Garage door module Nice SNA4/A - burnt component
  • jm1234
    • Jan 2024
    • 61
    • Slovakia
    I'm trying to guess what component got burnt on the control board for my Nice garage door motor Nice SNA4/A. You can see it in front of the 2 capacitors. The component is connected across the 36V rectified input wires, maybe it was some kind of protection device?
    All the pictures I could find were of the whole product, so enclosed in the plastic box, eg. https://www.ebay.co.uk/itm/123998876212
    Any help appreciated.
  • jm1234
    • Jan 2024
    • 61
    • Slovakia
    Better focused picture
    • jm1234
      • Jan 2024
      • 61
      • Slovakia
      actually it's rectified 35V AC, so it's 50V DC
        • 31063
        i think it was a GDT
        small one made of glass - the bigger ones are ceramic to prevent that!
          • 31063
          if it's 50vac input then you need one rated atleast 75v - maybe 100v
          • jm1234
            • Jan 2024
            • 61
            • Slovakia
            Thanks for the suggestion, just learned something new again :-).
            However, thinking about it some more, my bridge rectifier was not damaged, it still produces those 50V. Not sure how would high voltage appear on that GDT to burn it then?
            Also, does it seem the right place for GDT to put it after the bridge rectifier?
              • 31063
              not sure about the design, i wouldnt use a GDT,
              a GDT will latch on once it trips until the voltage drops a lot - a MOV is safer but slightly slower
              • redwire
                • 3910
                I agree the busted part is a GDT but not sure why it exploded. Did it just pop, they are gas-filled under pressure. No signs of heat. I thought the fuse would blow before it heated up enough to explode.
                It's seems to be a worm gear reduction, so you could not push against the door and generate high bus voltage.
                *Is that big Jamicon preggo, rusty at the top?
                The lowest voltage available GDT's are rated 75V ±20%. Most common are 90V. Once they are ionized lit up, they stay on conducting like 12V arc at 1A. Until zero-cross if AC is present. This one seems to go on the DC bus- which is not the brightest idea. MOV are what you use. It typically is a 24VAC mains transformer making around 35-40VDC but the motor seems to get higher voltage. I think a toroid power transformer is inside and a bridge rectifier board as well.
                Could not find board pics or decent info on the Nice SNA4.
                Garage door openers are susceptible to lightning. Overvoltage transients come in on mains, or on ground between the door rails/frame and PE ground.
                The Nice has no PE ground connection? So much plastic.
                More on garage door opener lightning protection in this thread: https://www.badcaps.net/forum/troubl...e4#post1815406
                • jm1234
                  • Jan 2024
                  • 61
                  • Slovakia
                  Both caps are bulged, need to replace them. I think the only other thing that popped was fuse on 220v side.
                    • 31063
                    jamicon are always shit
                    • CapLeaker
                      Leaking Member
                      • 8192
                      Replace the GDT with a bi directional TVS and call it a day. The GDT may have a higher surge capacity, but here I can’t see it being an advantage over a TVS. If you want you can theoretically triple your input protection by GDT, TVS, MOV all in parallel. Lol
                      The TVS or MOV would be my choice, because I don’t have any GDT’s in stock. As long as the rating is correct on the surge protection device, you can’t do anything wrong here. If you take the damaged GTD out, the board should work again, less the protection of course.
                      • redwire
                        • 3910
                        I think you'd have to sketch the circuit around the GDT and see what is going on, there should not be 75-90V there, and current long enough to heat it up and blow it up. The fuse should pop quickly before all that.
                        Then there are the bad electrolytic capacitors. Strange failure. I keep thinking the motor regen with low value caps did it, but again it's a worm gear so the motor should not backspin.
                        I haven't seen Jamicons since the 1980's lol in CRT monitors, arcade games.
                        • R_J
                          • 9551
                          Littlefuse makes a mov that looks similar IE V47MT2B or Harris V68MA3A
                          • CapLeaker
                            Leaking Member
                            • 8192
                            Looks a bit small to me… and the leads are thin too.
                            • R_J
                              • 9551
                              "similar" as in not exactly the same.
                              • redwire
                                • 3910
                                I've never seen a GDT with such thick leads as OP's. That makes me thing it's a TVS or diode, MR756 first thing to come to my mind. Or maybe some other 6-10A diode? What does a 6A10 look like inside. No PCB silkscreen hard to know if the part has polarity.
