Hi again. Thanks for all help. I've managed to find the problem, it was the motor and motor controller STK5Q4U363J on module .
I got two STK5Q4U363J from Aliexpress, First one didn't work fortunately second is OK
I got second hand motor from ebay.
After replacing these the washer dryer works perfectly.
Regards.
Try our *UPDATED* boardview, bios, & schematic search. Over 2.3 million files for download!
Bosch WDU28560GB/02 washer-dryer - time jumps, blocked door, codes E60 and -09
This topic has been answered.
Thank you so much. This is very useful. I couldn't find it myself. I'll do the procedure and post results.here is how to use service mode ..
https://www.youtube.com/watch?v=ASHjWsdVTCs
I got my hands on repair instructions of very similar model I'll go ahead and do all checks recommended and post update very soon.
Thanks for help much appreciated.Leave a comment:
does it fault instantly or does it take a minute or 2?
if it takes a while then maybe it works but the sensor cant see the water temperature rising?
this is what it says on elektroda https://www.elektroda.pl/rtvforum/topic4019313.htmlLeave a comment:
did my instructions not work then ?I don't know how to get it into test mode, can't find any info online, How is it done please?
I tried unplugging heater, still the same.
Tried cycling through fault codes, nothing. Just one code E:60 -09
Just read that these suffer from dryer becoming unsealed and I remember there was lot of moisture on the inside when I took cover off, I just thought it was because it was in garage but it was quite a lot of moisture. It was more than week ago so it's all well dry now.Leave a comment:
its possibly a faulty pcb . did you get it into test mode yet ?
another thing to try is unplug the heater and see if a different code appears .it might not actually mean heater fault .
its got me thinking of the 09 .maybe it means 1 of 9 faults . did you try cycling through fault codes ?Last edited by petehall347; 12-05-2023, 09:41 AM.- Selected Answer
I always had appliance plugged in through RCD. If there was leakage it would trip RCD.
I did test resistance between body and heater terminals and it's OL, I know it's different under voltage but RCD would notice it.
Resistance between heater element terminals is in normal range.
I'm thinking if heater was faulty it should have still do spin cycle.
It does go into dry cycle and heats up but not turning drum
Does anyone have repair instructions for this Model Number WDU28560GB/02
That would really help to test everything and eliminate other possibilities. Thanks.Last edited by mariukonie; 12-05-2023, 08:30 AM.Leave a comment:
did you check end to end on the heater or ends to the body?
most water heater elements fail by shorting to the casing.
when you take them out you often find they have split open and have rust in them.Leave a comment:
i would think the fault clears when its repaired . did you check the heater for the drier ?Leave a comment:
Thanks. I've tested the heater element. It seems okay. Is there any was to reset and erase the codes?Leave a comment:
E60 is a heater fault .
The diagnostics mode (accessed by turning the control ring to Rinse/Spin/Drain and holding the bottom-left of the touch screen for 7 secs
well that's if we can trust the internet .Leave a comment:
Bosch WDU28560GB/02 washer-dryer. After selecting the spin program, the clock jumps from 0:13 immediately to 0:05 and counts down the minutes to zero. The pump turns on and the door locks, but nothing else happens, the drum doesn't spin. After the countdown ends, it does not open the door, it can only be opened by pulling the emergency handle next to the filter. No error is shown. When I select spinning and hold my finger in the lower left corner of the screen, after 5 seconds E60 and -09 are shown alternately. What could be the problem? Is it possible to turn on the service mode so that the washer-dryer can perform a test on its own? Thanks.Tags: None
by sam_sam_samI had a lot of trouble with the WiFi connection from my router inside of the house into a ( new ) metal garage I had to run a 150 ft cat6 patch cord so the WIFI connection would be strong enough for the WiFi connection on the garage door opener would work correctly ( my son has a work out area in the garage as well and he was having to put his phone near the door to be able to stream music ) ( so I was going to eventually put WiFi out there anyway )
This garage door opener WiFi is very touchy if you lose the power it does not remember the password for the router which is weird or... -
by Petr0xHi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...05-24-2024, 01:00 PM -
by sam_sam_samI have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
by CapLeakerMy Bosch NEXXT 500 dryer quit today, press start nothing happens and the start button just keeps blinking. Not cool. Reset the dryer, same thing.
Even so the buttons feel good, my problem was the start button smd tactile switch on the PCB. Cleaned the switch with alcohol followed with Deoxit and the sucker runs like a champ again.
I like these easy evening fixes!
by BjsI was given this TV with little info. Was told that it didn't have a picture. Upon powering it up it displayed the Vizio logo and the menu was able to be displayed. I connected an antenna (OTA), did a channel scan which completed and the picture has been fine for days. The only issue is it has an initial blink code of 23 upon power off, followed by a 19 about 75 seconds later which then repeats the 19 code four more times. I haven't been able to find the process for entering the service menu nor do I have the service manual for this model (I do have the E60-C3 and E70-C3 service manuals but they...
- Loading...
