I have an LG frontloading dreyer #dre2050W (210v)that doesnt turn on when hitting the power button, however the light inside the drum is on. Reserching leadsd me to believe the control board #EBR36858801 itself is bad, as it is a common problem. Looking at grainy pics on the web, I can see a transformer, caps, and maybe a bridge rectifier, on the board. What would you focus on first, assuming the power to the board is good? Ill tear into it and post pics tonight.
LG dreyer control board no powah.
Mann-Made Global Warming.
- Dr Seuss
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by YanlebHi all, I just want to share the repair of my 60PK550-UA TV set.
The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
C57: 3.30V
C61:...07-20-2023, 12:38 AM -
by sam_sam_samI have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
by redoxyI am looking at the option of replacing my control/driver board to one with HDMI and/or Display port input on a 2K LED (I think IPS) screen.
The display is Samsung LTM270DL07.
I have tried using the model number to search for a compatible control/driver board but so far my efforts have been futile.
I am looking for inputs on what board could potentially be used for my display.
Attached are pictures of the display label information and connectors (CON30 CON40 only) and pictures of the current control board.
Also attached is a technical...-
03-14-2023, 08:52 PM -
- Loading...
