Help identify chip MITSUBISHI ELECTRIC Air-Conditioner Network system
  • sikocan
    • Oct 2019
    • 344
    Looking for a component labelled 56 on top 59 on bottom. It's from a MITSUBISHI ELECTRIC Air-Conditioner Network system. Thanks!
  • R_J
    • 9553
    Re: Help identify chip MITSUBISHI ELECTRIC Air-Conditioner Network system
    They seem to be Renesas Technology RD56P-T1-AZ zener diode
    • sikocan
      • Oct 2019
      • 344
      How do you know? I'll see if I can find them. Thanks again.
      • R_J
        • 9553
        BZV49-C56 could be a replacement, check the datasheet and see if it matches, Pins 1 & 3 are likely connected together
        The part is obsolete but I found a case style used on there lower voltage zeners that has pin1 NC
          • 31084
          it's there for protection, find out why it blew up first.
          • sikocan
            • Oct 2019
            • 344
            The guy plugged in AC instead of DC. The diodes did their job I guess.
            • BOSCHNJAK
              by BOSCHNJAK
              ABOUT ME INTRODUCTION FILE
              2
              024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
              2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
              2022 BEV, PROJECT ?
              2021 BEV, PROJECT ?
              2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
              2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
              12-28-2023, 02:09 PM
            • howardc64
              Samsung UN55JU650DF network/streaming problem
              by howardc64
              Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
              This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
              07-09-2025, 12:44 PM
            • davg
              Home network connection problem
              by davg
              I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
              03-06-2021, 07:13 AM
            • japlytic
              Maximum speed should be marked on network ports
              by japlytic
              I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
              One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
              12-19-2024, 05:04 PM
            • thesame
              DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
              by thesame
              Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
              The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
              02-27-2024, 04:31 AM
