Siemens induction panel PCB burnt
  • jm1234
    • Jan 2024
    • 64
    • Slovakia
    this is a Siemens induction panel, one side seems damaged, I attached both good and burnt picture to compare. I'm not sure what those rectangles a are for, but they are connected by a solder. That seems to be what got burnt, so I'm wondering it that was some kind of a protection. Do I just try to re-solder them?
    Thanks,
    Daniel
    • 21863
    Thanks,
    Daniel
    Post pictures of the other side of the board,and the part numbers
    • jm1234
      • Jan 2024
      • 64
      • Slovakia
      Nothing visibly obvious on the other side of the board, I'm attaching the picture. The only 2 protruding legs visible on those burnt rectangles belong to the blue capacitor (2u2) and the round brown capacitor just next to it
      Not sure if the part number is what's shown on the other picture but hoping it is.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        On the PCB there is the writing F2 so perhaps it is a PCB fuse? If so you probably have a short somewhere else...
        • jm1234
          • Jan 2024
          • 64
          • Slovakia
          So that's what I'm trying to understand. Besides finding the root cause, I'm curious about that burnt solder. Once I find and fix the root cause, do I just re-solder those burnt connections? If they indeed were designed as a fuse of a kind, I imagine their function would very much depend on the kind and amount of solder I would put there.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            I don't think it is possible to recreate it with enough precision, but it was just made as a cost measure: you could substitute it with a real ceramic fuse, however knowing the intended value would probably require a schematic...
            • lotas
              • Jan 2016
              • 4786
              • Russia
              Check the diode bridge and IGBT transistors for short circuit.
              • jm1234
                • Jan 2024
                • 64
                • Slovakia
                Right on the money, this is what I checked earlier this morning and 2 of the 4 transistors are shorted. The diode bridge seems fine.
                Daniel
                • alpersen
                  Siemens Washing Machine WM12T581TR/67 Touch Panel not working correctly
                  by alpersen
                  On the right bottom side it has a start/stop button (normally it is illuminated, when I took the picture it was blinking I took at the wrong time ). and the touch area there is not working, maybe if I am able to touch the most right bottom in a maybe 1 square millimeter area it works. also generally if I touch the normal place where the start stop icon is, the weight + and - areas register so there is a touch calibration problem in that area. All icons maybe 60% of the left side register correctly in their respective size. Siemens service recommends replacing the control pcb and screen (nearly...
                  10-24-2025, 01:55 AM
                • electomech-fixer
                  First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                  by electomech-fixer
                  I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                  I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                  09-15-2025, 01:42 AM
                • howardc64
                  LG 49UJ6500 LCD panel lighter band that goes away
                  by howardc64
                  49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                  Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                  02-19-2023, 12:13 AM
                • triplefour
                  SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                  by triplefour
                  TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                  tcon is built into mainboard.
                  Only one cable goes to panel boards.
                  there is a cable from one panel board to the other that links them.
                  cost cutting measure that results in us having harder time to diagnose.
                  removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                  used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                  07-28-2022, 07:59 PM
                • Storyteller12
                  QN55Q60R Service Menu Panel Help
                  by Storyteller12
                  I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                  I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                  I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                  the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                  01-13-2024, 01:57 PM
