Electrolux ERG22 vacuum cleaner pcb fault
  • petehall347
    • Jan 2015
    • 4447
    Re: Electrolux ERG22 vacuum cleaner pcb fault
    all you can hope now is that your customer doesn't see this thread .
    • Crystaleyes
      • Sep 2021
      • 493
      • Brazil
      Haha... Nice one
      • Henke
        Electrolux EUO9GREEN Vacuum Cleaner doesn't start
        by Henke
        I have a vacuum cleaner that won't start. I have desoldered 2 capacitors with low value. But i don't know if they can cause that kind of problem. Someone here with any thoughts and inputs?
        I marked the capacitors on the pcb picture with red and blue dots. The big one marked with 334 K measures 216 nF and the other one marked 224 K measures 109 nF.
        01-08-2024, 11:37 AM
      • AlexVG
        Replacing the WiFi module on a vacuum cleaner iROBOT i7
        by AlexVG
        I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
        I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
        (This board does not respond, only the LEDs light up in a circle.
        The liquid damage is catastrophic and restoration is impractical).
        (I bought this board to get the WiFi module and camera).
        The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
        If...
        10-22-2024, 07:20 AM
        ZD-915 vacuum pump motor mount service alert
        If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
        One note this unit has been repaired already once because of switching power supply regulator ic chip failure
        Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
        The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
        09-19-2021, 02:15 AM
      • Tyroonis
        Identify component - QPF Chip from Eufy Robovac L70 Hybrid Vacuum Cleaner
        by Tyroonis
        I have a robot vacuum cleaner here.
        An Eufy Robovac L70 Hybrid.
        A chip has burst due to a short circuit.
        The following is legible on the chip:
        Mpsm44
        m2612
        883138
        I'm not sure if there is another number after m2612, as that's exactly where the hole is.
        Can anyone help me identify what this component is?
        Unfortunately, I couldn't find anything.
        I also don't have any plans or board views of the...
        08-14-2025, 02:32 PM
      • rtstorm
        Xiaomi Vacuum Cleaner Charger PSU
        by rtstorm
        Hello my vacuum cleaner dock died, 0V on output. I replace the caps but still no voltage. I found out that this resistor is broken (showing 0 Ohm) do know the value of this? Is this really 0 Ohm resistor?...
        05-24-2024, 10:07 AM