                                The reason for a big diode I think is the 24V gel-cell power option for this opener, it might be protection against reverse-polarity? Was a battery wrongly connected letting smoke out?
                                • CapLeaker
                                  Leaking Member
                                  • 8192
                                  That’s exactly what I would put in there… a TVS and call it a day.
                                  • jm1234
                                    • Jan 2024
                                    • 61
                                    • Slovakia
                                    Just got back to this, sorry about the delay. I bought TVS https://www.tme.eu/ie/en/details/1.5...dil/1-5ke68ca/.
                                    When I put it in the PCB, I noticed tha TVS is connecting + poles of the 2 biggest capacitors. So I can see the supply voltage on the 1st capacitor, but it doesn't get to the 2nd capacitor. That's a homework I should've done before bying TVS, sorry about that.
                                    If I understand this correctly, TVS isn't the right way to address this, as I need that voltage to be passed onto the 2nd capacitor (and the rest of the board). Instead of the over-voltage protection that TVS provides, I probably need some over-current protection there, right?
                                    Thanks in advance.
                                    • CapLeaker
                                      Leaking Member
                                      • 8192
                                      Huh? So you bought a 68V TVS that protects a 50V capacitor? A TVS you can buy in unidirecttional and bidirectional versions. So it matters which way you put the unidirectional TVS in. You gotta read up on how these protection devices work. The protection devices work on over voltage, like TVS, MOV etc. vs over current like a fuse. That what is in there is not a fuse. In it does guaranteed not feed one big cap to the next via a TVS or whatever. Would be idiotic.
                                      This is connected between the positive poles on the 2 capacitors? It should work as intended. Matter effect, the whole thing should work without the TVS installed. You got another power supply missing that feeds the other cap.
                                      Maybe re upload some more pics and from the bottom too.
                                      • jm1234
                                        • Jan 2024
                                        • 61
                                        • Slovakia
                                        Not saying I don't need to learn, that is absolutely true. I just took the lazy path of following your advise literally, without thinking further. I see the PCB, not you, so I should have traced more before asking.
                                        Anyhow, I shorted the TVS and it started to work. Coming back to my original question, what should I put instead of that burnt component. Knowing now, that this component connects + poles of the 2 big caps, I think GDT doesn't make sense, as it doesn't conduct under normal circumstances.
                                        As for uni-directional TVS, it would pass the current in one direction, so the device would work. However, I don't understand the protection function here - it would only protect against reverse polarity until the break-down voltage and then it would just start conducting in reverse.
                                        Pls correct me if I'm wrong here.
                                        Appreciate all your help.
                                          Lift Master garage door opener with WiFi capability application through your phone
                                          by sam_sam_sam
                                          I had a lot of trouble with the WiFi connection from my router inside of the house into a ( new ) metal garage I had to run a 150 ft cat6 patch cord so the WIFI connection would be strong enough for the WiFi connection on the garage door opener would work correctly ( my son has a work out area in the garage as well and he was having to put his phone near the door to be able to stream music ) ( so I was going to eventually put WiFi out there anyway )
                                          This garage door opener WiFi is very touchy if you lose the power it does not remember the password for the router which is weird or...
                                          01-21-2023, 08:31 PM
                                          Linear Garage Door Opener Control board took a crap install a new control board back normal
                                          by sam_sam_sam
                                          I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
                                          02-08-2025, 06:52 AM
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          by sam_sam_sam
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                          Linear Garage Door Opener Control Board Repair weak capacitors
                                          by sam_sam_sam
                                          I was having issues with the controller not always responding to remote control signal having to hold button until garage door started to move
                                          Now after replacing the two capacitors on the two 5 volt power supply rails
                                          One is used for the up/down limit up/down force circuits
                                          Second one is used for the radio receiver circuit
                                          The main filtering capacitor ESR value was a little higher than a new one
                                          https://www.northshorecommercialdoor...yABEgLxlvD_BwE
                                          09-03-2022, 12:15 AM
                                        • Cornboats
                                          Garage door opener-safety cutout faulty
                                          by Cornboats
                                          I have vintage Slavedor garage door opener that has stopped closing the door. If I disable the up/down current control to the motor it works fine. I've attached the larger control board which is for everything and the smaller current control board.
                                          Normally the current control is set slightly above the maximum current normally used. If the door exceeds this it should stop and reverse when closing or just stop when opening. Can someone please explain how the current control board works so that I can try and repair or replace the defective parts.
                                          I see my self as an interested novice...
                                          01-19-2023, 05:25 AM
