Siemens RVS21.831, Looking for References, Models, and Values of These Components
  • mengpo
    • Dec 2021
    • 9
    • France
    Following a short circuit on the controller board of my heat pump, I'm looking to replace the components shown in the photos. All I know is that they are diodes (but I'm not sure what type), and I haven't been able to find their equivalents.
    The one on the left says: 15A 5BA
    The one on the right says: DTZ S47 or DTZ 547
    Does anyone know how to identify them?
    Thank you very much for your help!
    FYI, the card is a siemens RVS21.831
  • CapLeaker
    Leaking Member
    • 8179
    What do this pins do? If I had to guess these are TVS diodes.
    • redwire
      • 3910
      A new diode will also just blow - you have to find out why mains is present at that low voltage connector!
      Logo is Vishay General Semiconductor - Diodes Division.
      Closest I can find is 5KASMC or maybe a 1.5SMC TVS.
      "5AG" is not listed but might be a 5KASMC8.5A
      see SMC markings
      • CapLeaker
        Leaking Member
        • 8179
        Vishay marking 15A = 1.5SMC15A or a P6SMB15A; Vishay, Onemi or Littlefuse etc are the same.
        The other one I can't make out the manufacturer. Maybe clean it up and make another picture.
        A diode marking DT on a SMB device would be a SMBJ78CA.
        I guess you have to figure out if the case size is an SMB or a SMC and go from there.
        • proxneo
          Recapping Sony ICF-SW55 - verifying cap values
          by proxneo
          Dear reader
          I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
          At the moment, I have selected replacements based on the following list of values:
          3 x 470uF 10VDC
          3 x 4.7uF 35VDC
          4 x 47uF 50VDC
          8 x 22uF 6.3 VDC
          1 x 220uF 6.3VDC
          5 x 100uF 6.3VDC
          Which...
          06-21-2023, 12:38 AM
        • Kobok
          Different (lower) resistor values on PCB?
          by Kobok
          Dear Alls,
          For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
          09-19-2022, 07:30 AM
        • Acerman123
          MSI K7T Pro2 Ver1 - capacitors have higher values?
          by Acerman123
          Trying to fix this board, MSI K7T Pro2.
          All Tayeh capacitors showed either as damaged or with uf values which were faf from what they should be so I have replaced them and all other capacitors except those big ones near CPU.
          The motherboard powers on but doesn't post. My PCI bios code reader will most of the time dsplay some some kind of code if there has been no power to board for a while but I don't think those codes mean anything in this situation. If I power off the board and try powering it on the second time the code reader usually doesn't show anythin. Unplug...
          08-12-2023, 10:00 AM
        • mrkmpn
          Capacitor values in boardview
          by mrkmpn
          I am trying to determine the value of a blown capacitor, and the boadview shows the values for many of the capacitors and other components on this board, but all of the information blank on others.
          Is there any relevance to the fact that some of these values are left out, or is it just inconsistency by whoever created the boardviews?
          Is there any way to deteremine if one without infrormation matches one that shows those details?
          05-25-2022, 12:03 PM
        • rewease
          Replacement for the Siemens Bakelite caps in an early 1980s SMPS
          by rewease
          There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
          Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
          Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
          09-17-2023, 12:53 AM
