Fisher and Paykel 10 kg top-load washing machine LED identification
  • mojos911
    • Aug 2018
    • 25
    I'm looking for a replacement for the red LEDs used in a Fisher & Paykel 10 kg top-load washing machine. Each LED is about 6 mm long, mounts flush to the PCB with side tabs, and measures around 1.7 V forward voltage in diode-test mode. The marking on the body is “3A56,” but I can't find any matches for that in part searches. I've attached photos to show the shape and mounting style.
    If anyone has sourced an equivalent or knows a suitable replacement, I'd really appreciate your input. Thanks in advance for the help!
  • mon2
    • Dec 2019
    • 14979
    Some of the 1W-3W LEDs look close to the above.
    https://www.ebay.com/itm/400985235317
    https://ampul.eu/de/smd-leds/1113-sm...w-uv-380-390nm
    • mojos911
      • Aug 2018
      • 25
      Thank you. Getting harder and harder to find the parts with out the original part numbers for identification.
        • 31314
        those leds are just for the indicators under the buttons?
        they wont be 1w, probably only using a few mA
        • redwire
          • 3912
          These are special LED's - they reverse-mount on the PC board backside and shine their light through a hole in the board.
          They look the same format as 1W "bead LED's" (7.3mm dia) but much smaller.
          Nothing available for a round hole. There are plenty of bottom-mount gull wing 3528 but these are square.
          I would see if 1206 round could fit Ali with some creative solder blob.
          • mojos911
            • Aug 2018
            • 25
            Thats correct redwire
            stj they are the buttons LEDs, Yes.
            LS P47K-K1K2-1-Z-KS, Point LED, SMD Super Red, 630nm, 2mA, 1.8V, from Osram - I got some coming in from Germany. So well see.
            Interesting development though when I removed the LED from circuit they tested witht the diode mode on the multimeter - OK but the fault cleared on the circuit. The original fault was the LEDs would not illuminate and when tested with diode mode on MMeter the LEds that wont on where testing either OL or giving a reading in both directions of say .6v So maybe the LEDs are ok because now that i pulled them out of circuit and tested agian with diode mode on Mmeter that are all showing correct readings. So now I'm having to reevaluate my findings.
              • 31314
              i actually thought they may be from osram - the package style reminded me of a super-bright led called golden-dragon or something like that.
              btw, i have seen leds light but also meter in both directions.
              so reverse breakdown while still functioning is not impossible.
              • mojos911
                • Aug 2018
                • 25
                Hi stj, redwire and mon2 Got what i needed from Germany and wallah, all is right again with the panel. Interesting how when the faulty ones where removed from the pcb their readings would show 1.7v when testing with multimeter in diode mode but sure as I'm sitting here typing this, I replaced the three suspected faulty ones and its all good again. Thanks for your advice.
                • Soulzink
                  Samsug washing machine. Power supply DC41-00189a board issue
                  by Soulzink
                  I am trying to fix a samsung washinmachine power supply main board.
                  I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                  Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                  The power supply board reference is the following: DC41-00189a
                  I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                  04-19-2025, 06:26 AM
                • Shulgin
                  Acer predator XB241YU Component identification
                  by Shulgin
                  I have a problem with my Acer predator XB241YU screen. When I plug it in, the startup LED turns on instantly, and I can't turn off the screen without unplugging it.
                  After disassembly and inspection of the electronic cards I found what looks like a broken inductor, it is marked with the letter A and is at location L58.
                  In the first photo you can see the broken component, in the second photo you can see where it is on the board, in the third photo you can see the silkscreen and in the fourth photo you can see the identification sticker of the main board
                  I...
                  05-11-2024, 11:06 AM
                • thebomb602
                  ASUS GA402R IC identification
                  by thebomb602
                  Hey guys! my name is kyle, new to motherboard troubleshooting and a little confused still on chip identification if yall could help identify this chip..
                  also if you could teach me how to fish on this particular topic... i did read through the ic identification sticky, and couldnt identify this with that info... thanks!
                  EDIT, just realized thats a 5 and not an S in the first line... finding results for it now. cant figure out how to take down thread so im not embarrassed...
                  11-21-2023, 02:30 PM
                • Tend0
                  hp elitebook 840 G4 no 5v IC identification
                  by Tend0
                  Hello everythone
                  i have on the bank hp elitebook 840 G4 6050a2854301 mb a01 missing 5V cause IC is damage on this board 5V and 3V IC is separatly
                  i have 3V but no 5V i found 5V IC damage . i need our help to find IC identification, the 3v ic has mentionned ALVH 572 i found reference but no see something like IC . I poste the 3V here if someone have is reference. i don't found motherboard schematique or boardview...
                  05-31-2025, 09:13 PM
                • Tomylee
                  Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
                  by Tomylee
                  I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
                  It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
                  I'm looking for help with the following:
                  The exact identification or part number of the T5 component
                  05-28-2025, 12:42 PM
