Re: Wine Fridge Power Board
Thank you so much, now i just need to find out the value of the D12 diode which i have in good conditions.
do you know a replacement for the transistors 13005D ? T6, T7? can I use the MJE13007 ?
Thanks!
The Peltiers are a big problem with these cooler. First the Chinese ones one can connect a ATX 12 volt power supply directly to them and without putting them in the unit they will draw maximum amperage. The Manufacturer claims they are capable of drawing 6.5 amps at 12 volts DC. My measuring them for current outside of the heat sink the maximum they will draw if 2.6 amps. If you let them continue to draw that current they will burn out. I have tested them. Actually if you look at there graph you will see they are only capable of drawing about 4.5 amps at 12 volts. As the surface become the same temperature on each side the draw of current becomes less until they equal practically 0 Amps. The Black & Decker unit I tried to repair was not even listed on the B&D site and I read that they did not even support repairing their thermo-electric frig. I though perhaps the US supplier would have better quality Peltiers and I guess they do as one person bought these and was able to obtain 6.5 Amps of current out of them and they actually had a high heat output until something happen and they no longer drew out heat. Of course 6.5 amps was a lot and perhaps they could not hold up to that. The other problem is cost of them. The Chinese sell them for about $3 a piece, but they do not work. The US sells them for minimum $21 each which prohibits buying them as $42 dollar investment in a cooler one can by used for $60. The problem is not so much testing the power supply and temperature control as it is can these two Peltier actually cool 1.5 cubic foot of air from 70 F down to 37 F. and if the ambient is greater than 70F are the Peltiers incapable of overcoming that temp. These numbers are in the specifications of the frig. I was working on and 70F to 37F were maximum ratings. They also say that it will take at least 10 hours to do this. They also say if you open the door frequently, more than one time a hour, the inside will heat up again and will take time to re-cool again. This is the problem. Perhaps if one were only cooling off enough area just for a sandwich and coke that might work. One would have to figure out how many BTUs each Peltier is really capable of cooling.Leave a comment:
If I were testing this PCB on the bench, I would replace the Peltier cooler with a 12V dummy load. I would also lift the two diodes that feed pin #1 of the TL494 from IC2 and IC3. This will allow the supply to reach its full design voltage. Let's call this voltage Vp.
I would then reconnect the diode from IC2 and substitute a dummy resistor for the NTC/rheostat. Typical thermistors will have a resistance of 10K or 5K at 25degC, and a much higher resistance at 0degC. I would then vary the resistance between these two settings (or -10C to +40C) while observing the Peltier output voltage. The voltage should be less than or equal to Vp, never greater. I expect that the voltage should fall as the temperature falls.
Next I would examine the effect of ambient temperature by reconnecting IC3 and heating or cooling the TO92 device (with spray freeze or a hair dryer). Do this with the NTC set at 25degC. As before, the voltage should be less than or equal to Vp, never greater.Leave a comment:
AFAICT, the offboard temperature sensor (the one inside the fridge) is an NTC thermistor, not a thermocouple. Its resistance, together with the rheostat, forms the bottom end of a potential divider. As the fridge becomes colder, the non-inverting input of the opamp rises, causing the opamp's output to increase. This then causes the Peltier's supply voltage to fall.
The TO92 packaged device adjacent to IC3 appears to be a second temperature sensor. I believe it senses the ambient room temperature. I would very much like to see its markings, but for some reason it has been removed from the PCB.Leave a comment:
The temperature sensor is a thermo-couple and a rheostat controls how cold it gets. I think the thermo-couple is a K type but am not sure. One of the IC s should control the duty cycle of the PWM supply. That way as the frig. gets colder the duty cycle decreases as it approaches the temp that was set. Also, there maybe a LED inside the frig. that stays on all the time. It is just used as a light.Leave a comment:
I realise it probably won't be of any help in solving the immdiate problem, but I've drawn the area of the circuit that controls the TL494 regulator. ISTM that the regulator gets feedback from the Peltier output, the NTC sensor (via IC2), its own internal 5V reference voltage (?), and IC3 (uC). IC3 is a microcontroller whose function appears to be to monitor the ambient temperature, but I could be wrong about this.
