Bosch WDU28560GB/02 washer-dryer - time jumps, blocked door, codes E60 and -09
This topic has been answered.
  • mariukonie
    • Aug 2023
    • 29
    Bosch WDU28560GB/02 washer-dryer. After selecting the spin program, the clock jumps from 0:13 immediately to 0:05 and counts down the minutes to zero. The pump turns on and the door locks, but nothing else happens, the drum doesn't spin. After the countdown ends, it does not open the door, it can only be opened by pulling the emergency handle next to the filter. No error is shown. When I select spinning and hold my finger in the lower left corner of the screen, after 5 seconds E60 and -09 are shown alternately. What could be the problem? Is it possible to turn on the service mode so that the washer-dryer can perform a test on its own? Thanks.
  • Answer selected by mariukonie at 01-24-2024, 07:09 AM.
    petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    its possibly a faulty pcb . did you get it into test mode yet ?
    another thing to try is unplug the heater and see if a different code appears .it might not actually mean heater fault .
    its got me thinking of the 09 .maybe it means 1 of 9 faults . did you try cycling through fault codes ?
    • mariukonie
      • Aug 2023
      • 29
      • petehall347
        • Jan 2015
        • 4427
        • United Kingdom
        E60 is a heater fault .
        The diagnostics mode (accessed by turning the control ring to Rinse/Spin/Drain and holding the bottom-left of the touch screen for 7 secs
        well that's if we can trust the internet .
        • mariukonie
          • Aug 2023
          • 29
          Thanks. I've tested the heater element. It seems okay. Is there any was to reset and erase the codes?
          • petehall347
            • Jan 2015
            • 4427
            • United Kingdom
            i would think the fault clears when its repaired . did you check the heater for the drier ?
              • 31071
              did you check end to end on the heater or ends to the body?
              most water heater elements fail by shorting to the casing.
              when you take them out you often find they have split open and have rust in them.
              • CapLeaker
                Leaking Member
                • 8205
                How did you test this part? Only because there is continuity inside the element it doesn't automatically mean there is no earth leakage.
                • mariukonie
                  • Aug 2023
                  • 29
                  I always had appliance plugged in through RCD. If there was leakage it would trip RCD.
                  I did test resistance between body and heater terminals and it's OL, I know it's different under voltage but RCD would notice it.
                  Resistance between heater element terminals is in normal range.
                  I'm thinking if heater was faulty it should have still do spin cycle.
                  It does go into dry cycle and heats up but not turning drum
                  Does anyone have repair instructions for this Model Number WDU28560GB/02
                  That would really help to test everything and eliminate other possibilities. Thanks.
                  • petehall347
                    • Jan 2015
                    • 4427
                    • United Kingdom
                    • mariukonie
                      • Aug 2023
                      • 29
                      I don't know how to get it into test mode, can't find any info online, How is it done please?
                      I tried unplugging heater, still the same.
                      Tried cycling through fault codes, nothing. Just one code E:60 -09
                      Just read that these suffer from dryer becoming unsealed and I remember there was lot of moisture on the inside when I took cover off, I just thought it was because it was in garage but it was quite a lot of moisture. It was more than week ago so it's all well dry now.
                      • petehall347
                        • Jan 2015
                        • 4427
                        • United Kingdom
                        did my instructions not work then ?
                        • CapLeaker
                          Leaking Member
                          • 8205
                          Is there a relay on a board that turns on the heating element which is fubar?
                          • petehall347
                            • Jan 2015
                            • 4427
                            • United Kingdom
                            this is what it says on elektroda https://www.elektroda.pl/rtvforum/topic4019313.html
                            • petehall347
                              • Jan 2015
                              • 4427
                              • United Kingdom
                              here is how to use service mode ..
                              https://www.youtube.com/watch?v=ASHjWsdVTCs
                              • petehall347
                                • Jan 2015
                                • 4427
                                • United Kingdom
                                reset procedure here ... https://diaryofspaces.com/reset-bosch-washing-machine/
                                  • 31071
                                  does it fault instantly or does it take a minute or 2?
                                  if it takes a while then maybe it works but the sensor cant see the water temperature rising?
                                  • mariukonie
                                    • Aug 2023
                                    • 29
                                    Thank you so much. This is very useful. I couldn't find it myself. I'll do the procedure and post results.
                                    I got my hands on repair instructions of very similar model I'll go ahead and do all checks recommended and post update very soon.
                                    Thanks for help much appreciated.
                                    • mariukonie
                                      • Aug 2023
                                      • 29
                                      Hi again. Thanks for all help. I've managed to find the problem, it was the motor and motor controller STK5Q4U363J on module .
                                      I got two STK5Q4U363J from Aliexpress, First one didn't work fortunately second is OK
                                      I got second hand motor from ebay.
                                      After replacing these the washer dryer works perfectly.
                                      Regards.
                                        Lift Master garage door opener with WiFi capability application through your phone
                                        by sam_sam_sam
                                        I had a lot of trouble with the WiFi connection from my router inside of the house into a ( new ) metal garage I had to run a 150 ft cat6 patch cord so the WIFI connection would be strong enough for the WiFi connection on the garage door opener would work correctly ( my son has a work out area in the garage as well and he was having to put his phone near the door to be able to stream music ) ( so I was going to eventually put WiFi out there anyway )
                                        This garage door opener WiFi is very touchy if you lose the power it does not remember the password for the router which is weird or...
                                        01-21-2023, 08:31 PM
                                      • Petr0x
                                        Bosch 12V and 18V chargers modification
                                        by Petr0x
                                        Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
                                        You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
                                        Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
                                        05-24-2024, 01:00 PM
                                        Linear Garage Door Opener Control board took a crap install a new control board back normal
                                        by sam_sam_sam
                                        I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
                                        02-08-2025, 06:52 AM
                                      • CapLeaker
                                        Bosch Nexxt 500 dryer blinking start button - no start fix
                                        by CapLeaker
                                        My Bosch NEXXT 500 dryer quit today, press start nothing happens and the start button just keeps blinking. Not cool. Reset the dryer, same thing.
                                        Even so the buttons feel good, my problem was the start button smd tactile switch on the PCB. Cleaned the switch with alcohol followed with Deoxit and the sucker runs like a champ again.
                                        I like these easy evening fixes!
                                        12-07-2023, 04:38 PM
                                        Linear Garage Door Opener Control Board Repair weak capacitors
                                        by sam_sam_sam
                                        I was having issues with the controller not always responding to remote control signal having to hold button until garage door started to move
                                        Now after replacing the two capacitors on the two 5 volt power supply rails
                                        One is used for the up/down limit up/down force circuits
                                        Second one is used for the radio receiver circuit
                                        The main filtering capacitor ESR value was a little higher than a new one
                                        https://www.northshorecommercialdoor...yABEgLxlvD_BwE
                                        09-03-2022, 12:15 AM
