hope you got fast acting fuse not time delay fuses they are very different
          The amp rating is more important but also weather or not it is fast acting or a time delay type of fuse
          • Bobby78
            • Sep 2014
            • 47
            It doesn't say either
            https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
            • redwire
              • 3912
              I drew a partial schematic and it all makes much more sense.
              This Frigidaire Oven Controller 318010700 oven control board transformer is a custom part, because the vacuum fluorescent display needs that additional winding - the filament winding.
              I would say estimate it is around 14VAC center-tapped as the board uses less common 9VDC relays. OP measures 18VAC but at no (relay) load, and 4VAC with the VFD connected?
              In a pinch I would use an off the shelf 14VCT transformer and a second (extra) transformer 6.3V and add two resistors to get the filament voltage down to what it should be.
              It's great the transformer survived. I read another forum that this is a common failure mode - any power line surge causes these oven boards to collapse and then cook the transformer. I'm still puzzled about what causes the transformer to overheat. There is an additional primary fuse F1 so I would expect that have protected the transformer but the design fails here F1 should only be around 1/2A max. it must be way over that.
              I would say if you can't get a replacement thermal fuse, it is acceptable to add a (proper) normal fuse on the transformer's primary for F1. I use around 1/4A to 1/2A slow blow.
                • Jul 2011
                • 6061
                Originally posted by Bobby78
                I did not realize that you were buying thermo fuses that will work it just will not let the transformer to get as hot before it cuts out the power to the transformer which is probably a good thing
                • petehall347
                  • Jan 2015
                  • 4436
                  • United Kingdom
                  #28
                  dont forget those fuses can easily be damaged when soldering .
                  • Bobby78
                    • Sep 2014
                    • 47
                    Nice, thanks for the analysis. If I continue to have issues with the thermal fuse, I will consider replacing F1 with a 0.25-0.5A slow-blow fuse and see if that spares the thermal fuse. Hopefully I won't have to rig up a two transformer system.
                    • Wolf1977
                      dead transformer on ceramic oven
                      by Wolf1977
                      hi in ceramic oven the transformer is damaged
                      and writes
                      2x115v/2x12v/6VA 50-60hz ta105/f
                      can you suggest me a compatible transformer ;
                      i have found in 70 degrees celsius do you think is suitable for ceramic oven ;
                      09-02-2023, 03:43 PM
                    • double_DD
                      Transformer replacement for a dead coffee machine
                      by double_DD
                      Hi guys,
                      I have a dead coffee machine, and it seems that the culprit (no 1, at least) is a dead trafo - primary coil seems to be blown open (type shown on the picture below).
                      Now, I'm unable to find direct replacement anywhere on ebay or aliexpress, and all similar that I' was able to find are rated too low (<1A).
                      If someone knows a shop to buy replacement (EU/CH), that would of course be my 1st option.
                      My other ideas:
                      - to buy 220/20Vac trafo with 30VA, and to "manually" create secondary 12V output just via resistor
                      - to buy...
                      06-23-2025, 05:43 AM
                    • DennisH
                      Need Help Identifying This DIODE mounted on a Frigidaire oven control PN:316131600
                      by DennisH
                      This diode is mounted on a Frigidaire electronic oven control PN:316131600. This diode runs hot enough that the PCB is showing slight burn marks (black soot looking area on PCB above the diode). It looks to me to be coming from the body of the diode.
                      The oven control is 22 years old and still works, but I can't get a new replacement, so I'm doing preventative maintenance and replacing a few parts on it that I think could fail - and this is one of them.
                      Can any of you identify this diode (see pic) and suggest a replacement that can handle more heat - or if not, can...
                      10-18-2022, 07:24 PM
                    • Fsufan1391
                      LG Oven model LREL6325F
                      by Fsufan1391
                      Hello everyone my oven is less than 2 years old and all of a sudden recently when i run the oven for 15 minutes or so and i am done with it and shut it off. after about 10 minutes it starts chiming and randomly putting it in different modes like the touch screen is being touched but no one is around it. I have tried to reset it by unplugging it multiple times and no luck. I took it apart to see the main board and everything looks fine. I am wondering if i should replace the main board or if its in the control panel. the touch screen is very responsive and works like it should. its only acting...
                      04-23-2025, 05:42 AM
                    • mikey5791
                      Is it possible for transformer substitution?
                      by mikey5791
                      Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                      Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                      My questions are
                      1. How do i test to see if the transformer is in good working condition?
                      2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                      Hope you guys understand what i was asking. My intention is...
                      11-03-2022, 02:11 AM