Code:___ Vcc (TL494-12) <---|___|--+---+ | | |+ | === | --- | | | C 5Vref 5Vref === | || + + GND | +--||---+ | | | | || | .-. .-. +------)--| ___ |---+ | | | | | | +-|___|-+ | | | | | | | R | '-' '-' | |8 | | | | 2|\| | +-------+----+ +-----+----|-\ 1 | ___ D | | | | IC2| >-------------+-|___|-->|--> TL494-1 +| NTC .-. | .-. +----|+/ LM358 === | | | | | | 3|/|4 --- +->| | | | | | | | | '-' | '-' | | | +---| | | | === === === | === | GND GND GND | GND | | | +----------+
Code:.-------------------------. | | +------|1 14 |-- NC | | IC3 | | o---|2 NC? 13 |-- NC | | uC | | o---|3 NC? 12 |-- NC | | | 5Vref <----+------|4 VCC 11 |------+ | | | || | | === +--||---+----|5 OSC1 | GND | || | | | | _-_ | | +-----+ X1 |___| | | | | - | 10 |-- NC | | || | | | === +--||---+----|6 OSC2 9 |-- NC GND || | | +----|7 ADC in? DAC out? 8 |--->|----> TL494-1 | | | D | '-------------------------' | Link o under | |---------| TO92 IC3? o | o o o | | \ | | | / Temperature | -|--|--|- Sensor ? | | | | | | | +--------------------> 5Vref | | | | | | | .-. | | | | | +-------+ | | | | | '-' | | | +---+ +--+ | | | | .-. .-. --- | | | | --- | | | | | '-' '-' | | | +---+-----+ | === GND
Code:+------------+ | | | --- D | --- +------>|---+-----> Fans / LEDs | | | |+ | | .-. === | .-. | | --- | | | | | | | | | '-' === | '-' D1a L1 | GND | | ___ | | -. ,--+---->|--+----UUU---+------+--o Peltier + | )|( | | | | )|( | |+ | ___ ___ | TR2 )|(-----------)-----+ === +--------|___|--|___|--+--+ | )|( | | --- | | | )|( | | | | .-. | -' '--+---->|--+ +----+---------o Peltier - | | | | | | | | | | +------------| D1b | === | '-' | GND | | | | === | +----------------+ GND D | | V .----------. | - | TL494 | | D | | | +----|<--- IC3 (uC) +---|Vcc | | 12| | | | /| |1 | D | / |-|--------+----|<--- IC2 (LM358) | -< E| | | | \ |-|--+ | 13| \| |2 | | 5Vref <----+----|5Vref | | | +----- 5Vref | | | | | | .-. '----------' | | .-. | | | - | | | | | ^ | | '-' | D | '-' | | | | +------------------+ +---+ | | .-. .-. | | | | | | | | '-' '-' | | === === GND GND (created by AACircuit v1.28.7 beta 02/28/13 www.tech-chat.de)
I still think those diodes and capacitors are in backwards. That is C13, D10, C14 and D12.Last edited by keeney123; 09-14-2015, 01:20 PM.Leave a comment:
I think the main power supply is OK, it is the switching circuit that is not working.Leave a comment:
I wish I have the board in front of me, at first thought I was thinking it is set up as the Voltage Doubler circuit for 120AC line but looking at the connections it does not look right.
So the diode (the one connected to the two main filter cap +/- connection) as shown in the drawing is actually a jumper wire? It has to be for it to be Voltage Doubler circuit.
https://en.wikipedia.org/wiki/Rectif..._rectifier.svgLeave a comment:
https://en.wikipedia.org/wiki/Rectif..._rectifier.svgLast edited by budm; 09-14-2015, 11:40 AM.Leave a comment:
fzabkar I have corrected it here. When BudM told me that I did not understand as he drew it to DC primary ground and indeed from the picture of the board it actually seems to go to the DC primary ground.
Also remember you are looking at 1/2 of the circuit. So there is feed back to control duty cycle and to turn off the devices it is controlling. These diodes and caps I believe are used for oscillation for the pulsated DC supply.Leave a comment:
I don't know the reason for the Dxx circuit reference, but, as budm explains in post #104, it "is connected between incoming AC L and another end goes to the junction of those two filter cap not to the primary DC negative as I have drawn". This means that "it appears to be a wire link that programs the fridge for 120VAC operation", as I explained in post #110.
As for the polarities of D10/C13 and D14/C14, I'm still trying to get my head around it. ISTM that the diodes may be reversed, but I'm not certain.Leave a comment:
Fzabkar I do not mind the knit picking that is how something is proving. If you look at previous posts this board was from a unit not working correctly. It was the same as the board that was set up. My belief was that the D10 and C13 of this bad board are in backwards as are D14 and C14 and that is why it did not work. The person that has this board never got back to me. Perhaps the dunkel can confirm the direction of these components. The layout was from a virtual program from BudM all I did was develop a schematic from it. Do you have a schematic of this board or have you repaired these board? Also D14 is there, but it was listed as a resistor by BudM. I just put D14 because it had a marking of Dxx. Which I did not know what that meant perhaps you understand that marking?Last edited by keeney123; 09-13-2015, 10:30 PM.Leave a comment:
My eyesight isn't young anymore, and I don't mean to nitpick an excellent body of work, but ISTM that, on the basis of symmetry alone, the network consisting of D10, R34, C13 and the associated transformer winding should terminate at the source of T7 rather than B-. Also the "DIODE" in parallel with D14 is clearly in error.
Edit: maybe R36 = R39Last edited by fzabkar; 09-13-2015, 09:47 PM.Leave a comment:
Yes dunkel the values possible could be in error as the color coding could be different from looking at a picture as apposed to seeing in real life. I Believe the schematic drawing to be very accurate. This can be confirmed by ohming out the various points on the board. As fzabkar said there is a symmetry of the circuit so some of the components are the same because you have two circuit performing similar functions. I would still lift these components up on one side and measure them as I have run across color codes that were wrong for the value of the part and yet the part was of the correct value. I think in China if they catch that the color code is wrong they go ahead and use the part because the part is good.Leave a comment:
R35 = R38
R34 = R37
D10 = D12Leave a comment:
So the best spec. I can come up with is in post 106 schematic I drew up. I do not have the board, I am going from a picture. I tried to have the numbers verified by the person who has the board, but he has not responded back yet.Last edited by keeney123; 09-13-2015, 05:20 PM.Leave a comment:
Hello, I am having problems with this board, some components are totally burnt and i would like to know the specs of them, can you guys help me? the components are:
L1
R34
R35
R36
D10
Thanks in advanceLeave a comment:
Assuming...7 Photos -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by lkveeTurned it on. Green LED is on (set to cool), but the fan did not spin. Opened up the back, and found two blown capacitors. One blew up dramatically enough to remove the outer covering. Not sure if I can find that outer covering. I *think* the power board is the JWBX-12V5A-A (source: nbjianwei.com). She just wants to cool off her skincare products. If I were to buy an 12V AC adapter (Amazon has one by HKY), can I use it with this compromised power board?
If I need to repair this power board, how can I identify the specs of the nekkid capacitor? I can identify...3 Photos -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos - Loading...
