Hi Guy's
I am hoping that someone may be able to help me identify a component on a condensor dryer control board
or if anyone has a circuit diagram of the board it would help.
The water pump went bad for some reason but even with the new pump fitted the new pump wont pump when the
float switch is engaged.
I have tested the new pump out of circuit and it works and I have tested the wireing from the pump and float switch
and all is well.
It was when I traced the wireing back to the control board that I noticed a component with a creator in it which has
destroyed the part number which is why I need help.
The Condenser Dryer is a Logik and the model number is LCD7W18
I will upload a picture of each side of the circuit board plus a picture of the exploded component which was taken
under the microscope which shows better detail. It would also be good if you could let me know if you think any of
the other components might need checking.
This one shows the component with the creator in it.
This one with a bit more detail.
Thanks for your time and any help you can give me!
and all is well.
